Flickering in video
7364 31 2017-5-3
Craignos
Flight distance : 5574954 ft
Hi all,
I recorded a UHD video at 30fps at Dusk: picture 1/3 blue-pink sky, 2/3 trees-house. The lower 2/3 with the tress-house is darker than the sky obviously and really reveals the flickering caused by the video encoding GOP, where the image flickers every 8 frames.
Searching on YouTube it seems the issue is well known, and the solution is buying a denoiser or anti-flickering plugin for about $150.
I'm turning to you, DJI, to find out if there's a way to not have this issue?
The video settings were:
3840x2160 30p in Cinelike, AWB, sharp+1, Cont-1, Sat-1, shutter at around 1/120th, ISO100, no filter on lens.
Latest firmware installed.
Thanks!
2017-5-3
dronist
Post a video/pictures so we may be able to help!
2017-5-3
Could you please upload some original videos to dropbox or google drive?
We will help to check it.
2017-5-3
Anoniem
Flight distance : 70043 ft
Indeed this is well known and related to the choice of DJI to use H.264, allot of people are complaining about the quality of video.
Besides this problem, the Mavic is not capable to perform a decent Noise reduction, it creates blurred parts in the image.
Solution:
-Improve noise reduction within the Mavic
-selectable sharpness AND selectable noise reduction
OR
DJI should at least make an effort to supply a decent tool to take away the noise that comes with the intra frame and to minimise noise from the sensor.
By the way, if you would buy neatvideo open FX this is much more expensive than 150 dollar(to be used with Davinci resolve for example).
2017-5-3
Anoniem
double post
2017-5-3
Anoniem
DJI Mindy Posted at 2017-5-3 19:34
Hi Mindy,,
It's not about a defect, it about a choise DJI did make with the design.
And allot of your consumers are not happy with the Noise reduction that the Mavic capable is of.
DJI can improve if they are serious about listening to complaints and trying to understand.
Please read my other post to understand what this is about.
Or google: Mavic flickering
You'll be able to find allot of complaint of DJI customers on youtube, not a very good advertising I guess.
2017-5-3
Anoniem
Posted reply to your topic above
2017-5-3
jpap
Flight distance : 1780679 ft
I am having the same issues. I hope DJI could either fix this or somebody could provide an alternative workaround that does not cost 150USD!!!!
2017-5-4
Anoniem
jpap Posted at 2017-5-4 00:24
Hello jpap,
DJI should take this information with open arms, it is not a problem to be stuck with it is a opportunity to do something essential that allot of people will appreciate.
We need DJI to step up and show some appreciation to their customers.
And also might repair their own imago.
2017-5-4
jpap
I am not pessimistic, but the fact that this problem exists in the selected codec, which is also used by other drones (like Phantom series) does not allow enough room for me to believe that this could be solved by DJI any time soon.
However, it would be a great move for them to show their appreciation and that they listen to their customers if they decide to help us
2017-5-4
Anoniem Posted at 2017-5-3 23:17
Hi Mindy,,
I have forwarded this to our engineers for review.
Thank you for your feedback.
2017-5-4
Anoniem
DJI Mindy Posted at 2017-5-4 22:46
Hi Mindy, thank you for your feedback I appreciate your gesture.
2017-5-4
Irmantast
I am using neat video with adobe premiere pro, all issues witch flickering is now a history.. p.s. neat video is much better than denoiser III.
2017-5-5
ReinisK
Flight distance : 21946 ft
Latvia
Hey, Irmantast! Would you mind sharing your neat video settings? I've also tried Neat video for this, but cannot get it right, flickering is still there.
2017-5-8
DJI_camera
thanks for your feedback and we are now testing and optimizing this issue, pls pay attention to our update.
2017-5-8
jpap
Could somebody from DJI provide a status update to this issue?
Many Thanks in advance
2017-5-17
Reznor99
Flight distance : 98855 ft
jpap Posted at 2017-5-17 03:22
Right! The pulsing in my videos with the sharpness turned up is driving me nuts.  With the sharpness turned down the muddy video is just as distracting.
2017-5-17
Craignos
I concur with Anoniem, I appreciate DJI following up with this. Which is really the only grain of sand in the machine as for the rest, it is such a great UAV!
And I'm sorry I haven't posted a sample video yet, but I will this evening!
I am not sure how this can be solved really without changing the type of video encoding...
2017-5-29
jpap
Hi Mindy,
any feedback from the engineering department?
Here is another video with flickering. Not sure if this is a different issue or related to the one discussed here.
2017-5-29
Craignos
Mindy, the sample video can be found here:
https://www.dropbox.com/s/krclnd ... le%20video.mov?dl=0
Look at the bottom darker area of the video, and open it in Premiere or FCP with the vectorscope, you'll notice the obvious jump every 8 frames!
2017-5-30
Craignos
Here's a good explainantion of what's happening with the flickering, and what this guy does to remove it.
But it would be nice if DJI could fix it with a firmware update! (not sure how though since it seems to be a H264 issue...)
2017-6-7
nomnomnom
Flight distance : 8343 ft
How do you remove it? It's still a problem and even paying for neat video is not enough, there's no easy way to create a good profile. Some guy did it but he wants to sell it. Craignos did you figure it out?
2017-7-25
fansb8b222f3
Flight distance : 74213 ft
Any update on this ?
Its not cool to adv 4k support and then to find out it not up to expected standard.
2017-7-27
Craignos
nomnomnom Posted at 2017-7-25 10:37
neat video will remove the flickering, and that's it. And I haven't purchased that plugin by the way, so I don't have a fix really to that issue. I hope that with h265 (coming up in Mac OS High Sierra) we could see an improvement, not sure if the Mavic will be upgraded to support that codec either?
2017-8-10
kubais_ex_mach
Flight distance : 240801 ft
Czechia
I just spent 3 days editing dozens of Mavic videos I took in a span of whole year and I have to say that video quality is total rubbish. Noisy, pulsating light every 8th frame, insufficient bitrate. When I compare it to my $100 action cam (Firefly 8s- same sensor size like Mavic) with special script that almost doubles the bitrate - 1080/60 at 80Mbps, 2k/60 at 90 and 4k/30 at 110Mbps, Mavic´s video quality is just sight for sore eyes in comparison.
I am aware you can use denoise and  to clean out the pulsation somehow in post, but that is so much of a job that I am simply not willing to do that, especially with so many videos. I just wish DJI at least managed by simple firmware upgrade to up bitrates and made the real 1080/60.
2018-1-20
djiuser_GmIKOrD
Flight distance : 118 ft
Any news here? I just unpacked the Mavic Pro, tried it for the first time and 4k@24fps +1, -1, -1 looks crap... I'm thinking about returning it right away.
2018-1-23
Craignos
djiuser_GmIKOrD Posted at 2018-1-23 08:57
Maybe the Mavic Air allows to shoot in H265, with better results?
Sorry to see you're that disappointed. It is mainly an issue in low light on the Mavic Pro.
2018-1-23
djiuser_GmIKOrD
Craignos Posted at 2018-1-23 09:07
Maybe but check this one out. Not a low light situation. It looks like there is noise following the whole scene.
You know any better settings?
2018-1-23
Craignos
djiuser_GmIKOrD Posted at 2018-1-23 10:44
https://youtu.be/J9XE_jYkjRE
Looks fine to me! I actually don't see the flickering, but just the H264 compression on your quick pans.
2018-1-23
aftersun
I think it looks like there is a noise following the entire video and it's more visible when panning.
2018-1-23
aftersun
Have you found out which settings that creates least amount of flickering and noise?
2018-1-23
Craignos
aftersun Posted at 2018-1-23 13:43
I usually don't touch the picture settings: contrast, sharpness or saturation.
2018-1-24
