Spark owners in Germany with Plakette (tag)
3244 27 2017-9-25
FahedC
Flight distance : 16818 ft
I have a question about the Plakette ( Tag ) with our information thats need to be some where in the Drone attached. So I spoke with someone in  the Online Support asking them where is the safest place to put the aluminum tag so that it doesnt have any  interference with the GPS or something else and this is what he answer me .
" I see. Here at DJI we not recommend to attached any third party items on the drone because it may affect the performance specially for your spark. In this case, that is aluminum, it may cause magnetic interference to your spark that may cause of crashed. May I suggest, Just keep that aluminum plaque with you when you are trying to fly your drone."
Any one here has any experience flying the drone with an aluminum Plakette ( Tag ) without problems ? and where did you attached on the drone.
Thanks in advance.
2017-9-25
Rawsome
Flight distance : 230827 ft
Perhaps print a small label (label maker) with the same information and stick that on your bird. Keep the government issued one in your pocket.
Wonder who the genius was that decided to make this a metal plate...
2017-9-25
quikee
Flight distance : 54590 ft
Slovenia
Rawsome Posted at 2017-9-25 10:39
It's metal probably to make it fireproof.
2017-9-25
fans61699a75
Flight distance : 24971795 ft
Yes i ordered these plakette here:shop@drohnen.de
I have stuck mine at the side of the drone. So far no problem. Its a very small plakette .
2017-9-25
fans61699a75
Especially for the sparks at the moment you need them , so not only in germany , worldwide , as they are having a lot of issues i read on the forum. So if one does a runner and you cant find it anymore, maybe one day some honest person finds it and sends it to you
2017-9-25
DJI-Mark
Keep the official tag with you. Keep a copy on the aircraft.
2017-9-25
FahedC
Yes the same thing told me DJI but it needs to be fire resistance in case of any fire accident created by the drone.
2017-9-25
FahedC
fans61699a75 Posted at 2017-9-25 11:55
Do you may maybe uploading a photo to see it ? And yes specially now that i see lots of users having flyaway or loosing gps . I dont want this aluminium tag ve the cause of that
2017-9-25
fansd9f1395d
Flight distance : 15344 ft
I already have a 'plakette' (tag), which is a really tiny one and fits on my spark on the side between the propeller arms. So far I had no interference. Hope it will stay so
2017-9-25
FahedC
fans61699a75 Posted at 2017-9-25 11:52
Thanks for the info
2017-9-25
jsfilmz0412
Flight distance : 13428 ft
FahedC Posted at 2017-9-25 12:36
Thanks for the info
whats this rule for?i thought spark is small enough it isnt regulated?
2017-9-25
Bright Spark
Flight distance : 22129 ft
The tag isn't there for some kind person to return it when lost. It's there for the authorities to prosecute you in the event of a claim.
2017-9-25
FahedC
jsfilmz0412 Posted at 2017-9-25 12:44
When the drones weights more then 250 grams it needs to have a tag with your information
2017-9-25
FahedC
Bright Spark Posted at 2017-9-25 12:49
Yes , that its correct
2017-9-25
Wachtberger
Flight distance : 261509 ft
Estonia
We have had this topic already and I have posted a picture of where my metal plate is placed based on an official recommendation received from DJI Germany: https://forum.dji.com/forum.php? ... 80&page=1#pid963101
2017-9-25
FahedC
Wachtberger Posted at 2017-9-25 13:05
Thanks for the information , I was the one that ask you where did you put your tag on the drone in the other thread, you told me to ask to the DJI support for more information so i did and they said they dont recommennd to put an aluminium tag on the drone.  I will try again to get in touch with them and maybe ask further more . I really appreciate your answer ☺
2017-9-25
Rawsome
In case of a fire your little drone will likely not leave any evidence ;)
2017-9-25
Bright Spark
Unless the little drone meets with a little person.
2017-9-25
TexasAerials
Flight distance : 566952 ft
uh, aluminum is non-magnetic, so it shouldn't affect the compass.  it could affect gps signal though.
2017-9-25
Alanzalander
Flight distance : 93009 ft
I ordered a very small plakette today, only 18x8mm in size. They say it weighs ~0.4g.
I added a photo of the inside of the spark, borrowed it from a YT video. It shows a large heatsink with fins in the middle. I imagine placing the plakette right above that huge metal structure can hardly influence radio, GPS or compass.
Camera is left side, SD card right.
2017-10-7
Flight distance : 10186312 ft
Alanzalander Posted at 2017-10-7 11:00
Just don’t place it on top of GPS receiver. You can then calibrate compass with tag on and you shouldn’t have any problems.
2017-10-7
Wachtberger
This is where I have placed my one based on a recommendation given by DJI Germany and it does not cause any problems (and it is the place that you have correctly guessed to be the best):
Metal Plate on Spark
2017-10-7
wglovett
so for warranty purposes.. in the event of crash throw aluminum tag in the last known vicinity of your drone, must land in a clearly visible manner (ontario)
2017-10-23
ThomasHB
Flight distance : 33891 ft
Direkt vorne funktioniert auch einwandfrei.
2017-10-23
HansWerner
Yes, if you fly in germany hen you should get such a lable. We call it "Drohnenplakette". There are currently 2 decent sellers available, these are https://shop.drohnen.de/drohnen-plakette-nano/ and https://droneparts.de/copter/dro ... m-40x20mm-feuerfest But it depends: You don't need the "Plakette" in all cases, it depends on the weight of your drone. If you need one or not, you can find out here: http://drohneversicherungsvergle ... ersicherungspflicht
Hope it helps!
2017-10-26
Wachtberger
HansWerner Posted at 2017-10-26 18:03
Yes, if you fly in germany hen you should get such a lable. We call it "Drohnenplakette". There are currently 2 decent sellers available, these are https://shop.drohnen.de/drohnen-plakette-nano/ and https://droneparts.de/copter/drohne-kennzeichen/etikett-aluminium-40x20mm-feuerfest But it depends: You don't need the "Plakette" in all cases, it depends on the weight of your drone. If you need one or not, you can find out here: http://drohneversicherungsvergleich.de/#drohnenversicherungspflicht
Hope it helps!
They are mandatory for all drones above 250 gramms weight, thus also for the Spark. And there are many more similar offers on the market. A simple google search makes them easy to find.
2017-10-27
fans5e7d6d40
Philippines
Wachtberger Posted at 2017-10-27 08:08
Here is a good info about the German "Drohnen Plakette".
https://translate.google.com/tra ... en%2F&sandbox=1
or the original site: https://versichertedrohne.de/blog/drohnen-plaketten/
Hope it helps!
2018-4-15
Wachtberger
fans5e7d6d40 Posted at 2018-4-15 12:18
https://translate.google.com/translate?hl=en&sl=auto&tl=en&u=https%3A%2F%2Fversichertedrohne.de%2Fblog%2Fdrohnen-plaketten%2F&sandbox=1
Thank you for your kind assistance! I have had it already before it became mandatory and I hope that by know all German pilots have it.
2018-4-15
