DJI Phantom 4 Pro Plus V01.04.0602 Still Not Safe to Fly
2474 16 2017-6-30
Nelsonlee
Flight distance : 2779203 ft
Malaysia
This is what i personal opinion for after update the latest Aircraft Firmware : V01.04.0602, Phantom 4 Pro+ Remote Controller Firmware : V 1.2.0.0 and DJI GO 4 App Android : V 4.1.0 that DJI released on 08-June-2017.
So far after tested this firmware for me i think is still not safe to flying cause still got a lot issues even the firmware and the Go apps too, as i did mentioned this is only my opinion so i am not sure how other pilot have same issues like what i highlighted or not.
So what i try to do is downgrade back to the previous version as what DJI Assistant 2 software mentioned that if you feel not happy with this latest firmware then you can load back the previous firmware version, But now seem the DJI has removed all the previous firmware on their server!
After i connect my aircraft to DJI Assistant 2 software and only showing  Latest Firmware V01.04.0602 and the rest previous version is now gone! So DJI Support, can you guys answer me this how to i downgrade my Phantom 4 Pro Plus back to previous firmware??
I hope DJI support can give me a proper answer for this as your did mentioned before we do this firmware update can roll back to the previous firmware.
2017-6-30
Aardvark
Flight distance : 384432 ft
You could try this again without the gimbal guard fitted. These have been known in the past to produce some strange affects on altitude (ultrasonic sensors getting false readings).
2017-6-30
Nelsonlee
Malaysia
Aardvark Posted at 2017-6-30 01:45
The previous firmware am also wearing this gimbal protection and it work well, the gimbal protector does not blocked the sensor.
2017-6-30
Aardvark
Nelsonlee Posted at 2017-6-30 04:13
That may be the case here, but DJI have decided they won't cover any damage where they are fitted, have a look at a previous post I made Here
2017-6-30
Nelsonlee
Malaysia
Aardvark Posted at 2017-6-30 06:46
That may be the case here, but DJI have decided they won't cover any damage where they are fitted, have a look at a previous pot I made Here
My concern now is why their mentioned if this latest firmware you not happy then can roll back the previous version!
But now you see the DJI Assistant 2 after i connected and what i get!
Now can DJI Support answer my question?
Where's the previous firmware version now?
2017-6-30
Tmygun
Flight distance : 2972497 ft
One of the things I noticed in the video was when you calibrated the aircraft,  you calibrated during second stage with the camera facing to the left and not down at the ground.
This might cause an issue in the overall calibration.
2017-6-30
Nelsonlee
Malaysia
Tmygun Posted at 2017-6-30 09:08
I am follow what the DJI Go 4 displayed the calibration, If i did wrong then is not my fault and it's dji fault.
2017-6-30
Tmygun
Nelsonlee Posted at 2017-6-30 09:33
No............DJI displays a 2nd rotation of the aircraft with the nose/camera DOWN  not pointed  to the LEFT.
Good Luck with your issue.
2017-6-30
Klaush
Flight distance : 449219 ft
Nelsonlee Posted at 2017-6-30 07:00
I have the same problem. Where is the firmware to roll back?
2017-6-30
fansc629d008
Banned
2017-6-30
Nelsonlee
Malaysia
Please see the Go 4 app displayed us the compass calibration step photo here, if i doing wrong so is not my fault! this is what dji support what suppose they need to do!
2017-6-30
andyc57
Flight distance : 184032 ft
DJI took all the firmware offline or from the there servers except for the current ones. someone posted a video on YT showing how to Mod the DJI AC's so is going to be interested on the next firmware update. specially if you have any issues with the update cant rollback....
2017-7-1
You might have a serious problem where you took off from if concrete is rebar, you calibrated compass with remote in one hand AC in the other.
This whole thing looks like your whole preparation is so wrong including gimbal guard location and compass calibration procedure.
If you handle AC like this in same location, then you need look no further than yourself first to try to sort your problems.
2017-7-1
Landbo
Flight distance : 502792 ft
Nelsonlee Posted at 2017-6-30 17:02
Yes, unfortunately, DJI has made a mistake in their drawing since the nose of the drones and the lens should point down to the ground, which is actually in clear writing twice. Remember to put the controller and phone / tablet down to the ground at least 3 meters from you while performing the DJI compass dance. Afterwards, the compass must not be calibrated without the vessel's opening side extensively asking for a compass dance.
Regards Leif.
2017-7-1
MAQJJ
Flight distance : 75 ft
Peru
If this update does not bring anything good, for the DJI out.
2017-7-1
MAQJJ
Peru
2017-7-1
mickspawn
any idea how to downgrade if there is no other versions apart from V01.04.0602 on the dji assist software?
2017-7-1
