New Firmware 1.2.1.0 released - Share your experiences after installation.
123456Next >
15744 209 2015-4-14
stephenbrink62
Flight distance : 380522 ft
Hey guys.....well it has finally arrived & let this be the forum to discuss any issues after the installation on whether improvements have been made or any more bugs some may experience. I'll comment later after installation and flight.
Safe flying out there....
2015-4-14
Prop-Lock Girl
Flight distance : 2419163 ft
Oh damn, I can't test until tomorrow!
Please give some feedback ;-)
2015-4-15
mirco
Did the update.
The log after rechecking is as follows:
[00010378]========== 2014.01.01 00:00:10 unsynchronized ======
[00010387]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010395]Packet upgrade start...
[00010402]Packet checking...
[00010406]Done.
[00010410]Version checking[1]...
[00010415][01 00] v1.7.2499 -> v1.7.2499          Maybe Camera
[00010420][01 01] v1.7.2499 -> v1.7.2499          Maybe Camera
[00010465][03 05] v34.1.0.5 -> v34.1.0.5
[00010499][03 06] v2.0.5.10 -> v2.0.5.10            Maybe Main Control
[00010510][04 00] v1.16.0.76 -> v1.16.0.76        Maybe Gimbal
[00010539][05 00] v2.5.6.1 -> v2.5.6.1               Maybe Center Board
[00010546][08 00] v1.11.0.19 -> v1.11.0.19        Maybe Air System Encoder
[00010564][09 00] v1.7.0.3 -> v1.7.0.3               Maybe Air System Main Controller
[00010600][11 00] v3.3.0.0 -> v3.2.1.0
[00010661][12 00] v1.3.0.60 -> v1.3.0.60            Maybe ESC
[00010719][12 01] v1.3.0.60 -> v1.3.0.60            Maybe ESC
[00010780][12 02] v1.3.0.60 -> v1.3.0.60            Maybe ESC
[00010839][12 03] v1.3.0.60 -> v1.3.0.60            Maybe ESC
[00010897][15 00] v1.1.2.0 -> v1.1.2.0                Maybe Air System USB transmitter
[00010919][17 00] v1.1.0.1 -> v1.1.0.1                Maybe Vision Positioning System M4
[00010999][17 01] v2.0.0.1 -> v2.0.0.1                Maybe Vision Positioning System M0
[00011014][19 00] v1.0.8.59 -> v1.0.8.59
All done but one.
What is this component? Maybe the Battery?
2015-4-15
adam.krow
Just updated both batteries and controllers, no problems!
2015-4-15
Farnk666
Flight distance : 1711394 ft
Loading now - will post back in a bit!
2015-4-15
mirco
That seems not to be a Problem, but this component seems to have newer Software than the latest update. How could this be?
2015-4-15
ola
adam.krow Posted at 2015-4-15 17:02
How did you upgrade battery?
I have three batteries, how do I upgrade them?
2015-4-15
airimage.pl
ola@almviken.co Posted at 2015-4-15 17:37
Updating Intelligent Flight Battery Firmware
The Intelligent Flight Battery is upgraded during the aircraft firmware upgrade process. It is recommended to keep the upgrade package files in your SD card. The upgrade will start automatically after power cycling the aircraft.
2015-4-15
Farnk666
All good - loaded fine. Had to try a couple of different USB sticks on the controllers, but got there in the end.
Same thing happened last time. If you find that the update doesn't start on your controller, try the microSD in a reader or a different USB stick.
2015-4-15
Farnk666
Topvisions Thai Posted at 2015-4-15 17:51
Manual 25 minute Anyone update how long time to do. Or more
Much quicker than that Topvisions - only took a few minutes for me.
All updates returned a 'success' result.
2015-4-15
bahamasky
Flight distance : 3240535 ft
Bahamas
u guys will love it!
2015-4-15
mirco
Could someone be so kind to have a look to the Memory Card in \MISC\LOG\WM610_FW_LOG_AB.txt
to the section
[00010600][11 00]
What is printed there?
2015-4-15
nilsblix
Flight distance : 23047543 ft
Upgraded Craft Remote Batteries - no problems.
Flying tonight
2015-4-15
mirco
@bahamasky
Did i missed a Thing.
I thought that there are only bugfixes
2015-4-15
robbie_gilmore
Is it just me ?  Shouldn't we receive info regarding a Firmware Upgrade from DJI rather than learning about it in a Forum?  I had problems last upgrade.  Any clue what features this involves?  I would like to know as I am not having any issues flying or video at this time.
2015-4-15
mirco
@robbie_gilmore
Take a look here
http://download.dji-innovations. ... elease_Notes_en.pdf
2015-4-15
gboivin
Flight distance : 1544416 ft
No problems here! 2nd controller and all batteries updated flawlessly
2015-4-15
Prop-Lock Girl
Hi folks!
for me the most annoying issue ist the gimbal horizon drift. The release notes says it has been fixed. Can you confirm that?
Thanks!
2015-4-15
Farnk666
Topvisions Thai Posted at 2015-4-15 19:45
Found that battery 1-2 test fine but batter 3 found that "BATTERY UPGRADE REQUIRED" . Any advise me  ...
Put the sd card with the firmware in the camera, put the battery in and power it on.
The inspire will update it automatically
2015-4-15
Farnk666
2015-4-15
mirco
Once again:
to the section
[00010600][11 00]
2015-4-15
DJeff1
Is the WM610_FW_V01.02.01.00, file type MPlayer Video File size 38,376 KB be the only file we place on the SD card for updating?
2015-4-15
mirco
DJeff1 Posted at 2015-4-15 20:10
Is the WM610_FW_V01.02.01.00, file type MPlayer Video File size 38,376 KB be the only file we place  ...
Yes it is. You have to place it in the root Directory of the Memory Card
2015-4-15
DJeff1
mirco@dzillum.d Posted at 2015-4-15 20:12
I have deleted all other files on my card and that is the only file that is now on the card.
2015-4-15
kirk.pleasant
Qatar
mirco@dzillum.d Posted at 2015-4-15 19:59
Once again:
Could someone be so kind to have a look to the Memory Card in \MISC\LOG\WM610_FW_LOG_AB. ...
Sorry I don't have that file on my card
2015-4-15
clintbarton
Upgraded the craft with no issues. The controller wouldn't update via my usb drive, but I was able to update both controllers from the Gimbal. Also upgraded the FW on 6 batteries (TB47 & TB48) without issue. Test flight tonight
2015-4-15
mountmotor
POST flight performance please!!!! I don't see my bird till tomorrow when I get back to LA!!!! I'm dying of curiosity
2015-4-15
kirk.pleasant
Qatar
Just completed updating 2 Inspires, 7 batteries (including the one with the bad cell) and 3 controllers.
Took 13 minutes for 1 Inspire and 10 1/2 minutes for the other Inspire.
About 1 1/2 min for each controller and 1 min for each battery.
After each upgrade I removed the sd card, checked the text file then deleted it before the next item was upgraded.
In the end I did not have to re-link my controllers , both masters and slave continued to work as previously linked.
All gains on the controllers were reset to a default value.
After the upgrade I had to calibrate each compass.
The only issue I had was one of the controllers would not link  initially, I then tried to reset the link with no luck. After that I put in the .bin file back on the sd card in the camera and it did the upgrading sound for about 2-3 minutes and then stopped. I turned on the controller then and it linked!
I have tested out the simulator and it seems fine...now heading out to a wide open place to test!
Cheers
2015-4-15
lcoleman
How do you access the log file that shows the firmware for each component?
I did the update on the aircraft but the notepad says, "Result: Failed.
Reboot the aircraft and try to upgrade the firmware again."
When I try again it says, "Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft."
The controller updated fine and the app says, "Overall Status - Normal (latest firmware)
2015-4-15
niels_hornung
The horrible lag with dual output and an android device still exists why DJI why?
2015-4-15
stephenbrink62
lcoleman Posted at 2015-4-15 21:03
I did the update on the  ...
How old is your unit & to access your log file you will need your computer to see hidden folders...hope that helps
2015-4-15
gboivin
Notices of Firmware Update thru email notification to registered owners was a great way of being in touch with the customers direct. Not all of us can be glued to the forum 24-7 LOL Also  video of firmware install was a great idea!! Firmware was a breeze! Thanks DJI for listening and working to improve on this very important subject
2015-4-15
joekeantang
gboivin@msn.com Posted at 2015-4-15 21:57
Notices of Firmware Update thru email notification to registered owners was a great way of being in  ...
I agree I woke up to that email this morning! will be upgrading my bird soon!
2015-4-15
Abe
Flight distance : 524032 ft
In case you did not get the email:
Dear Inspire 1 Owners,
A new firmware update (V1.2.1.0) is now available for your Inspire 1.
Please visit http://www.dji.com/product/inspire-1/download to download and update your Inspire 1.
What’s New
Reduced likelihood that the aircraft will automatically switch to P-ATTI mode when encountering interference or other errors during flight.
Solved issue of sudden gimbal drift during flight.
Enabled ability for aircraft to initialize and takeoff from a moving surface.
Added intelligent landing gear feature: landing gear will automatically raise when the aircraft reaches an altitude of 1.2m for the first time, and automatically lower every time it descends to 0.8m. Users can turn this feature ON/OFF in the Pilot app.
Updated No-Fly zones, please refer to http://flysafe.dji.com/no-fly/ for the updated zones.
Optimized Return to Home. Now allows the pilot to interrupt the aircraft when ascending by moving the throttle stick up/down if it is at an altitude of 20 meters or more.
Added a reminder to the Pilot app that will alert the user to perform a full Intelligent Flight Battery charge/discharge cycle when required.
Altitude limited to 120 meters when in non-GPS mode.
Optimized the OSD display for HDMI devices.
Pilot app updated to show the complete firmware version instead of individual component versions.
When changing the Home Point to the RC’s location, added an alert to the Pilot app to tell the user the distance between the new Home Point and the previous one.
Added more descriptions to explain why the aircraft enters P-ATTI/ATTI mode in the app.
Added more details to the Pilot app on the aircraft status when in Return to Home mode.
Added a reminder to the Pilot app reminding the user to fully charge the Intelligent Flight Battery before the first flight.
Gimbal will stop moving if it detects that the camera’s USB port is connected to another device.
Optimized gimbal calibration feature.
Optimized Vision Positioning System stability.
Note
After updating to this firmware version, compass calibration is required.
After updating to this firmware version, the aircraft will be locked. The Pilot app must be connected to unlock and takeoff.
Please contact DJI support if you have problems after updating the firmware.
2015-4-15
Arrow1969
Flight distance : 400577 ft
Firmware update failed on the first attempt ,formatted card tried again everything okay, have 7 battery to update 4 of them needed to update and 1 has to have a full cycle.
2015-4-15
rsghowellnj
Flight distance : 508255 ft
mirco@dzillum.d Posted at 2015-4-15 16:53
Did the update.
I'm confused.  You indicated that you needed to update both batteries.  Are you saying that I need to do the firmware upgrade on my Inspire 3 times for with each battery installed and then again on each controller?  In the past I only did the firmware upgrade on the Inspire and then for each controller.  Is there an update that has to happen on each of the batteries as well?
2015-4-15
Grimtheviking
Flight distance : 12584416 ft
All updated, no problems just follow included update instructions for I1, RC, and batteries.
Ps,, RTH height defaults back to 20m, if you need higher than you will need to change.
Now out to test,, fingers x'd
Update,
Test flight results all good, no GPS drop outs or gimbal twitch and as solid and stable as a rock,,,,,,,,
So far so good...
Regards
Mike.
2015-4-15
philbard
Has anyone actually flown with the new firmware?  East Coast? Europe? Aussies?
Is the GPS problem any better?
2015-4-15
lethbrp
Its good that they are fixing bugs, but lets hope we are now on the road to new functionality in the next release (waypoints, POI etc..).
2015-4-15
rsghowellnj
Updated Inspire, 3 Batteries and 2 Controllers.
I guess I have to re-callibrate IMU and then compass before flying.  Going to try this evening.
2015-4-15
123456Next >
