patou72
Flight distance : 3316614 ft
Electro-Nick Posted at 2017-2-16 11:04
Ok, did a bit of testing today, the "problem" arises when the setting 'Gimbal Yaw Smoothness in Follow Mode' is changed from 0. If you set to something like 40, then you start to see this behaviour, if you set to 100, then the aircraft pretty much refuses any yaw stick commands at all.
If you've set your settings so you get the slow response and find the aircraft carries on turning after you've let go of the sticks and you need to stop it, you can stop it instantly by flicking over to atti mode.
Hello Elektro-Nick,
Thanks for your help, today i tested the settings with the "gimbal Yaw smoothness" and it is exactly as you said.
So after all this time everything works as it should. Always wondering what's the need of this... and a little bit surprised that nobody from the official DJI team could give a valid answer or chime in to give some support.
By the way this option should be called "Aircraft Yaw smoothness".
Thanks again
Patrick |
