New firmware for Spark is Available (26/07/2017)
61751 324 2017-7-26
Phuong Do
Flight distance : 29800 ft
Vietnam
realstreetuk Posted at 2017-7-26 07:57
update for each battery? i also updated through dji assistant, there was nothing about battery firmware?
i just update with 1 full charged battery. what about my other battery?
is there a procedure i should be following. if not whats the consiquence?
The procedure for me is plug in 1st battery, upgrade firmware.
Turn off, take out that batter and plug in the 2nd battery, DJI assistant 2 will said that software conflict or something and ask you to confirm the upgrade.
After finish,Turn off and plug in the next battery
2017-7-26
Jeff7577
Flight distance : 1916821 ft
GO4 will update battery, not Assistant.
2017-7-26
fans19e5af88
Flight distance : 71109 ft
FYI - Just performed the upgrade on Spark.  Mine stuck at 97% for 15 minutes.  Power cycled the drone and DJA2 showed complete.  Swapped battery and upgrade completed fine.  Have not flown yet, but connection via OTG to remote works fine.
2017-7-26
fans19e5af88
2017-7-26
Jimmers
Flight distance : 49623 ft
My Spark and 3 batteries are all updated.  Can't wait until tomorrow to try out the new features!  Thanks DJI for the updates!
2017-7-26
Cavids
mine works fine after updates but it did not seem to update the batteries only the quad and RC.  It does work with the OTG cable, but I cannot hook wifi first or it will not do the cable
2017-7-26
Jimmers
Cavids Posted at 2017-7-26 17:46
When you put another battery in it should tell you that an inconsistent firmware is found and then you have to swipe to update the new battery.
2017-7-26
Jimmers
So....what happened to the "Voice Prompts" that the DJI Go 4 app listed?????
2017-7-26
fans909d0edb
Flight distance : 19465 ft
Matioupi Posted at 2017-7-26 11:23
Why is 4.1.4 go app still not available on google playstore everywhere ?
the firmware 4.1.4 is uploaded through the DJI go 4 app. The DJI go 4 app is not a new  app.
2017-7-26
fans909d0edb
Byrd's Loft Posted at 2017-7-26 16:34
So what's up with the 4.1.4 app not showing up in the Google play store? Do we seriously have to sideload the apk from a 3rd party source or am I doing something wrong???
there is no 4.1.4 app. the firmware is 4.1.4 downloaded through the DJI go 4 app.
2017-7-26
Byrd's Loft
Flight distance : 48320 ft
fans909d0edb Posted at 2017-7-26 18:47
What I have learned is that both the DJI Go 4 iOS and Android apps were updated to version 4.1.4.  However, the Android Go 4 4.1.4 version was pulled from the play store and 4.1.3 was put back due to issues with the 4.1.4 Android version.  I expect we will see the Android 4.1.4 version re-released soon.
The firmware that is pushed through the DJI Go 4 app is Aircraft Firmware: V 01.00.0500 and Remote Controller Firmware: V 01.00.0300
2017-7-26
PHOTOlulu
Flight distance : 952625 ft
It's the second time in two days I updated to the same 4.1.4
2017-7-26
nwhit
Flight distance : 374 ft
Updated and flew this evening. Couple issues. The video hand gesture would not work no matter what I did.  Twice a palm launch resulted in the spark moving quickly sideways about 3 ft. Selfie photo quality is much better at 4K.
2017-7-26
ix3lplix
Flight distance : 145846 ft
I updated as well. Overall, I'm happy with the improvements.
Pros
* Full resolution selfies
* Interference warning on startup (I never got these before, but I'd rather see them and be on the safe side by disabling bluetooth than lose my Spark completely)
* As someone else reported, the hand gestures appeared to be faster and more responsive
* 180 Pano results look great
* Pushing on the sticks to stop a quickshot was a nice intuitive feature
Cons
* Couldn't get video gesture to work
* Distance slider on Helix and Dronie still doesn't work
* Dronie still doesn't climb much
2017-7-26
fans205b06e5
  I successfully updated the DJI GO4 app and installed latest firmware and the test flight and gesture control for video worked well
2017-7-26
fans205b06e5
If anyone interested in how to do the gesture control for video, I have created a youtube video under my channel "TLY Rider" with the video title DJI Spark Firmware Update - Gesture for Video
2017-7-26
fans205b06e5
2017-7-26
Kidologist
Flight distance : 4415722 ft
I updated all the firmware, remote and drone, and the DJI app, but unlike some YouTube videos, while I got gimbal speed control new, I do not have the speed of drone setting in the stick control menu. Several people show that online but mine does not have it?
2017-7-26
GCBrent
Flight distance : 66286 ft
So only 4k pic if using a gesture? What about if you use the RC to take a pic???
2017-7-26
Gloops
Flight distance : 33789 ft
Luxembourg
fanse800398f Posted at 2017-7-26 16:16
Anyone elsehave problem with sync flight records? I have tried 3phones but it gets stuck at 67% and never completes the sync, it seems it is still not addressed in this updates
I had also the impression that the update was stuck at 97% without succes but It's not.
You need to wait patiently. After a (long) while the Spark will restart automatically and your battery will be updated. You need to repeat  this for every battery you have.
2017-7-26
ebo974
Flight distance : 83730 ft
Réunion
Byrd's Loft did you got the application update yet?
I updated the RC, AC and all my batteries... but I still waiting now for the Dji Go App update... For android device, S8+. Living in Reunion Island.
Any word on that point Dji members please?
2017-7-26
fanse4e12300
Updated today.
Gesture feels worse
No climbing in dronie
Selfie still looks 1080
2017-7-26
PHOTOlulu
Dronie still doesn't ascend when flying out
2017-7-26
fans3e685982
Flight distance : 482520 ft
Video activation for Gesture does not trigger (did multiple re-install of firmware) 3 different battery tests of gesture for video recording in 2 different lighting conditions.
Dronie does not ascend above 10 feet when slider is at minimum or while slider is at maximum. (while using iphone 6s as controller)
Tap to Fly now has a speed slider that does work while using the controller.
Controller wifi to phone connection is near unusable without a OTG wired connection.
THis update seems to have broken more features than it has fixed.
2017-7-26
PhLi
Flight distance : 81814 ft
Can´t update the app in Europe with android!
2017-7-26
PhLi
2017-7-26
Scotty S
Flight distance : 182884 ft
No updated Android app in Australia.....
Any mods online to comment?
EDIT: Nevermind... saw the other thread...  1st August apparently.
2017-7-26
Borat
Flight distance : 127487 ft
Kyokushin Posted at 2017-7-26 08:51
What is europe wifi bug?
The fact that in europe, you have to reset the wifi network ( press 9sec on the spark) everytime you want to connect your drone to your phone...
see this thread https://forum.dji.com/forum.php? ... D436%26typeid%3D436
2017-7-26
fans8400443d
South Korea
tried video gesture with spark only. (no smartphone/RC)  1. normally video works fine  2. doesn't work during "Away and Follow mode" which is very important. I usually takes video using active track, but gesture video seems like it doesn't support active track.. so dissapointed
2017-7-27
Tommy Vu
Flight distance : 4564 ft
Vietnam
fans205b06e5 Posted at 2017-7-26 19:57
If anyone interested in how to do the gesture control for video, I have created a youtube video under my channel "TLY Rider" with the video title DJI Spark Firmware Update - Gesture for Video Youtube video here
Have you tried activating Active Track by hand gesture "Y" BEFORE or AFTER performing video record by hand gesture ?
My Spark cannot recognize Active Track by hand gesture anymore from this firmware version despite it 's able to perform video recording by Hand gesture perfectly.
2017-7-27
JP Santos
Flight distance : 116929 ft
Portugal
First Demo:
-Made the FW upgrade and last DJI GO app (IOS 4.1.4)
-I think is more stable in gesture mode
-Cant make movie gesture to work
-Nice 4k selfie photos
My problems weren't solve on this upgrade:
-The Dronie (Quickshot) is not accepting the distance i make. So when i inputed 30 meters, we goes away on that direction untill disconnects from the iphone 7. Circle is working fine, didn't tried other yet (low battery)
-The "drama" of wifi 5.8GHZ Europe makes it disconnect from 30 / 40 meters away of spark (and then he hovers and RTH). Tried to chance to 2.4 but the problem of iphone disconnection persists.
2017-7-27
Jimmyeao
Flight distance : 6604 ft
After the firmware update, my iPhone 6s kept losing WiFi connection every couple of minutes and stating 'incorrect password' I then had to reset the WiFi on the Spark to be able to reconnect. Then it disconnects again after a couple of minutes. Not prepared to fly with this firmware until this is fixed, it has also put me off buying any further hardware (controller, batteries, Mavic) until this issue is resolved. UK based, I assume this is the WiFi bug others have posted about?
2017-7-27
realstreetuk
Flight distance : 7966 ft
Jimmers Posted at 2017-7-26 18:03
Hi the voice promts work when in gesture mode meaning that it tells you what is happening. eg the ladies voice will say palm launch activated or face recognised.
at first i though of it as our voice to command it do what we want it to, but no its not like that.
By the way you need to have your phone connected to hear the voice prompts
2017-7-27
realstreetuk
GCBrent Posted at 2017-7-26 20:48
I have taken picture with gesture and it is not 4k Just 12mpx
2017-7-27
realstreetuk
fanse4e12300 Posted at 2017-7-26 21:29
Updated today.
Gesture feels worse
Same here gesture seems worse it hit and miss with palm recognition but before update it was better and no climbing gesture as well and no 4k selfie pic
2017-7-27
pvtsailor
Flight distance : 983196 ft
I also cannot find this. In the new manual they do not write anything about that. Maybe they cancelled it.
2017-7-27
Thor1
Flight distance : 196837 ft
pvtsailor Posted at 2017-7-27 02:37
The voice prompts are the remote telling you what is going on. ie: "palm launch activated"
It is not voice commands. i was also confused by this at first until someone corrected me.
2017-7-27
Thor1
i'm pretty sure it has always been 4k with rc or phone to take stills. the resolution was reduced for gesture control but not anymore according to dji.
2017-7-27
Malakyte
Flight distance : 216043 ft
BE CAREFUL WITH THIS FIRMWARE - POTENTIAL BATTERY KILLER
Proceed with extreme caution. After proceeding with this upgrade (26/07/2017 version), one of my batteries has died this morning. I got the infamous "inconsistent firmware" message after switching batteries despite having made the upgrade with a fully charged one. I can't switch off the battery and it stays with the 2 middle LEDs always ON. It won't charge with the hub either (red status LED). I will try to revive the battery with the wall charger instead and see if it can recover. If not, I'll go for an RMA through DJI support.
Battery always ON with middle LEDs permanently lit
2017-7-27
ix3lplix
Malakyte Posted at 2017-7-27 03:27
You will need to do the update with every battery, not just one.
I got the same "inconsistent firmware" message, but it should then prompt you to slide to do an update. Once you do that, you'll have to repeat the process with all your other batteries.
2017-7-27
