RicardoGray
Flight distance : 4356421 ft
Irate Retro Posted at 2017-10-3 10:44
He very well may have made a "wrong move" (as you put it) by recalibrating the compass, but that would cause loss of directional control, if he was startled by it, not a swim in the water.
It has little to do with needing to be an expert before commenting. It's just that it doesn't even pass the smell test. You parrot this, and then 10 other people are going to read it and start parroting it, and so on. This type of thing is becoming an epidemic and is getting in the way of people getting real answers. If it's not called out it's just going to get worse. Same with the "format your SD card" and "update your firmware" BS. Folks who are having trouble need help, not being asked to waste their time on all sorts of BS things which have no possible way of solving their problem. And worse, it wastes their time and patience. Causing them to get fed up. Obviously that doesn't exactly apply here since the drone is already destroyed.
I totally agree with your response that a compass error wouldn't cause it to fall out of the sky. I have experienced a goofy compass, and my aircraft did some crazy stuff, but yes it kept flying. I was simply mentioning it to him. Sure, I maybe should have said that it was in no way the reason for his bird to fall out of the sky. My bad!
But to that, you don't have to bash us for mentioning it. I also agree with you about how you see a lot of the same things mentioned over and over, and yes it seems a bit much at times to me too. But who am I to tell somebody to not ask a question or give an answer that has been discussed a hundred times. I am not one to do that, but you seem to not be able to stand it. You have the right to voice your opinion as much as the next guy, but I don't think your ranting is helping anyone here.
So, here we are all discussing your comments, and missing the objective of trying to help this guy.
Take a deep breath, and if you don't like what you are reading, don't read.
