Link RC before each flight?
2779 17 2017-6-22
JDAVIS21
Do I have to do the link/pairing procedure each time between the RC and the Spark?? I've had to link it every time so far, even though the manual says they are linked from the factory.
2017-6-22
gottorock
Flight distance : 4012 ft
yes you do
2017-6-22
J Beaker
Flight distance : 203 ft
No.  The only time i've had to link the RC with the Spark is when I fly the Spark without the RC.  I've gone hours/days between RC flights and never had to link the RC with the Spark.
2017-6-22
FFS
Flight distance : 50003 ft
J Beaker Posted at 2017-6-22 19:20
You seem to have gotten lucky because most reports on this forum including my own experience is that you must relink every time you reboot the machine.
2017-6-22
Buzzyone
Flight distance : 4647913 ft
FFS Posted at 2017-6-22 19:33
Not here, never had to link the RC to the drone, apart from when I unlinked it to fly it phone only mode. Re linked after and it has stayed linked.
When you power on it can take 20 or 30 seconds to connect to the remote, are you giving it long enough to connect?
2017-6-22
gottorock
when I called DJI they told me you have to relink after turning it off
2017-6-23
Tviscomi
Flight distance : 106886 ft
gottorock Posted at 2017-6-23 11:47
Are you sure that you asked the right question to DJI?  I've never had to re-link my RC
2017-6-23
gottorock
Tviscomi Posted at 2017-6-23 11:51
yea so I'm having the issue  if I even able to  pair my RC and I fly it to the point where its time change batteries I will not be able to use the controller again it does I called and they said yes I have to do it every time I turn it off
2017-6-23
Tviscomi
gottorock Posted at 2017-6-23 12:37
I would probably try talking to them (DJI) because you should NOT have to pair the RC to the Spark each time you fly.
2017-6-23
gottorock
Tviscomi Posted at 2017-6-23 12:45
well they think my RC is broken anyways it won't pair now
2017-6-23
Tviscomi
gottorock Posted at 2017-6-23 12:49
Read page 38 in the owners manual:
https://dl.djicdn.com/downloads/ ... ser+Manual+V1.0.pdf
2017-6-23
gottorock
Tviscomi Posted at 2017-6-23 12:51
https://dl.djicdn.com/downloads/Spark/20170527/Spark+User+Manual+V1.0.pdf
yea I have already looked and followed the instructions. but it just keeps beeping
2017-6-23
gottorock
I just found out even tho it doesn't pair i see the GPS location for it
2017-6-23
Corrupt ID
Flight distance : 49531 ft
Never had to relink before each use. I turn the remote on then the spark. The sparks flashes yellow at start up till it self links. If you are having to rebind each use make sure to turn the RC on first then the drone, if it continues contact support for a possible replacement.
2017-6-23
gottorock
Corrupt ID Posted at 2017-6-23 13:19
they want to try to fix it first they won't send me a new one.
2017-6-23
Tviscomi
gottorock Posted at 2017-6-23 13:41
So first they (DJI) tell you that its normal to relink each time and now they say it's an issue...omg.
2017-6-23
zguy
Flight distance : 243796 ft
How long does it take to link?  Mine is 25-30 sec.  Seems long.
2017-6-23
Birdyflymore
Flight distance : 57287 ft
zguy Posted at 2017-6-23 17:21
Ive never had to relink my remote, unless i delink it from the remote controller.
2017-6-23
