Spark and Pixel XL (possibly others) wifi disappearance
1234Next >
41568 129 2017-6-17
Soureal
Flight distance : 58136 ft
Same problem here in Germany with Spark and Galaxy S7 Edge and all other (Android-) Devices. Need to reset Wifi every start. How is it possible from dji to overlook this in the development? Return to dealer in some days...
2017-7-4
fansadb6ab0b
Unfortunate, but glad to find out on this forum instead of in the air :-) Thanks OP for the detailed issue report.
I've only flown it for about 5 minutes, but noticed directly after the initial setup I could not find the Wifi network anymore with my Oneplus 3 (in The Netherlands). I then tried with the RC which worked, at least for the 5 minutes I've used it.
Can anybody confirm if this issue also goes for the connection between smartphone/tablet and the controller?
2017-7-4
JergenPuckel
Sweden
I bought a DJI Spark today, and as I live in Europe, I have the same problem. It's absolutely disgraceful that DJI hasn't made any statement about this critical design error in a week. I will be returning my Spark tomorrow, and I would recommend everyone else unfortunate enough to have bought this in Europe to do the same. This is just not acceptable by any stretch of the imagination.
2017-7-5
jiri.stibor1-sp
Czechia
Returning mine in a week if no update comes. So infuriating. Dji, the clock is ticking.
2017-7-5
Szwedu
Flight distance : 378114 ft
Poland
Where are you , DJI officials ? Don't you hear the roar's. Are you deaf?
2017-7-5
tecnophone
Flight distance : 86608 ft
Same problem in Italy...In addition to the fact that the video transmission disappears after 80 meters with the controller.
It is not tolerable!
2017-7-5
jellybeantech
Flight distance : 108 ft
Yes same issue here, my DJI Spark will be returned tomorrow.
2017-7-5
Perugian
Poland
I was getting worried that my unit is broken in some way, but now - after reading this thread, I see it's a major error by DJI. I'm returning my Spark tomorrow and I'm highly recommending others to do the say. We need to spread the information about it as wide a possible too.
2017-7-5
jiri.stibor1-sp
Czechia
I cannot imagine how must a normal person (for whome is spark made) feel when they get this issue.. DJI I bet you are loosing customer every minute you let this issue be..
2017-7-5
LeChuck71
Flight distance : 68786 ft
It's so sad to read this.
I don't have my combo yet, but it will be returned ASAP if this bug will not be fixed within my 14 days limit - I switched from my race quad because I was sick of all the cables flying around, but Betaflight and all other firmwares did a great job to support a wide range of hardware. Selected DJI because I thought they know what they are doing...
2017-7-5
JergenPuckel
Sweden
LeChuck71 Posted at 2017-7-5 23:18
Yeah, I thought so too, but they must hardly have tested it in Europe at all. I don't understand how they could be have missed such a glaring issue.
2017-7-6
Adomolis
Flight distance : 219219 ft
Funny thing is, when you contact support, they have completely no idea what im telling them and try to give you some random advice.
2017-7-6
Vip1980
this is a DJI forum doesn't anyone from DJI read this forum .....?
2017-7-6
Jack_Sweeney
Flight distance : 634692 ft
Vip1980 Posted at 2017-7-6 12:22
Like 1 administrator pretty much
2017-7-6
robybu
Same issue here, 9 sec reset to get wifi connection (Italy) to the drone every time. Really annoying.
Did not tested yet wifi phone wifi range but reading about problem encountered let me believe that there is a very good marketing without following up real world.
2017-7-6
fansb2281168
Flight distance : 282516 ft
Should this issue not have been fixed in the latest FW? http://forum.dji.com/thread-100387-1-1.html
The change log reads: "Fixed an issue where the remote controller and aircraft couldn't connect in some regions."
How can you tell what FW version your Spark is running?
2017-7-7
daveio
Flight distance : 1890 ft
fansb2281168 Posted at 2017-7-7 08:39
It's definitely not fixed in 01.00.0400. Note that it refers to connection between the remote controller and aircraft - not the mobile device and aircraft.
2017-7-7
djiuser_9m1lPN7
Flight distance : 12710 ft
I'm glad I found this thread. I just bought Spark yesterday and I though I'm stupid because I couldn't figure out why the hell SSID disappears all the time and I have to reset it. This is really bad and shouldn't take place.
2017-7-8
Adomolis
perhaps Moderators could tag this thread to [TOP] as there are more and more owners of Spark unaware of this, so they create new threads without searching.
2017-7-10
Pylomé
Flight distance : 29160 ft
Same problem on mine (Germany).
Got to reset the wifi settings with 3 beeps (9 seconds) before every flight. Very frustrating.
It completely ruins the quick gesture control mode like palm launch, since you won't be able to connect to the drone if gestures (for some reason) wouldnt work . In this case the drone would land / go down (when battery is low) without having control over it. THATS A NO GO! If this won't be fixed within my return period I'll send it back.
2017-7-10
Webdrone
Flight distance : 674938 ft
Waiting for my SparkFlyMore and was interested in finding out how to force 2.4Ghz as I've found that regardless of how congested the environment is 2.4Ghz generally works better than 5.8Ghz, especially for range. It's good to read that there is a "fix" until/if DJI implement such a feature but I'm not totally clear on it :
1. The trick works because the Spark stays on 2.4Ghz after a wifi reset and until it is restarted, at which point it will start it's "swtiching" tactics ?
2. If that's the case it will ensure the remote stays connected on 2.4Ghz too once it's been paired with the 3 second/1 beep method ?
2017-7-12
Borat
Flight distance : 127487 ft
Hi guys,
Same here (France, Galaxy S7), i have to reset wifi (9sec push) every time i start flying.
I guess spamming support might be a way to get an update...
2017-7-12
GCBrent
Flight distance : 66286 ft
fansb2281168 Posted at 2017-7-1 15:18
I'm also having the same problem on Nexus 5x in the UK.
Assuming DJI fixed this issue via FW update, is there any advantage in using 5GHz in EU? It looks like we will get significantly reduced transmission distance using 5GHz. See image below from the manual.
I am in a "CE" country and my iPhone 6 and spark use the 5.8GHz frequency most the time (as default, wish they would actually set 2.4GHz as standard!). Just using my phone I get it out to its limit of 80m. Waiting on my RC still...
2017-7-12
fans9708f972
fansbc09a9fc Posted at 2017-7-1 23:14
I'm having the same problem. Having to reset the WiFi settings using the 9 second button press. Disappointed. I've got 2 devices S7 Edge(2.4+5GHz) and an old Hudll (2.4GHz).Getting the same thing on both. For its initial connection everything worked fine but then it said "switching WiFi you your country" and that's when it misbehaves.
After resetting the WiFi it connects on 2.4GHz. Dji needs a solution that remembers that for next time to save that so resetting is not required.
Totally agree. I got my Spark today and find this WiFi connection issue is enough of a pain to return it unless they acknowledge a fix is on the way. Come on DJI! Sort yourself out.
2017-7-13
Peao
I have the same problem (S7 Edge, Germany). Please fix it fast @DJI
But I found another "workaround" for the problem:
Press "Close" once the message pops up that your drone will restart to change local wifi settings (2ghz to 5ghz). It will stay in 2ghz, but you have to answer this message every start, but its more comfortable.
I don't know why the message came again, I didn't factory reset the drone or anything else...
2017-7-14
JockeH
Flight distance : 289 ft
Sweden
Same here, in Sweden and Samsung Note 4.
It works with my wife's iPhone!...
/Jocke
2017-7-17
Mephisto
I'm having exactly the same problem.
Bought a spark in the UK, got a Onpelus 5, oneplus 1 and a Nexus 9, all devices can't see the drone wifi after it is switched off and then back on. The only way around is to reset it to factory settings using the power button pressed for 9 second.
2017-7-17
roverw
Bulgaria
JockeH Posted at 2017-7-17 04:42
/Jocke
Same here in Bulgaria - Spark with Samsung Galaxy S5
2017-7-18
fans2fbb0a68
Flight distance : 7162 ft
Same here in France, mobile phone Xiaomi Redmi Note 4 Global Version (official rom)...
2017-7-18
Mephisto
I've emailed support, no answer yet
2017-7-18
Tabarish
I have the same problem. I live in Spain and I use an android BQ Aquaris X PRO. I have to reset the Wi-Fi settings each time I turn on the Spark.
I hope this issue will be resolved soon.
2017-7-19
Telrin
Flight distance : 29767 ft
There is a good table of the channel allocations here: http://www.radio-electronics.com ... ncies-bandwidth.php
The channels that DJI are using are the correct channels for outdoor Short Range Devices (SRD) in Europe on the 5.8GHz band, so that is not going to change.
Being able to force a 2.4GHz link regardless of congestion would help when using Spark without a controller, but if your device doesn't support channels 149-165 then you are going to get the same problem the other way around when you use the controller, you'll have to use 2.4GHz for the link to your device which forces the controller ot use 5.8GHz for the link from the controller to Spark which then leaves you with reduced range.
Using an OTG cable does solve that part at least, for as long as OTG remains an option.
Fortunately the problem seems limited to Android devices and while DJI pretty much have to remove OTG from iOS devices (due to MFi), there is no imperative to do that for Android...
2017-7-23
Telrin
Szwedu Posted at 2017-6-29 03:24
DJI you didn't know that  WTF?
DJI got it right, your list is not complete.
channels 149-165 are permitted for use in outdoors in ETSI regions for Short Range Devices (SRD) using low power transmissions, which is exactly what Spark is.
The problem is with the phones and tablets that assumed you will only be connecting to indoor devices...
2017-7-23
Borat
FYI, i received this message form the DJI support twitter account after explaining the problem:
"Given your location, EU Android users have reported having issues similar to yours due to the limited channels accessible that are EU specific. For the latter, this has been reported to the development team to address as quickly as possible."
Wait (not too long i hope and see!
2017-7-23
jerdnok
Flight distance : 21864 ft
Czechia
The same problem in Czech republic (Galaxy S7, Galaxy Tab 10.1)
2017-7-23
Brunogr84
Flight distance : 33842 ft
The same in Amsterdam - Netherlands with Samsung S7 Edge. This is F* annoying!!!
2017-7-24
Szwedu
Poland
New firmware and problem persists... We need a petition or what?
2017-7-28
Nealej
Has anyone flown with oppo r9s I can't get Wi-Fi to recognise spark
2017-7-29
fans96d42ff6
Flight distance : 28294 ft
Same in Norway with G5. Even after firmware update. Poop chutes.
2017-7-29
Szwedu
Poland
DJI Mindy Posted at 2017-6-28 00:21
There are a few information I would like to make it clear.
1. On 2.4Ghz, the channels do support everywhere run from 1 to 11, a portion of countries support 1-13 channels, but 14 channel is barely permissible in most countries.
2. 5Ghz frequency include three bands, Spark only support 149-165 channel. Usually channel 36 to channel 48 are used indoors (Spark is recommended to fly outdoors); Channel 52 to channel 140 belong to DFS which will need 1 minute channel availability check time. The most important thing is that indoor channel is not allowed to be used outdoor, with DFS, it would take more than 1 minute to access wifi hotspot.
DJI Mindy , are you now familiar with this problem? we did try our best to explain  this . We fell that you (DJI) turn your back on us and act like there is no problem .
2017-8-3
1234Next >
