Phantom 3 gimbal dial not working
12501 22 2015-6-21
pedro_abreu
I have a brand new Phatom 3 Professional.
During my first flight the left dial on the remote was able to tilt the camera up and down.  Now (second flight after recharging battery) it does not work.  I've calibrated the gimbal and it still does not work.  I was able to go to the DJI Pilot App and change teh gimbal dircetion from forward to down and then back to forward, but the dial continues to not work.
Any thoughts?
2015-6-21
sinbad_uk
Flight distance : 117343 ft
You may need to calibrate the RC again, ensuring you scroll the gimbal wheel left/right fully.
2015-6-22
SULTAN This user has been deleted
2015-6-22
jackngh
I experience the same problem.  Tried recal and sensitivity on RC yet no luck.  Should I return? Had it for 2 weeks.  Controller is version B
2015-9-21
eaton2001
I'm having the same issue with mine. At lease you got to have some enjoyment with yours. I guess I got to open the box up and take it out and do the firmware update but that's it! I'm sending back and hopefully dji will fix it or send me a replacement soon.  I hope you figure it out!
2015-9-30
eaton2001
This whole experience has been so stressful for me! I was so excited to get my dji phantom 3 and now I just want to cry. I hope the get it back to me soon! I have to send it to the company a got it from off amazon then they have to look at it and if they can't figure it out then they send it to dji so who knows when I'll see it. What a nightmare!
2015-9-30
philml420
I changed speed to lower on my phantom 3 standard and now it is acting weird, when i scroll just a little, say down,gimbal moves opposite, but when i scroll fast it almost works good,i calibrated RC few times, no luck,also calibrated gimbal few times,im thinking maybe IMU calibration?
2015-10-24
philml420
http://www.quadcopterguide.com/f ... l-on-dji-phantom-2/
2015-10-24
philml420
That helped me,well funny thing is,  my phantom 3 has the dial calibration option,  i just didnt see it
2015-10-24
Diego Rueda
Colombia
Hello friends, I'm from Colombia do not speak English. I have the same problem with my Phamtom 3 standard, the dial gimbal stopped working, I put it to fly but it does not work, the last time I flew it was working perfectly. anyone knows what I can do? in APP DJI Go, I calibrated everything, but the phantom still not working. I'm sad
2016-1-22
Diego Rueda
Colombia
Hello friends tell you that you can fix the problem and has to do with the speed of the gimbal, I had it to 0, to leave plays roles in 30
2016-1-22
kutaisi
Georgia
sinbad_uk@ntlwo Posted at 2015-6-22 15:14
Your advise is a winner!
2016-2-9
DJI-Ken
Flight distance : 1515312 ft
Also there is a gimbal wheel speed adjustment in the app, if that somehow got set to 0 then the wheel won't work.
2016-2-9
chrisindevon
Flight distance : 66 ft
Hi
I experienced the same problem with my gimbal this morning whilst flying over the sea.
The gimbal wheel didn't appear to move the camera. I got back home and did a control unit update , still not working. I checked the gimbal speed and found it was set to slow speed, all the way to the left. I set the control to approximately 30 and it works fine, nice and smooth. Give it a try. Good luck.
2016-4-7
gerzon113
Hi...
I have the same problem with my gimbal, but in my case nothing of your subjection is seen to work for me. all firmware are up to date. I calibrated gimbal and RC, many times. Any change made to the setting no luck. please help.
2016-7-4
chonny
Same issue here. Tried evrything sugested here but no result.
2016-7-22
DJI-Ken
chonny Posted at 2016-7-23 01:43
Since you tried deleting and reinstalling the firmware, RC stick calibration, gimbal wheel speed, and other suggestions I think you should contact support and have the RC checked out.
2016-7-22
DB4Tim
Any updates on this mine does the same thing...on TWO birds, both worked fine and now...gimbals wheel does nothing except INCREDIBLY slow moment almost so slow you cannot see it, it you wait long enough while holding the wheel at full stop it moves...S  L  O  W  L  Y
DJI-Ken....please help
BTW calabrateded and all
2016-8-28
DJI-Jamie
Flight distance : 112405 ft
DB4Tim Posted at 2016-8-29 07:26
Any updates on this mine does the same thing...on TWO birds, both worked fine and now...gimbals whee ...
To clarify, have you already tried relinking the RC to the aircraft?
2016-8-28
DB4Tim
Yes.................3 times
2016-8-28
DB4Tim
HELP............................................
2016-8-29
userf88cacf812
Flight distance : 164104 ft
Did you ever figure out what the problem was? I have 2 controllers and one of them has the same issue. Using the same device with both controllers so it's not a setting because the other controller the gimbal wheel works as expected, but this one the speed at which the gimbal moves is extremely slow. From within the app, I can move the gimbal and it moves quickly. I have one of the buttons assigned to point the camera at the ground and that works as expected also.
2017-2-3
billy_jrb
Flight distance : 184757 ft
Hola a Todos
Alguien pudo solucionar este problema, a mi me sigue pasando lo mismo con la app se mueve, con el boton automatico (arriba/abajo) tambien, pero con la rueda no.
2017-9-11
