GL300F controller question
11250 12 2017-8-24
Trekz
Flight distance : 3245 ft
Does the gl300f p4p controller work on the p4a?
2017-8-24
Cetacean
Flight distance : 2528264 ft
Aloha Trekz,
     The best answer would be from a DJI Team member, but the GL300F has two communications frequencies, 2.4 GHz and 5.8 GHz.  The P4A uses the GL300C controller, the same one as the original P4.  It also turns out that the GL300E used with the P4 Pro + (plus) is the same RC used with the P4 Adv + (plus).  The compatibilities should go like this:
GL300C  -  P4    P4A
GL300E  -  P4 Adv + (plus)    P4 Pro + (plus)
GL300F  -  P4 Pro
     So, if you want an alternative remote controller for your P4 Adv you could use the remote controller for the P4.  The P4 Pro remote controller is unique because it is the only Phantom that uses both communication frequencies (2.4 & 5.8 GHz).  The Mavic used the two frequencies but only without the remote controller (device only mode).  The Inspires do use both frequencies but their remote controller is different.
     Hope this helps!
Aloha and Drone On!
2017-8-24
Trekz
Cetacean Posted at 2017-8-24 11:13
Aloha Trekz,
Thank you!
2017-8-24
DJI Diana
Flight distance : 2408 ft
2017-8-24
Trekz
DJI Diana Posted at 2017-8-24 20:05
Nope, actually, you can find it in the Specs of P4A.[view_image]
Thank you! I was just making sure.
2017-8-24
pastorjared
Flight distance : 249829 ft
Actually you can, I have a P4A+ and I purchased a backup remote. I got the GL300F and in the app you have to change the setting to show that you are flying a P4A. Restart the remote and try linking. It should work.
My remote (GL300F) and P4A are successfully linked!
2018-7-26
fans843962c9
Flight distance : 150148 ft
Indonesia
Does the gl300f p4p obsidian controller work on the p4 standard? Thanks
2019-2-20
PatrickStark
Argentina
pastorjared Posted at 2018-7-26 16:53
Hello, it's possible to do this?
Can you explain me more? Thanks!
2019-5-10
PatrickStark
Argentina
I have the problem linking RC GL300F w/my Aircraft P4A.
I don't know why i cannot update P4A firmware with Dji Assistant 2 on the laptop, so i have no way to update it.
My RC doesn't recognize my aircraft.
2019-5-10
baschroeder2
Dose the P4A (GL300e) remote work with the Mavic 2 pro/zoom and/or the Mavic pro/platinum?
2019-11-23
Sick Dawg
Flight distance : 451119 ft
....no....
2019-11-24
fans9b709e66
Israel
The GL300f work in phantom 4 rtk???
2021-11-28
