EV not working in manual
4325 13 2017-1-5
Nil73
Mexico
Is anyone having any issues with the EV when the camera is in manual mode.. Mine changes to M.M and is only affected by the ISO dial..
2017-1-5
DJI Natalia
It's normal, when in manual mode, the EV value will be changed automatically after you change the ISO value and shutter value.
While you can change EV value in auto mode, then shutter and ISO value will be changed according to the EV value.
2017-1-6
Nil73
Mexico
DJI Natalia Posted at 2017-1-6 00:29
No its not normal.. If you had read my explanation.. When I go into Maunal mode on the camera. The EV changes to M.M.. (what is this ??? )  The M.M does not change automatically to give the exposure.. It is only affected by changing the ISO value..  I am using the new P4P+ with the crystal remote..  Is this a firmware problem..? Please if you are going to offer advice read what the problem is before you reply..
2017-1-6
DJI Natalia
Nil73 Posted at 2017-1-6 05:43
https://youtu.be/ejhVog8qlKk
Correct, when in manual mode, the EV value will be changed according to the ISO and shutter value.
Sorry for any confusion caused.
2017-1-8
Nil73
Mexico
DJI Natalia Posted at 2017-1-8 02:10
Do you actually read what I have written.. or watch the video.. I think not.  You have made no mention of M.M, and keep reffering to Ev.. watch the video you will see M.M NOT EV.. and also that when I move the shutter the M.M doesn't change.
Shouldn't the EV /M.M be metering the ambient light, as all proffesional cameras do.. including my Phantom 3 pro, This drone does not do that.. In fact the M.M on my drone tells you nothing....!! Again please watch the video and read what I have written before you try and offer some help... !!
2017-1-8
Nil73 Posted at 2017-1-8 02:25
I think what Natalia is trying to tell you, once you are in Manual mode EV changes automatically to MM I presume meaning Manual mode, she is telling you exposure value in manual mode or metering mode only changes when you change the ISO .
Weather this is correct or not I think this is what she is trying to say.
You can use the wave to see this.
2017-1-8
Hendo
Flight distance : 104495 ft
Wow man, have some patience and manners! Just because Natalia didn't pick up your meaning first off, you don't need to start ranting. She is just trying to help. Also consider there is possibly an English translation issue here too.
2017-1-8
Nil73
Mexico
Hendo Posted at 2017-1-8 03:20
Hendo.... back off
It is nothing personal, but you have to understand I got this drone less than a week ago, I am on a job with it. And I am having constant issues. When I ask for explanations and help I get answers that seem computer generated and do not actually answer any of my questions!
Over 2000 USD spent and so far it's rubbish! I would just like some serious effort on the part of DJI, thank you.
2017-1-8
Nil73 Posted at 2017-1-8 10:05
Hendo.... back off
I think you don't understand the answers, that's a problem, I think Hendo was trying to point out to you with a bit of decorum you might get the answers you seek..
2017-1-8
Hendo
hallmark007 Posted at 2017-1-8 12:06
Exactly my point.
2017-1-8
Hendo.... back off
It might also help if you could explain what the issue is.
I'm an english-speaking photographer and I've read it three times and it's still unclear.
My best guess is that you don't understand camera controls and should get out of manual mode.
2017-1-8
fans72daf448
Flight distance : 771811 ft
I understand your problem. I always shoot in manual mode & have used the ev value to see if I have correct exposure. This no longer is working. Has anyone found a fix or this how it will be from now on.
2017-2-7
fans72daf448
2017-2-7
SimCab
Flight distance : 1004498 ft
If it worked as expected M.M. should give an evaluation of the exposition manually selected. But it seems not coherent with this
2017-6-17
