Landing gear stuck
2273 28 2016-12-30
Rschutte3
Flight distance : 275577 ft
First flight with my inspire 2 today. Everything went great until I went in to land. Flipped the gear switch to lower and the landing gear got stuck in travel mode. Anyone else have this problem? I was able to land on a set of 4x4's and to avoid damaging my x5s
2016-12-30
Donnie Stugots
Flight distance : 3636782 ft
I would Inspect that VPS sensor , make sure nothing is binding on the gear as well.  Wow , that is a real bummer on such a high end machine , hope you find  a fix quick .Some other helpful members who just received there machine may be able to help you , not sure if there is a different procedure for it . Sorry I cant help you more .
****I  am not 100% versed on the Inspire 2 .  Maybe ask Casey Neistat, he is the guy on You Tube that DJI gives new product  too ......I am sure he would be happy to help you ......( sarcasm )
If I figure something out or another thread has a solution I will let you know .  Please keep us posted if you find a solutiion  for the benefit of others as well.
donnie
2016-12-31
Rschutte3
After the semi-crash landing I cycled the power and the landing gear operated normally. I am going to pull the logs and send to dji
2016-12-31
fansa84fe8a4
Flight distance : 3 ft
If I buy one, I think I'm going to find something round to land it in so the camera doesn't hit the ground on landing if the landing gear faults.  Need to find something portable as I don't think I'll find 4x4's nearby.  Maybe a kid's blow-up life saver from Dollar General, or Boom-Pa's hemorrhoid cushion?
2016-12-31
Donnie Stugots
fansa84fe8a4 Posted at 2016-12-31 11:09
You can also just catch it as well, just be sure to grab  the fuselage firmly from the bottom and not the camera . It works in a Pinch but would not advise doing it each time , also only if you have the skill and reflexes as well.  I dont like the idea of landing on the Hemorrhoid  cushion , to many variables and 'Boom-Pa " will be missing it !
donnie
2017-1-1
RichJ53
Flight distance : 1837356 ft
Wow I am surprised you had trouble already with the new Inspire 2. Glad you were able to get it down without issues.  Did you note the height indicated with the VPS on the Go App? I would definitely report this to DJI and send in your logs files. Is all of the FW up to date? Maybe they had some last minute fixes ?
Rich
2017-1-1
Rschutte3
Donnie- problem with hand catching is the gear is stuck in travel mode, giving you very little room to grab without props in your fingers. My ninja reflexes are not that good.
Rich- I did not do a full software check. I did check the app when I turned the craft on, the inspire and controller and camera were ready to go.
2017-1-2
What's the color of the light blinking when you click the power button for five times?
2017-1-2
RichJ53
Rschutte3 Posted at 2017-1-2 09:48
Rschutte3,
Maybe you can take a screen shot of the FW for us or video showing the problem (if it still exists)
I do not doubt your Go App was ready to go, I was only curious if the new  FW could fix this?
Rich
2017-1-2
fans408026e9
I had the exact same happen to me on two flights.... out of 4... The first flight it was coming back from a critical bat landing and then the landing gear was stuck half way when it landed on the camera.  I put it back into the air immediately and cycled the switch until it finally worked.  Then the second time it came down but did the same thing resulting in a minor crash where it flipped upside down.   I also find it disturbing that the aircraft will not auto shut off when it knows it is at an improper flight angle.  I had to  wait till all the blades exploded away to safely approach it to turn it off.  NON of the controls shut off the motors I had to pull the battery out.
2017-1-14
Donnie Stugots
That is why I added this caveat   ,"only if you have the skill and reflexes as well. " I knew it was not going to work for everyone .  What an awful dilemma to be in , I have never had it happen personally where the gear would not come down .
donnie
2017-1-14
Donnie Stugots
fans408026e9 Posted at 2017-1-14 06:03
If you  are having this happen 50% of the time and there is no obvious solution I would send it back in for evaluation .  Explain what happened , maybe if  they see it as a bind in the worm gear for the Landing gear they will get you some new props or replace anything else that was damaged.
Did you try and do the CSC  ( combined Stick Command ) to turn off the machine because it was an emergency ?  IF this is an Inspire 2 I think you push the Home  button as well as lowering the Left stick to full OFF.  Inspire 1 just uses the standard full sticks in or out .  Like the starting procedure .
*The improper angle shut off would be a tough one to implement. I for one would LOVE to see a covered flip Momentary switch for starting and stopping the motors. I had no trouble with this feature on my Yuneec Products.   Being covered would eliminate any accidental engagement .
good luck
donnie
2017-1-14
fans408026e9
Donnie Stugots Posted at 2017-1-14 06:22
Yes I have sent it in for repair and hopefully they will cover it seeing as it was only my 4th flight in 2 days.  But I mean it was upside down.. and just spinning on the ground.  Surely it can sense this and should shut off.  I would think anything over 45 degrees would be unable to fly and should be the emergency cutoff.  I used to have a toy parrot drone and it had this safety feature. If it went beyond a certain angle it would shut off and also if anything touched the blades it would shut off.  I can just think of it falling and cutting someone... Non of the controller commands stopped the motors I had to wait till they broke away and was able to pick it up to pull the battery. Not even hitting the main power button did anything.  Def should be more documents on what to do in an emergency.   Maybe even an emergency button on the app to swipe twice or something....
2017-1-14
michael.michael
Flight distance : 935 ft
This happened to me today. It went into travel mode and refused to come out. After around 10 tries the landing gear finally went down. I tried it again 20 minutes later and it worked fine. Pretty scary,
trying to figure out how to catch it and shut off the motors by myself...
2017-1-14
fans408026e9
michael.michael Posted at 2017-1-14 16:24
I am kinda glad this is happening to more people and it wasn't just me.  Hopefully they will fix my damage.  Good luck
2017-1-14
fanse5656c17
Flight distance : 435052 ft
Yes, this happened to me as well....
2017-1-14
GabeZ
Flight distance : 768448 ft
If I recall correctly, I think the Inspire 1 had the same problem and it was a VPS adjustment in the firmware.  I'll look out for this when I fly mine.  Just for my own piece of mind, did the aircraft ever touch down and then raise the legs back up to midway point (travel mode)?  If so, it's going to be harder to safely land.
2017-1-14
fans408026e9
GabeZ Posted at 2017-1-14 21:25
Mine landed on the gimbal twice.  Both with auto land on.  It seems to me like the sensor is getting bad readings as it would go -feet after it touched down.
2017-1-15
Alastair
Flight distance : 96631 ft
RichJ53 Posted at 2017-1-1 13:58
Rich
After all the issues we had with the I1...I'm not surprised
2017-1-15
Donnie Stugots
fans408026e9 Posted at 2017-1-15 00:45
Is the VPS giving good data on the go app main screen from 10 feet and below ?  If it is not then that would indicate where the problem is .
donnie
2017-1-15
Mike-the-cat
Flight distance : 22488593 ft
Rschutte3 Posted at 2016-12-31 06:51
Normally, if you keep lowering power and the VPS senses ground (snow or a non-patterned surface could be a problem), it shuts off, you get a warning message and then the landing gear lowers.  I have not had problems with my I2 but have flown only a limited number of times.
When I hand caught yesterday, the gear did not come down as it usually does on the I1 when one brings the bird close to the ground. As such, I think there is some tweaking to do with the thresholds for gear lowering.
If you cannot lower the gear by flipping the switch, raise it and then lower it again. This always works.
2017-1-15
RichJ53
Alastair Posted at 2017-1-15 05:52
I understand things can happen but this is not DJI first transforming design... How the heck did this get out of the factory? Did the latest FW update cause the problem?
I am shocked
All the best
Rich
2017-1-15
RichJ53
Mike-the-cat Posted at 2017-1-15 19:28
Or turn off the VPS altogether for now until DJI comes up with a FW fix
Rich
2017-1-15
joejoe
Flight distance : 194003 ft
I had the issue, too.
(no way to lower the gear, had to catch it)
Also posted it again to make aware of it:
http://forum.dji.com/thread-80918-1-1.html
2017-1-17
DJI-Jamie
Flight distance : 112405 ft
joejoe Posted at 2017-1-17 09:18
I responded to you on your own thread.
2017-1-17
DJI-Jamie
For those of you that had issues, what kind of surfaces were you trying to land on? Have you tried calibrating the sensors in the Assistant 2 software?
2017-1-17
Kankles
Flight distance : 3963865 ft
Come on ya'll.  Remember the 3 month rule with all DJI products  (as in wait 3 months for all of the problems to be fixed, then buy it).
2017-1-17
fans408026e9
DJI-Jamie Posted at 2017-1-17 23:34
Normal flat black rooftop... Plenty of light and texture.. The ultasonic sensors should have no issues with this.
2017-1-18
DJI-Jamie
fans408026e9 Posted at 2017-1-18 17:51
And you are sure that the sensors are clean?
2017-1-18
