Arm Wobble
1376 11 2015-4-9
jliddil
Interesting video
2015-4-9
Northofthe49th
That was crazy!..Pre production jitters maybe? Good video editor maybe?
Wonder if the P3 ESC's and motors will fit in a P2?
TURBO!
2015-4-9
Daninho
Flight distance : 70203 ft
That does absolutely not look like arm wobble, the whole copter is just correcting its position. This is more like the Yaw movement the gimbal should smoothen out.
2015-4-9
acenothing
Flight distance : 112185 ft
Daninho Posted at 2015-4-9 22:34
That does absolutely not look like arm wobble, the whole copter is just correcting its position. Thi ...
I am not sure what I see but I would guess if you slo-mo the existing P2 you would see the same .  I would guess there is some natural resonance in all these things.  In fact you imagine the amount of torque from the motors and props on these little arms it is surprising there is not more movement.
2015-4-9
Daninho
acenothing Posted at 2015-4-10 01:59
I am not sure what I see but I would guess if you slo-mo the existing P2 you would see the same .   ...
i would say its an optical illusion, the plastic cant wobble, its stiff. The P3 is just twisting from right to the left very fast.
2015-4-10
acenothing
Daninho Posted at 2015-4-10 19:09
i would say its an optical illusion, the plastic cant wobble, its stiff. The P3 is just twisting f ...
Plastic can and does wobble.  It is not that stiff.  This is like saving steel can not wobble.  Anything can wobble depending on the properties of the material and the span.  Those motor and props put out a lot of force.  than the torque make it move.
2015-4-10
jliddil
acenothing Posted at 2015-4-10 22:51
Plastic can and does wobble.  It is not that stiff.  This is like saving steel can not wobble.  Any ...
and in fact you don't want things to be perfectly rigid quite often. It just appears in stopped frames that the motor is actually leaning over quite a bit. Perhaps video quality and perhaps pre-production model. Only time if this is an issue or what other issues may arise.
2015-4-10
acenothing
jliddil Posted at 2015-4-10 22:55
and in fact you don't want things to be perfectly rigid quite often. It just appears in stopped fr ...
I agree thanks.
2015-4-10
Phuglie
Flight distance : 45226 ft
.. and later some have complained about cracks appearing. Normally crack comes first and then the wobble
2015-10-1
liningiv
Flight distance : 329409 ft
Phuglie Posted at 2015-10-1 14:04
.. and later some have complained about cracks appearing. Normally crack comes first and then the wo ...
Quite the contrary, the wobble causes the cracks.
2015-10-2
Phuglie
liningiv Posted at 2015-10-2 21:16
I think you missed the joke - what drug is commonly referred to as 'crack' ?
2015-10-2
liningiv
Phuglie Posted at 2015-10-2 22:53
You are correct Fug....  I totally missed your joke.I'll try better next time.
2015-10-10
