Need help rolling back FW on Aircraft to work with RC FW 1.6
fans35a98fd8
Hi all,
It is with great regret that I upgreted my P3P RC/AC to the latest FW versions 1.9.2/1.11.20 before reading the forums.  Now I have a drone that works in all respects except streaming video.  It flies, it records, it lands...just doesn’t transmit video to the RC.
Anyway, I’ve rolled back the RC FW to 1.6 which was the last version that worked for me but I don’t remember what the corresponding stable FW for the AC was.  Any help with identifying, downloading, and installing the corresponding FW would be incredibly appreciated.  Otherwise, this POS will end up becoming an expensive paper weight.
Thank you in advance for your help.
2017-9-29
Mordorr
Portugal
You can rollback RC on the app...
About the FW...there is a way to force rollback the FW 1.11 to earlier versions, but its dangereuse.....
2017-9-29
Which mobile device do you use? Whether the current channel is stable or not when the issue appeared? I'd like to check.
2017-9-30
KedDK
Flight distance : 1133038 ft
Mordorr Posted at 2017-9-29 11:31
Please tell a little more ;-)
The tool i am using would not work on the P3 series as far i can see.
2017-9-30
Mordorr
Portugal
RC only?
Easy: When open DJI Go app, press for a few seconds on the icone, superior, right.
It will open a secret menu to dongrade the RC to early versions:
However.....only 1.9 will work with 1.11fw (((
2017-10-1
Aardvark
Flight distance : 384432 ft
When your RC was at version 1.9.2 did you try re-linking the RC to the aircraft ? That might (or not) make a difference to the live view transmission.
2017-10-1
DTK
Flight distance : 1943159 ft
Once you are on latest firmware, dji has stopped you to go back to older version. They want to enforce no fly zone restrictions in the latest version.
2017-10-1
BocaDad
DJI Susan Posted at 2017-9-30 01:26
Hi DJI Susan,
I normally use  an Android Tab 8 but I also tried using iPad mini.
2017-10-1
BocaDad
Aardvark Posted at 2017-10-1 06:21
Yes, I re link every time I updated
2017-10-1
BocaDad Posted at 2017-10-1 08:22
Hi DJI Susan,
Please try to re-plug the pins on the side of the gimbal. Also, the aircraft firmware and RC firmware should be matched all the time, then you can try to link RC.
If still no helps, please send it in for diagnosis: http://www.dji.com/support.
2017-10-11
