New Firmware......12/06/2016
123Next >
6640 92 2016-12-6
Oliver F
Thank you,
I will check out the DJI GO 4 app
2016-12-6
Nerds=Drones
They have to many peeps with these birds to foul up
2016-12-6
R&L Aerial
Flight distance : 298100 ft
Mavvy Posted at 2016-12-6 17:10
Please explain more on this subject please.
There have been post about the wind warning feature on the p4 pro constant notifications about the wind speed even though it's calm?
2016-12-6
hedfan
Flight distance : 21470 ft
Great, still no facility for manually switching to ATTITUDE mode
2016-12-6
sarge43
Solid update for this early.  Thanks DJI.  I'm sure more are to follow.
Sarge
2016-12-6
FedsRevenge
Flight distance : 2487 ft
Still waiting for mine, but it sure is nice to see more firmware updates as I wait
2016-12-6
C-GMTV
Flight distance : 197064 ft
What the ??? I have flown my Mavic for 6 hrs so far. Today I went to go fly and It says New Firmware. I go through the process (15 min) all seems to be fine. Restart the Mavic and go for a 4 min flight then land. All seems normal so I tap the auto take off button, the Mavic takes off and hovers for 1 second then all motors quit and it drops onto the hard ground. My gimbal is busted. It tells me check to see if the gimbal lock is on.
Anyone else have this happen?
2016-12-6
Gary Mac
Flight distance : 829885 ft
hedfan Posted at 2016-12-6 18:26
I think I want this as well.  Wouldn't it make it much more stabile indoors to prevent it switching in and out of ATTI vs GPS mode?  I hate that transition.
2016-12-6
DJI-Ken
Flight distance : 1515312 ft
Gary Mac Posted at 2016-12-6 17:21
It's been suggested long ago and if since it's not on this update maybe it won't become available, or possibly it may be at a later date.
And flying indoors the downward sensors should keep the aircraft positioned so if it goes in and out of GPS mode it shouldn't matter (as long as none of the sensor limitations are present).
2016-12-6
Gary Mac
DJI-Ken Posted at 2016-12-6 20:03
Good to know.  It was quite stabile today, but I noticed a little twitch from time to time.  I thought it might be from going in and out of ATTI mode.  Tripod mode was awesome.
No rain in the forecast tomorrow, so I'm hoping to get some outdoor flights in.
2016-12-6
James L.
My Mavic seems more stable.  Thanks for the awesome update!
Ken, is there a way to request a firmware update?
I would really like to either fix the gimbal roll adjustment via hold down C2+exposure wheel or allow adjust via 5D controller.
In the Phantom 4, the hold down C2+exposure wheel worked perfectly.  However, when I try that with the Mavic, the exposure changes along with the gimbal roll.
I personally would like the ability to adjust with the 5D button.
Thanks!
2016-12-6
DJI-Ken
Gary Mac Posted at 2016-12-6 18:11
If it seems twitchy, you can lower the sensitivity and gains.
I like my aircraft really docile, I lower the sensitivity and gains (not altitude gain) pretty much on everything I fly.
2016-12-6
GoCardz
Flight distance : 353747 ft
Has anyone tested whether this fixes the TBE (toilet bowl effect) where the Mavic claims GPS signal loss and begins to spin uncontrollably?  A few of the improvements hint at fixes on what others thought might be causing this to occur.  I'm curious if this is the case.
2016-12-7
fans915ed907
Flight distance : 5416604 ft
DJI again start to put the best stuff away after you perform a firmware update.
This time they took out one of the best picture style - Art mode!!!! I do not see any stability issue if art mode stay in.
In my exp, Art mode gives the most details, accurate color and no so digital sharpening feel for grading. D-log and D-cinelike is good but they produce various color shifting and color cast, which means the color is no so accurate. And the worse is they are just too flat and can not maintain detail.
One lucky thing is , you can still stay in art mode if you haven't change the setting after the firmware update. God bless me and hopefully DJI give me back the art mode. Or can someone find a better / similar picture profile like art mode? thx.
2016-12-7
Mayoo
Flight distance : 299708 ft
GoCardz Posted at 2016-12-7 16:03
That was fixed on last firmware already ..
2016-12-7
Mayoo
James L. Posted at 2016-12-6 20:52
Follow this settings for Cinematic Views
2016-12-7
Adanggas
I went for my first flight this afternoon with new update. After about two min of flying my iPhone 7 plus screen went black. Did not show any video and all the info said N/A. Good thing it was in line of sight. I quit dji go and reopened with my mavic still in the air and it was fine after that. This was my 8th flight and the first time this has ever happened. Should I be worried....
2016-12-7
Nerds=Drones
She definitely flys different. Can't think of the word.  Gues I have to get use to it
2016-12-7
QuanthonyTrang
Flight distance : 419980 ft
Nerds=Drones Posted at 2016-12-8 10:32
That's because the firmware resets all your settings. Your stick input sensitivity is now default and therefore the craft may not respond the same. Take a screen shot of all the settings before updating firmware next time.
And if you KNOW what you are doing, then reprime the Mavic with IMU, compass and stick recalibration. This is arguable, but if done right, you will have a better user experience and more understanding of the Mavic Pro.
2016-12-7
richard56
Flight distance : 675869 ft
The smooth track setting in that video seems to have been removed for those looking for it. I cannot locate it.
2016-12-7
Nerds=Drones
QuanthonyTrang Posted at 2016-12-7 17:44
I had default settings for the last version?
2016-12-8
T_A_Rogers
Flight distance : 68537 ft
DJI-Ken Posted at 2016-12-7 04:16
If it's ruining your live streams, don't use RTH and lower the battery warnings and if they're already at the lowest then land before the warning.I made the suggestion but it was not done so this is how it is. They see it as a safety precaution, so it's probably going to stay there.
It's great for the beginner to keep them reminded.
I often turn for home at 20%. I don't need it to yell at me all the way home..
I certainly see the value for a beginner, which is why this would make sense as a UI setting an experienced pilot could disable or adjust the volume of.
2016-12-8
jvanderhoff
Flight distance : 14045 ft
C-GMTV Posted at 2016-12-7 07:55
That is concerning. Did you send the logs to DJI?
2016-12-8
DJI-Ken
T_A_Rogers Posted at 2016-12-8 08:51
DJI probably thought differently and thought it's there for safety and if they wanted you to be able to disable it they would have given the option.
2016-12-8
ZeeinBC
Flight distance : 287749 ft
I updated and have flown about 6 times since the update.  No issues to report, same flight times ~22-24 mins.. I had to reset a few settings but in all, nothing felt different.
Managed to get one of those red scrolling compass errors though in mid flight while flying at top speed in sport mode - I was at the beach and some whales came by, so in a rush to go film them I did a horrible job at the calibration dance, which i'm pretty sure caused the issue. Next battery I re calibrated and had no problems.
This update requires the batteries to get updated too -- so remember to do all of them before you head out.
2016-12-8
Kevin16
Flight distance : 353642 ft
Anyone tested 60fps or are we accepting that the issue is not firmware fixable?
2016-12-8
GMG
Flight distance : 3632605 ft
dana5 Posted at 2016-12-6 19:50
Still no mute for the return to home BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP
Oh, how I wish this was an option!  It screams "Look at ME! Look at ME!
Would be great if there was a way to at least turn down the volume!
2016-12-8
stealle
Flight distance : 21827 ft
DJI-Ken Posted at 2016-12-8 10:03
@DJI-Ken  The beeping is ridiculous. And, that is a very good point about it ruining live stream. The beeping ruined my first live streem too.  The live FaceBook messages I was getting changed from "Wow, that is so awesome!" to [BEEP, BEEP, BEEP, BEEP, BEEP] "Wow, that is so annoying! Is it going to explode?... Can you make it stop?"
But I guess it is what it is right Ken. Probably the same reason they will not allow manual Attitude mode. We should not even ask. DJI knows what is best for us. Really Ken.... I can only go by what I read in your posts, but it sounds like to just sheepishly ask for things on our behalf once and then tuck your tail between your legs when they say no. Can you keep on them about this.  Hell, make an advanced setting that can only be accessed after an 4 hours of flight time beefore the beeping can be reduced to 3 beeps or disabled.
2016-12-8
DJI-Ken
stealle Posted at 2016-12-8 15:12
@DJI-Ken  The beeping is ridiculous. And, that is a very good point about it ruining live stream. The beeping ruined my first live streem too.  The live FaceBook messages I was getting changed from "Wow, that is so awesome!" to  "Wow, that is so annoying! Is it going to explode?... Can you make it stop?"
If you go to the Me page and select more, you can send your feedback there. If enough send it in they may do something. I know Manual ATTI was sent a bunch of time starting months ago.
2016-12-8
stealle
DJI-Ken Posted at 2016-12-8 17:47
@DJI-Ken - What is the Me page?
2016-12-8
DJI-Ken
stealle Posted at 2016-12-9 09:24
The Me page is where your info is. NFZ applications, you can get to the forum from there and the DJI store too.
If you click on More, you can choose DJI Support, your DJI credits, and leave feedback.
2016-12-8
Heavysledz
Flight distance : 819491 ft
This might help....
From the APP click on "ME"
Click on "More"
Click on "More"
Click on "Feedback"
Click on "Feedback"
2016-12-8
stealle
Uhhhh... yeah... immensely helpful.  Thanks! I was looking for a Me page here on the forum, lol.
2016-12-8
Heavysledz
stealle Posted at 2016-12-9 10:16
yea, I looked on the forum and didn't find anywhere to leave feedback so I looked on the app after Ken suggested it...
2016-12-8
VoDoXuS
Flight distance : 88619 ft
Can someone give clear instructions on how to update the firmware on batteries? I've read so many different reports.
2016-12-8
No Man's Drone
Flight distance : 301545 ft
VoDoXuS Posted at 2016-12-8 21:22
I'd like to know as well.
2016-12-9
Kuzz
Flight distance : 136900 ft
Has anyone had any issues with their Mavic since the update on the latest firmware?
I just took mine up in the garden to show a friend and in normal mode it seemed quite sluggish and slow, not as responsive as normal... I then bragged sport mode and switched it to show the speed and the speed did not change in the slightest... It was exactly the same. It was working fine the day before I updated it so it's clearly something with the update that has caused this.
I've seen people talking about updating the battery before? I never knew this was something that had to be done, does it just get done automatically to the battery that's in the Mavic when updating the Mavic Firmware?
2016-12-9
C-GMTV
jvanderhoff Posted at 2016-12-8 08:01
I spent 2 hours trying to access the flight logs with the DJI software with no luck. I have sent the unit in for repair as the gimbal doesn't work. The unit should have the flight log still in it so the repair facility can check it out.
2016-12-9
stealle
VoDoXuS Posted at 2016-12-8 20:22
Batteries just get updated automatically same as any firmware update. When a new firmware is available for ANYTHING you will be prompted to do so. As long as you accept it will update. You've probably already updated your battery firmware and didn't realize it. It doesn't specifically say "battery firmware"  before the update it just says "firmware". This only becomes obvious when you have multiple batteries. When I got my two spare batteries it prompted me to update firmware with each battery.
2016-12-9
Adanggas
Kuzz Posted at 2016-12-9 18:11
Mine did the same thing. I had to go back into the settings and make it do the sport mode switch would work. Update messed with all my old settings.
2016-12-9
123Next >
