jean affreux
I found that there is an error in the last firmware of the Phantom 4 Pro. Indeed, I use micro SD of the type Scandisk Extreme Plus 32 GB, Scandisk Ultra 64 GB Lexar 633x 16 GB, Lexar 1800x 64 GB. If you try to format them with the application DJI GO 4, it is unable to format them ... So they are not usable ... If you still try to format them with a software under windows (Format) Or other applications like rufus, SDFormatter, Fast32FormaterEN, etc ... these are declared in error and always impossible to use them ... The only remedy that I found is to use the application DJI GO for Phantom 3 Pro . Indeed, all these micro SD cards are recognized and you can very well format them from this application. After having bet on the Phantom 4 Pro, these work very well, except the Lexar 1800x 64 GB (I think this is due to the additional connectors that are on this micro SD).
To complete the analysis, here is the information that is bet on the micro SD when formatted:
First 2 directory:
DCIM
MISC
In DCIM 1 directory:
100MEDIA (empty and read-only)
In MISC 4 directories:
IDX (read-only)
LOG (empty and read only)
THM (empty and read only)
XCODE (empty and read only)
In IDX, 4 files:
Idx00
Idx01
Idx10
Idx11
If the developers did something to correct this anomaly, it would be very good (something that is easy ...).
After testing, to format a Micro SD card, just format it with Windows (If it is 32 GB or 16 GB, it will be formatted in FAT32, if it is in 64 GB it will be exFAT), Then to add a directory DCIM (empty) and at the time of the initialization of the Phantom 4 pro, the complementary directories will be created ... and you will be able to use your micro SD.
Best regards |
