Horrible Range
899 8 2017-2-5
formentera
Since i updated to DJI GO 3.1.2 and the corresponding FW-updates, the range is no longer bearable.
After the unavoidable FLY AWAY with 3.1.2 (discribed here: http://forum.dji.com/thread-81594-1-1.html), i tried 2.9.1 and 3.1.1, which removed the jumping homepoint issue.
But the range is still horrible ! I can't fly any further than 120m  anymore.
And it does not depend on the DJI GO app.
I am going to send it back to DJI  - i am pretty fed up now.
I want it back with the same functionality as when i bought it 6 weeks ago.
Here are some examples:
2.1.9
https://dl.dropboxusercontent.com/u/14071236/Phantom%20Marek/XX291.mp4
3.1.1
https://dl.dropboxusercontent.com/u/14071236/Phantom%20Marek/XX311.mp4
2017-2-5
Darrel1987
I'm having this issue too! This morning was fine but took out this evening and seems to loose connection
2017-2-5
DroneGuy96
Flight distance : 8127 ft
I had the same issue until I downgraded the FW on my drone, I no longer have the range problem anymore!
2017-2-5
blackcrusader
Flight distance : 689774 ft
Taiwan
I have latest firmware and 3.1.2 Go App and I have no issues.
However I did a gimble and IMU calibration after firmware upgrade.     This from a flight I did yesterday
2017-2-5
DJI Natalia
Sorry to hear about the issue.
May I know what mobile device you used to connect the remote?
Just to clarify, you mean RC signal lost or image transmission lost when it reaches to 120m?
Please try to link the remote to aircraft again and adjust antenna during flight.
And fly it farther then higher.
2017-2-6
formentera
DJI Natalia Posted at 2017-2-6 02:32
Hi Natalia,
i have a Nexus7- 2nd Gen.
As you can see in my Videos above, the image transmission is good and stable all the time.
But the RC signal gets lost and AC performs a RTH.
I did relinking a few times and i know how to position an antenna.
This has nothing to do with this "lost signal issue" since the last FW updates.
In the videos above i did not fly high - only RTH was high with 50m.
2017-2-6
jda407FL
I'm having a similar issue with version 3.1.4 and my iPhone 6.  cannot get beyond 1100 feet.  ugh
2017-2-6
DJI Natalia
formentera Posted at 2017-2-6 03:40
Hi Natalia,
In that case, it would be best to send it in, our engineers will help you evaluate it and test the performance.
Sorry for the inconvenience caused. You can contact our tech support via support.eu@dji.com for a case number, and you will get an e-mail with the details.
2017-2-7
PauloHenrique
i have a Samsung Galaxy S7.
I'm having a similar issue:
Yhe image transmission is good and stable all the time.
This has nothing to do with this "lost signal issue" since activation.
only RTH was high with ~120m.
2017-2-7
