height limit on phantom 2?
3859 10 2016-12-18
fansbcc1a8ca
if i buy a phantom 2 . NOT vision... but the phantom 2...(2.4ghz) model is there any kind height limit like my phanotm 3 advanced has?or any of the updating like my phantom 3 advanced has? thanks a lot
2016-12-18
DJI Natalia
You can change the settings through Assistant on your PC when aircraft is connected properly.
To upgrade the firmware, we need run the Assistant as well.
For the details, you can check the manual here: http://dl.djicdn.com/downloads/p ... elease_Notes_en.pdf
2016-12-19
Inspire_Max
Flight distance : 9211303 ft
bafore upgrading, check your version...should you be so lucky having a 1.08 DON'T upgrade!!!
1.08 has NO height limit and speeds very fast...
2016-12-19
fansbcc1a8ca
i just purchased a dji 1 brand new but was purchased 3 years ago. its a v1.1.1...what you think? also has not been upgraded or any firmware. what should i expect?
2016-12-19
trance728-
Flight distance : 298048 ft
I have a P2 sitting in my room that I haven't touched for a long while, I doubt I've upgraded the firmware. I don't really remember much of a limitation to height, I could change it in DJI P2 Assistant.
Any particular reason you need to go higher?
2016-12-19
fansbcc1a8ca
Inspire_Max Posted at 2016-12-19 11:23
its a v 1.1.1 the back if the drone says
2016-12-19
Inspire_Max
fansbcc1a8ca Posted at 2016-12-20 03:17
NO!
You have to connect the Phantom to a Pc or Mac using Phantom Assistant software and check the version once is connected.
2016-12-20
Inspire_Max
trance728- Posted at 2016-12-20 02:57
Selling it? Interested if it's not upgraded and has the FW 1.08
2016-12-20
j3r0me33
DJI Natalia Posted at 2016-12-19 01:10
i understand that.
im asking when did dji start installing the 500 m height limits on all their models, new out of the box. im asking specifically about the phantom 2.
thanks
2017-1-2
Inspire_Max
j3r0me33 Posted at 2017-1-2 10:23
i understand that.
thanks
If I don't get wrong, they started with firmware 2.XX
2017-1-4
j3r0me33
Inspire_Max Posted at 2017-1-4 14:36
thanks man do you happen to know what year>
2017-1-6
