Horizon tilt (yeah, how original...)
12345678Next >
21727 298 2017-4-23
betonven
Well, I don't know what to say anymore.
I received my second replacement (so third bird) Phantom 4 Pro. This one doesn't have the horrible vibrating gimbal of the previous one, doesn't give critical errors, doesn't fry while charging, so yeayyyyy! Well, no: in that, the horizon tilt is just INTOLERABLE. You cannot work with it. It starts tilted, it takes a few minutes to get it well, either by pressing C2 (works only some times) or also having to constantly rotate the dial. The green lines (horizontal-vertical) appear on the screen, but it literally doesn't tilt the way you want. And even if you manage to do that, after couple of minutes trying, don't get too excited, after a few seconds it starts to tilt away again, sometimes even without turning. It's like it's balance point is somewhere completely off the horizontal. I was aware of the horizon tilt, I had it in both of my previous birds, but nothing that bad, I had learnt to live with it. Here, it is just terrible.
I've done IMU calibration, I've done several gimbal calibrations, but hey, no luck.
I don't know what to say, I've never experienced that before, getting three problematic pieces in a row, each with different issues. I'm returing that for a full refund, and I'm probably done with the drone game for now. Sadly, I'm stuck with ~ 300$ of accessories, and that assuming that DJI will accept to give me a partial refund for the Care & Refresh I bought in the beginning, when I thought I was buying an impressive piece of technology and wanted to get the most of it with my peace of mind.
Any ideas/suggestions? Sorry but my time is not enough to hold on the line for 3 hours to talk to somebody that usually doesn't even know what he's talking about...
2017-4-23
DJI Natalia
We do understand that is really frustrating for you, sincerely sorry for your experience.
If you have not returned it, could you please cool the drone for about 30 minutes firstly, then put it in a very level surface, insert the battery, power it on and start to calibrate IMU as quick as possible, then calibrate gimbal and adjust Roll?
2017-4-23
betonven
DJI Natalia Posted at 2017-4-23 23:47
Natalia, I did an IMU calibration as soon as I unboxed it. However, probably the bird was not 'cold' as there was a firmware update before. I'll try what you suggested, even though I'm not very confident.
Also, what's this thing about C2 button? Why does it only work 1 out of 3 times I press it to level?
2017-4-24
Eric13
Flight distance : 15515515 ft
Yes - it is a major problem for many. No need for me to repeat myself here, I mentioned it often.
Now here is something I realized and I would be interested if someone else experiences this.
I have always tilted horizon - but not when facing West. It goes from North through East to South.
As soon as I turn from North or South towards West it levels.
2017-4-24
dronist
betonven Posted at 2017-4-24 07:14
Put the drone in a cool place outside at night for 30 minutes  or if you are in a warm area stick in the the fridge.
Take out, fire up DO NOT UPDATE,  stay away from any metal etc., do the IMU on a 100% leveled surface. then shut/ restart and again DO NOT UPDATE, then do the AUTO Gimbal Calibration. Shut / restart and do the upgrade.
Do the upgrade using the app. let us know.
SAFETY FIRST - FUN SECOND
2017-4-24
betonven
dronist Posted at 2017-4-24 14:21
Put it in the fridge???  Is that for real???
I've already done all updates since the unboxing. Are you suggesting to downgrade?
2017-4-24
betonven
Sorry - double post!
2017-4-24
dronist
betonven Posted at 2017-4-24 14:29
Yes for real!...
And if you already upgraded and you don't have any issue or error from the upgrade that do everything else
2017-4-24
dronist
No worry... Am not counting...
2017-4-24
lienbacher
Flight distance : 1068337 ft
Austria
Dear Natalia,
since I am suffering the very same Problem and my drone was just next to me and cold when I read this, I decided to just give it a try. Switch it on, as soon as possible to into sensors menu and choose calibrate IMU. There was absolutely no change in the horizon issue.
Natalia, since I'm sure you have a P4P yourself, can you try this with your unit: put it on level ground facing a wall perpendicular so all lines are straight, switch it on, confirm the lines are straight on your screen. Now slowly tilt the drone to the left (so it would stand on only one skid) for about 30 degrees and watch the screen. I am very certain you will notice the camera tilting to the right. Now tilt the drone to the right, you will be able to watch the lines rotate to the left. If you put the drone back level, it will slowly go back level.
Please report back about your findings. Your help is very much appreciated!
2017-4-25
DJI Natalia
Please have a try and keep us posted. If still the same case, please provide me your DJI account, you can try to PM me, thanks.For C2 button, you notice that each time you press it?
2017-4-25
DJI Natalia
lienbacher Posted at 2017-4-25 00:28
Dear Natalia,
For horizon issue, could you please provide me your DJI account (an e-mail address).
For the situation you described, we'll have a try tomorrow and get back to you.
2017-4-25
betonven
DJI Natalia Posted at 2017-4-25 03:05
I will as soon as I get some free time.
Can you please comment on the "put the Phantom in the fridge if you don't have access to cold weather"? I'm just worried whether it will be wise to power on the drone after it has been in the fridge (with condensation on the circuits, etc.).
2017-4-25
betonven
I did some research online about why the "COLD" is needed in IMU calibration and I understood that this is something that would help your drone to warm up faster after you turn it on. I don't have any issue like that, do I still need to go through a "fridge" cold calibration for my horizon issue?
2017-4-25
Eric13
The fridge thing is not a recommendation by DJI. Some users think its a good idea.
I wouldn't do it. When it comes out the sudden rise in temperature can result in condensation (fogging).
Especially in regions with high humidity.
Instant temperature changes should always be avoided for cameras/lenses/electronic equipment.
2017-4-25
SM-17
Flight distance : 179288 ft
@eric13
Agreed 100% there are long term consequences to electronics.
2017-4-25
betonven
Yeah, that's what I thought. I prefer not to mess with anything. I'll do the calibration with the bird turned off and without a battery for 3 days, that's "cold" enough.
2017-4-25
Eric13
Well - the bird must be turned on for the calibration.  But you want to start right after it's on.
If you use a smartphone level app remember that the app itself must be cailbrated before - on a leveled surface.
I prefer a classic level over an app. Also because my smart phone is not completely flat on its rear side.
2017-4-25
betonven
Eric13 Posted at 2017-4-25 14:09
Haha of course, excuse my terrible English, how could I calibrate with the Phantom turned off?
I also have an actual level, I'd never trust a phone for that, for the same reason I cannot trust the Phantom
2017-4-25
bassistas
Flight distance : 355377 ft
Hello guys, I recently purchased a phantom 4 pro new from Amazon but I have the camera shake problem and the tilted horizon which is kinda fixed with the adjust gimbal roll function. Is my P4Pro faulty or it can be fixed with a proper calibration?
2017-4-25
DJI Natalia
betonven Posted at 2017-4-25 07:29
You can put it in a room with air condition.
Besides, what your DJI account? can you PM me so we can provide you a firmware for upgrading? which may help for horizon issue.
2017-4-25
SM-17
Malta
@DJI Natalia
Since i am getting horizon issues as well with all calibrations done. Can you assist with a firmware to test. My mail is the same used on this forum
2017-4-25
DJI Natalia
Dear Natalia,
I just got your message, sorry PM does not function well sometimes.
I've transferred your account to the engineers, please check it later, thanks.
2017-4-26
DJI Natalia
SM-17 Posted at 2017-4-25 23:51
@DJI Natalia
I failed to get your e-mail, maybe a system issue, can you please try to PM me? thank you.
2017-4-26
DJI Natalia
Dear Natalia,
It has been done, please check it again and upgrade it.
Waiting to hear back from you for the performance after upgrading, thanks.
2017-4-26
SM-17
Thanks dji Natalia
I sent you pm with my email
Will i be able to downgrade to the current released version if needed?
Thanks a lot
2017-4-26
lienbacher
Austria
DJI Natalia Posted at 2017-4-26 02:26
Thank you Natalia!
Just installed, rebooted and tilted the drone. I'm a little bit stunned, the horizon seems to be rock steady level with the indoor test I described earlier - put drone on ground with horizontal lines visible, tilt drone till shortly before gimbal limit, lines stay absolutely straight and I took my time to look for horizon shift!
I also did a short test flight outdoors. Full stick deflection left and right in P-Mode and Horizon stays rock solid.
This is truly amazing and very relieving for a horizon-pedant like me. This is fix is extremely appreciated!!
2017-4-26
betonven
DJI Natalia Posted at 2017-4-25 22:47
Thanks Natalia, I sent you my account with Personal Message.
2017-4-26
Floreto
Flight distance : 3591102 ft
I have the camera tilting problem as well, new P4P+ less than 5 months old, I'd send it in to be fixed but I have no confidence that it's a problem DJI can fix and I don't have 2 or 3 months to wait to find out.
2017-4-26
MassiTX
Hi there,
Looks like this horizon tilt is not just what I have faced! I got my mavic pro a week ago and it looks like my horizon tilts when rolling on left or right. Here is a picture as well.
(https://drive.google.com/file/d/ ... Gc/view?usp=sharing)
I guess I have the latest firmware as I updated it a week ago. Any help or idea?
2017-4-26
lienbacher
Austria
Floreto Posted at 2017-4-26 09:20
Don't send it in Floreto. Seems there is help on the way with the next update!
2017-4-26
lienbacher
Austria
MassiTX Posted at 2017-4-26 11:17
Hi there,
You may want to post this in the Mavic forum, not the Phantom 4 Pro forum ...
2017-4-26
Floreto
lienbacher Posted at 2017-4-26 12:25
That would be welcome as correcting it in post really isn't a solution I want to continue using.
2017-4-26
SM-17
Malta
DJI Natalia Posted at 2017-4-26 01:08
@DJI Natalia,
PM with my email sent Sent.
2017-4-26
Indio
Flight distance : 303373 ft
Austria
same problem :- (
2017-4-26
UltraDan
Natalia, please can you send me the horizon firmware update fix please !! I will pm you my email, thanks, Dan.
2017-4-27
UltraDan
How do I Pm you Natalia?
2017-4-27
betonven
@DJI Natalia
Still haven't received anything.
2017-4-27
betonven
UltraDan Posted at 2017-4-27 05:26
Click on the "Personal Message" tab below her name in one of her posts. It will popup a window and you can write there.
2017-4-27
Mobilcams
Flight distance : 2907674 ft
Wait.. So you got a firmware update that isn't available to the public yet and it actually fixes the horizon tilt issue?????????
2017-4-27
12345678Next >
