Encouraging news on the P4 firmware issue
1234Next >
8516 120 2017-9-27
Aardvark
Flight distance : 384432 ft
KedDK Posted at 2017-9-28 01:36
Just wondering, do you know for a fact that assistant are performing some sort of verification or checksum calculation or if it would just flash whatever it has got.
I really hope DJI has been mindful enough to do some checksum validation but on the other hand one of your co-captain's in here beside of his admiration of this "cutting edge tech", keep mumbling about bad downloads, he could be right in that.
I don't know for a fact. But it would seem meaningless if they didn't do any check sums or file verification, and I suspect the failure rates would be near 100% if none were carried out. Perhaps these error checks are not perfect and some corruption could get through ?
What I can say is that over the past two years having carried out every upgrade  on my previously owned P3 Pro, and my currently owned P4 & Mavic machines that I have never had any problems that I've been aware of regarding the downloads.
2017-9-28
Hellsgate
Flight distance : 1991555 ft
well i for one have had to send in my one month old p4p in to be repaired firmware fault ? hardware fault ? pilot error not a chance. crash ..never happened. environment ... very much doubt as ive flown in exact same place many times without an issue.
seems to me that many pilots are having very similar issues all coincidentaly happening just after the latest update. coincidence? hmmm you guys work that out yourselves but i know from my point of view ive just spent over $3000 on a drone that i can no longer trust how can i use this drone in search and rescue situations or fighting fires if its not going to be reliable?
unfortunatly once and if i get my drone back in working order i will probably have to sell it and find something that i can rely on to help save peoples lives.
2017-9-28
JockC
Flight distance : 459416 ft
Aardvark Posted at 2017-9-28 02:52
Per my previous post, I agree with what you’ve said and have had the same experience. I’ve never had a DJI firmware update fail because of a download data integrity issue. I also doubt that any company would allow an update process without some kind of integrity/ validity check. That would simply defy all accepted principles and best  practices for software/firmware distribution.
2017-9-28
jbj220
Flight distance : 847031 ft
A lot of this BS could have been avoided if DJI wouldn't have taken the "restore to previous version" option out...
2017-9-28
KedDK
Flight distance : 1133038 ft
Yes my download/update also was done without any issues, but the result ....
2017-9-28
KedDK
Hellsgate Posted at 2017-9-28 03:11
I have no doubt that the June FW upgrade has given all the trouble on my P4P+ (minus), what i am unsure of is if a new FW can fix it or if something has got trashed for ever.
Downgrade of both RC and AC has helped a lot but i still see something not quite as before the upgrade.
I fully understand your point, but you could do without selling if you keep it away from the net. i really would like to know what version it has from factory as i think it is not one of the official releases and i have no notes of my own from before the fatal upgrade.
2017-9-28
KedDK
JockC Posted at 2017-9-28 03:33
I also believe that some sort of control is done but must admit that a little doubt is nagging me as time go without they fix the issues. It shouldn't take long to put some previously working code into a FW fix unless they know something might have been flashed to eternity.
IT does look a little like they want to solve it by having the equipment sent in, just to send a known good downgraded item back to the customers.
I know how to test but don't feel like bricking the rest of the life out of it.
2017-9-28
Pvt Pilot '79
Flight distance : 1000272 ft
KedDK Posted at 2017-9-28 00:54
Not to disappoint you but they have claimed that for months now, if they would they could have solved the issues by removing the disaster FW and provide a factory FW from where we could update to last known good version.
Agreed. There's got to be a reason that DJI won't put V602 back on Assistant 2 to be a able to roll back to. Either there's a security issue with it or maybe they want all P4 owners to pop for a new P4P. I mean it makes no sense to upset a large customer base for no reason.
2017-9-28
KedDK
Pvt Pilot '79 Posted at 2017-9-28 08:21
"maybe they want all P4 owners to pop for a new P4P."
Bad strategy as a lot of P4P's also was hit by various problems of the same kind, even before they infected the P4 with the stuff ...
And yes they think they can stop the ones doing nasty stuff with their limitations and believe that by taking a lot of regular customers hostage by removing the downgrade, the "dirty hackers" won't find a way. For sure a wrong strategy only hurting all others.
2017-9-28
Pvt Pilot '79
KedDK Posted at 2017-9-28 08:31
I was being sarcastic about motivation to pop for a new P4P. That would be beyond stupid for DJI. Something is up because none of this makes any sense; especially the silence from their end.
2017-9-28
KedDK
Regarding the new FW comming soon, see the claims of july ...
Yes possibly one day they got it right, but when is soon?
2017-9-28
F.KOK
Flight distance : 19109472 ft
Namibia
Hope for the best.
Date: 27 September 2017 at 14:44:57 WAST
To: DJI Support <support@dji.com>
Subject: Re: [Support] : RE Re: [Support] : RE Re: [Support] : RE Re: [Support] : RE Re: [Support] : RE ***Beta firmware for Phantom 4
Thanks for your feedback. Appreciate it.
Sent from my iPad
On 27 Sep 2017, at 12:02, DJI Support (DJI Support) <support@dji.com> wrote:
##- 請在這行以上輸入回覆 -##
Your request(#755569)has been updated, please reply the email below.
DJI Support (Support)
9月27日 18:02 CST
Dear Kokfbc,
Good news to you.
The R&D team has fixed the issue, there will be a new firmware be updated soon, it is under the testing now.
Please be patient to wait for it.
Hope you have a nice day.
Best regards,
Aurora
DJI Technical Support
Office hours: Monday to Friday , 9:00AM to 18:00PM (HongKong Time GMT+8:00)
2017-9-28
fansa84fe8a4
Flight distance : 3 ft
F.KOK Posted at 2017-9-28 08:45
Hope for the best.
Which issue was this response for?
I've lost track of all the issues...
2017-9-28
wangrincreation
Flight distance : 984436 ft
I am pretty sure this the fix for the wobbling issue
2017-9-28
Schlepprock250
Flight distance : 1375 ft
I'm still running firmware from like December... Thank God I didn't update.
2017-9-28
Pvt Pilot '79
wangrincreation Posted at 2017-9-28 09:12
Hoping for that anyway.
2017-9-28
veekman530
echopiece Posted at 2017-9-27 10:35
I wonder if this has anything to do with those who hung up at 99% download?  My P4 hung at 99% and I have all of the common issues.
my update said complete and still flew like crap.
2017-9-28
CDSSafety1
Flight distance : 98950 ft
Ok, here's my first post. I bought a phantom 4, to be delivered tomorrow. Should I,can I just not update it until they fix the problem?
2017-9-28
wangrincreation
It's all depends on you, you can update, and fly well or we can welcome you to our club with all sort of issues like wobbling bird.
2017-9-28
Pvt Pilot '79
CDSSafety1 Posted at 2017-9-28 17:42
Do not update it.
Here’s an email I just received today. It counterdicts the news I heard earlier. Who knows what to expect now:
Riezl Grace C. Lor (Support)
9月29日 08:02 CST
Dear John,
Thank you for the response.
Regretfully, there are no future developments to enhance this option at the moment. What we can do is collect all related feedback on relating to this concern and forwards them to our Developers as Customer Suggestion to further review as a case possibility for the next firmware update/product enhancement.
Though we are unable to provide you an exact resolution time, we appreciate your suggestions that will help us improve our products. We urge you to constantly visit our link - www.dji.com for the latest updates on our technology and products.
I regret to tell you that there is no way to download again the downgrade version on our website. All the available firmware are listed there. I suggest you to use that third party installer program.
I hope you understand.
Just please let me know if you have other questions regarding with this matter.
Thank you for choosing DJI and have a great day!
Sincerely yours,
Grace
DJI TECHNICAL SUPPORT
Tel Support: +1(818)235 0789 / Mon-Fri 7:00AM-5:00PM(PST)
Online Support: http://www.dji.com/support#after
2017-9-28
KedDK
Pvt Pilot '79 Posted at 2017-9-28 19:35
Do not update it.
"I suggest you to use that third party installer program."
Still a little unclear to me what the dialog was about in the first place, but the above statement i find hilarious as they could just put the old FW's back to ensure their customers don't get something installed that has been mingled with.
2017-9-28
F.KOK
Namibia
fansa84fe8a4 Posted at 2017-9-28 08:56
It is for the unstable issue.
2017-9-28
SuperVal
Hey guys, first post here on the forum.
I have updated my P4 to 2.00.0300 - that fixed the camera issue
I launched DJI Assistant this morning, and I have the option to downgrade to:
- V2.00.0034 Beta
- V2.00.0106 Official
- V2.00.0200 Beta
- V2.00.0300 Beta (CURRENT)
Any of you had issues w/ the .0034 beta. I am considering downgrading to that version see if it's any better.
Thanks for your feedback,
2017-9-29
Blériot53
Flight distance : 6269839 ft
Fly it first, in Airplane mode on your tablet(wifi OFF) and if it works OK  don't chance any upgrades for now.
2017-9-29
VFARYAN
Flight distance : 1461611 ft
SuperVal Posted at 2017-9-29 01:47
This is my video when using. 300. I honestly wouldn't waste your time. Just wait for the next release.
https://youtu.be/FkBQdNIP9KQ
2017-9-29
Pvt Pilot '79
KedDK Posted at 2017-9-28 22:30
That email was from tech support. So we’re getting conflicting information because online support is where I was told the fix for the erratic flying qualities is underway. I have a copy of all the prior versions and I know that 503 and 602 work perfectly. I’m going ahead and rolling back to 602 myself once again.
2017-9-29
SuperVal
VFARYAN Posted at 2017-9-29 03:45
I test flew the drone a couple hours ago, this is what I got. Seems to fly ok. Running the 2.00.0300 beta.
2017-9-29
SuperVal
Landing the P4, windy conditions w/ the 2.00.0300 beta firmware
2017-9-29
Juliano Cruz
Flight distance : 4158868 ft
How to becone a beta tester?
2017-9-29
Aardvark
Juliano Cruz Posted at 2017-9-29 10:19
You need to request the Beta V02.00.0300 file by sending a PM (Personal Message) to DJI Thor or DJI Susan. This PM should include the email address you use to log into your DJI Account.
2017-9-29
Aardvark
I flew my P4 yesterday using V02.00.0300 (Beta) and had no problems with recording in 4k @ 30 fps, which is what the .0300 beta was testing. I had no instability problems with the formal release 02.00.0106 nor V02.00.0300.
If your P4 is just being delivered it might be prudent to wait for a few weeks, there may be a formal fix soon, also it will give you some experience to be able to judge if something is wrong after you update.
2017-9-29
Uptowndisco
Flight distance : 7394987 ft
Beta V02.00.0300 has fixed the erratic flight and stop recording issue when in 4K for both myself and a friend's P4 , I dont know
why DJI is holding firmware  V02.00.0300 back from those having problems esp since they wont allow a rollback anymore.
"Edit" to add this is a P4 on beta firmware from today , the craft is back to being rock solid as it was before the fatal update
to the latest official update which made it useless if trying to record in 4K mode.
Beta Flight in UK
2017-9-29
UnFlyable2
fans1f690efe Posted at 2017-9-27 15:59
I wouldn't hold my breath, sorry for sounding so negative but I've a pain In my ass with this disastrous firmware.
I feel the same, almost 3 months unflyable, that's ridiculous!
2017-9-29
Blériot53
Uptowndisco Posted at 2017-9-29 12:03
That looks as stable as you could wish for.  Good flight. Thanks for the share.
2017-9-29
Aardvark
A lovely video, I spent several holidays there as a child in the 60's. I used to play in the Orchard that can be seen behind the Palace in the opening shot.
Good to hear that V02.00.0300 has resolved your stability problem.
2017-9-29
Juliano Cruz
Aardvark Posted at 2017-9-29 11:01
Thanks a lot Aerdvark!!
2017-9-29
Supong
Mine, May 2016, very shaky flying in light wind and gimbal lost power sometimes. Never happened with previous firmware. Goback to previous firmware the problem disappeared.
2017-9-30
JockC
Supong Posted at 2017-9-30 18:19
Those are the same problems that have been reported in hundreds of posts within this forum (and many other deleted post and threads) . There are clearly a number of issues introduced with the last firmware some of which have restricted or prevented owners’ use of their drone for almost three months.  We live in hope that DJI will release some reliable P4 firmware to address those issues soon. In the meantime we at least have the third party facility to restore the previous firmware which proved to be far more reliable.
2017-10-1
scbeer1
Flight distance : 33947 ft
I Dam well hope so.  Right now I have a $1,500 paper weight. To me the wobbling appears to be some errant inputs from the collision avoidance sensors no matter what flight profile your operating in.
2017-10-1
speedblue
Flight distance : 329511 ft
This update on the horizon  is good news. Unfortunately, DJI support had me send my Phantom 4 in for repair last week. My flights have been so erratic since the last firmware update that it was practically unflyable. I asked about firmware but that didn't seem to be a possibility to the rep I spoke to on the phone. Anyway, I hope they can get it fixed and back to me in a reasonable amount of time. In May  I sent my remote in for repair because it wouldn't charge and it took 6 weeks to get back to me.
2017-10-2
1234Next >
