Any one fix a ESC error after update
1621 12 2016-12-29
fans492b5fcc
Philippines
Updated after flying now will not start up
2016-12-29
fans492b5fcc
Philippines
Fans492b5fcc
2016-12-29
DJI-Jamie
Flight distance : 112405 ft
Have you tried downgrading and reapplying the firmware update? Just to clarify, what firmware are you currently on and what were you on before?
2016-12-29
fans492b5fcc
Philippines
I had ver 1.10. 90  now trying to put back on the text old or same ver when I read the chip
2016-12-30
DJI Natalia
fans492b5fcc Posted at 2016-12-30 02:10
You have an advanced or professional aircraft?
Would you please format the SD card and try to upgrade it again?
Also you can restart the aircraft for several times then check again.
What mobile device you are using? APP is up to date as well?
2016-12-30
Whenwillbehappy
Philippines
Using advance
Upto date on rc will I lose pics if I do the SD card
2016-12-30
Whenwillbehappy
Philippines
Using dji go and tap 7 A samsung
2016-12-30
DJI Natalia
Whenwillbehappy Posted at 2016-12-30 02:50
Using advance
Please copy the pictures or videos from the SD card to your PC before you format it.
Have you tried to delete the DJI GO APP and re-install it?
2016-12-30
Aardvark
Flight distance : 384432 ft
Try calibrating the RC.
2016-12-30
Whenwillbehappy
Philippines
Don't know how to get screen shot on here
2017-1-1
Whenwillbehappy
Philippines
Yes I have reset the control and reinstall ver 1 10.9
The tab that been having problems with also when I did update but dji says everything else
So just trying to figure out
The lights Blick green camera light green everything good until I try to start motors then puts  error up will not start motors
2017-1-1
Whenwillbehappy
Philippines
Not sure how  to load last flight on
2017-1-1
mycypher
Flight distance : 682215 ft
I'm looking for help on this also. I have experienced the same exact problem after updating the firmware on my P3P. Using an Ipad 2 Mini DJI Go app and RC or updated.
2017-1-11
