OTG WORKS - DJI GO 4 _ 4.2.12 - For Android - 19th April ...
14500 189 2018-4-19
DMX_MLT
Malta
Ricky Aerial Photography Posted at 2018-4-20 00:38
https://www.apkmirror.com/apk/dj ... o-4-4-2-12-release/
With this new version of 4.2.12, Spark is unbeatable, becomes a very cost effective drone. I think Spark sales will go through the roof. Mavic Air may become a headache for DJI sales team. :-)
Thank you for the link Rick.
2018-4-20
djiuser_cGCqi24ohsNH
Flight distance : 3091 ft
Sorry, I´m not good with chinese...
2018-4-20
djiuser_cGCqi24ohsNH Posted at 2018-4-20 01:11
"離線地圖下載" Offline Map Download
"選擇你要下載的地區" Choose Offline Map Area
"下載" Start Download
Use two fingers to zoom in/out the map to select the area.
2018-4-20
DMX_MLT
Malta
Ricky Aerial Photography Posted at 2018-4-20 01:04
Compare 4.2.12 on Spark (force FCC using OTG on Huawei P9 Plus) and Mavic Air (Hong Kong standard version is already in FCC. It belongs to my friend using iPad Mini 4). With the same flight path and distance, 5.8G and with OTG. Mavic Air experienced broken video signal for couple of times while Spark's video feed was smooth. Interesting. We do not know why. Both birds were running in FCC mode.
I do not know why Spark in Hong Kong is defaulted to running in CE mode while Mavic Air is alowed to run in FCC mode??
Hi Ricky maybe it was the 5.8GHz on the Mavic Air ? Did you try test it with 2.4GHz from Remote to Spark ?
In Europe many complain about the 5.8GHz. I once read that 2.4GHz is more Long Wave than 5.8GHz, the range of the 5.8GHz is not incredibly long.
I think US, with FCC and more support for 5.8GHz dont have so many issues, I wish some Americans give us their thoughts.
If it was me, I would try 2.4GHz.
2018-4-20
DMX_MLT Posted at 2018-4-20 02:01
During the comparison, I observed that Mavic Air connected to RC using 5.8G at takeoff. As the signal was getting weaker, Mavic Air automatically changed to  2.4G.  Signal was strong but the video transmission became broken two times. Spark using 4.2.12 stayed on 5.8G throughout the testing.
I asked my friend whether this was a usual behaviour, i.e. auto changing from 5.8G to 2.4G, of Mavic Air. He said that it was but sometimes experienced broken video with good signal, but do not know why?
The comparision test was done in highly interference urban area, may be Mavic Air got a strong interference during the flight.
2018-4-20
DMX_MLT
Malta
I see, Thank you Rick for clarifying it.
2018-4-20
In the test fly area this morning, I did not dare to try on 2.4G. 2.4G was everywhere ,some with very strong signal. 5.8G was the safer way to go if flying in Hong Kong urban area. Hong Kong urban area is a concrete jungle with dual band (2.4G and 5.8G) wifi routers in every household/resturants/shops and etc., and with plenty of powerful 4G transmitters /repeaters installed on rooftops.
2018-4-20
DMX_MLT
Malta
Range was the same Rick on 5.8GHz or less ?
When flying in Urban Areas there is a lot of polluted noise in WIFI Signals as there is lot of Traffic.
2018-4-20
DMX_MLT Posted at 2018-4-20 02:56
The Mavic Air while on 5.8G was stable and video lagging was acceptable. Broken video only happened after the Mavic Air auto changed to 2.4G. Although the signal was nearly full, if the video became broken, it was no point to fly any further.
Spark 4.2.12 stayed on 5.8G with nearly full signal and smooth video throughout the test. In urban area, I am not dare to push Spark further than 250m with a height of 120m. In urban area, I must fly to maximum height to get good signal and hope that the Spark/RC can be free from interference.
2018-4-20
DMX_MLT
Malta
Thanks Rick ! Very happy to talk to you Buddy !
2018-4-20
munchausen
Flight distance : 890217 ft
DMX_MLT Posted at 2018-4-20 01:03
Ohhh I see. Good Point.
May I ask if you use Android or IPhone please ?
I'm on Nexus 5X. I simply go for airplane mode, it does _not_ turn off GPS, only BT, WIFI and mobile.
If i'd want something else, I have arranged the notification bar shortcuts the way that these toggles are the first, so I don't have to look for them.
2018-4-20
pabloevaristo
Ricky Aerial Photography Posted at 2018-4-20 01:18
"下載" Start Download
Can´t find any "Offline Map Download" in the DJI GO 4 (v4.2.8) ....
2018-4-20
DMX_MLT
Malta
munchausen Posted at 2018-4-20 03:27
Thank you so much Munchausen !
2018-4-20
S-e-ven
Flight distance : 5922034 ft
Thailand
The apkmirror Go4 4.2.12 seem to be a tablet app (20.xxxxx)
I could install it on my Huawei Tab, but not on my OnePlus5 yet.
On the tablet it seems to work, only indoor check, no start.
2018-4-20
DMX_MLT
Malta
S-e-ven Posted at 2018-4-20 04:26
Hi Seven, do you use OTG with this app because thats my biggest concern ! Thank you for sharing your knowledge buddy !
First time we talk, I read a lot of posts you posted, they are very informative and helpful !
2018-4-20
S-e-ven
Thailand
DMX_MLT Posted at 2018-4-20 05:08
OTG is the only thing I tested this app for!
And since my OP5 is complaining (not installed), I have tried on the Mi Redmi Note 4.
Works also, OTG connected, shows Satellites and batt and other stuff.
Like it should.
Will maybe try a fly, 2morrow
2018-4-20
Junior SBC
Flight distance : 476483 ft
Brazil
pabloevaristo Posted at 2018-4-20 03:37
Sorry, the map offline is in 4.2.12 version. To the v. 4.2.8 is necessary to use 3G/4G connection, the map is online.
2018-4-20
DMX_MLT
Malta
S-e-ven Posted at 2018-4-20 05:19
OTG is the only thing, I tested this app for!
Very good news indeed ! Thank you !
2018-4-20
S-e-ven
Thailand
DMX_MLT Posted at 2018-4-20 07:19
but right now, since I have the app on my flight device, I read a lot.
And a lot about connection losses.
Just, like always, it is very difficult to find out if iOS or Android!
DJI:
What was with the change for posts, like "select topic", a "select OS" or a "must check" box before posting
android [ ]
iOS         [ ]
PLEASE!
2018-4-20
DMX_MLT
Malta
S-e-ven Posted at 2018-4-20 08:35
I will try Samsung 8+ with OTG and latest version, if it gives me touble I will think I will go IOS for less problems.
2018-4-20
Vyborny83
Flight distance : 166014 ft
Czechia
Ok, another find. Apparently, the problem with the WiFi channels I have is not related to the DJI GO 4 App but the firmware. I have downgraded to DJI GO 4 4.1.14 and still can't see anything. I tried to downgrade Sparks FW but the oldest version I can see in DJI Assistant 2 is 01.00.0701. Is there a way to downgrade back to 01.00.0600 that is apparenly the last one that works for me ? Thanks.
2018-4-20
S-e-ven
Thailand
Actually, I was surprised
I saw the wifi channels with red and greens. On both devices, I think.
Did not do screenshots, but will check if I have flightweather, 2morrow
But also I saw 13 channels, only I am in a 2-3km area. Which should be FCC, methinks
Needs to be checked, methinks
Edit: Spark on latest firmware, .900
2018-4-20
Vyborny83
Czechia
S-e-ven Posted at 2018-4-20 08:56
Well I have tested .900 and .701 and in happens on both. I didn't expect that I won't have an option to downgrade to .600 anymore ... Hopefully somebody knows how to do it.
2018-4-20
S-e-ven
Thailand
But if I really can see the chanels with cable, which I could not with other apps before, it is unlikely that the birds firmware has anything to do with it.
I will check that 2morrow!
And I am anyway certain, the readings are from what the RC can see , not the AC.
2018-4-20
DMX_MLT
Malta
FCC has got 11 Channels
CE has got 13 Channels
Correct me if I am wrong.
2018-4-20
DMX_MLT
Malta
Vyborny83 Posted at 2018-4-20 08:51
Did you have the WIFI problem arise now when you upgraded to 4.2.12 ?
Did you do The Spark Firmware update when you upgraded to 4.2.12 ?
With the Version 4.1.14 you where using the Firmware 01.00.0600 ?
2018-4-20
S-e-ven
Thailand
DMX_MLT Posted at 2018-4-20 09:25
Yep, that is the official version.
Ok, it can be, I have one or two wifis around, using also chanel 12 and 13.
Maybe the new app shows what it detects?
2018-4-20
Vyborny83
Czechia
S-e-ven Posted at 2018-4-20 09:20
All I know is that I can see the WiFi channel info just fine with .600 firmware and I can't see it with any newer one. In fact, I do remember some trouble like that last year when .701 was released, I just didn't care back then since I had a choice to downgrade back to .600. I didn't expect to see this bug six months later in .900 as well ...
2018-4-20
Sparky Sparkinson
Flight distance : 5614 ft
I side loaded 4.2.12 from APK Mirror. OTG Worked perfectly on my Pixel XL and I was able to unlock a flight zone from within the app for the first time.
I was flying with WiFi turned off but the app was still able to use cell data with the OTG active.
So far this seems like a huge improvement!
2018-4-20
Junior SBC
Brazil
djiuser_cGCqi24ohsNH Posted at 2018-4-19 23:26
how do you have the maps offline?
Hi, sorry my delay... I saw our friend Ricky Aerial aswered your question. Thanks.
2018-4-20
Tested 4.2.12 again today with wifi connection only. No OTG. Follow the same flight path. Video was smooth. I could not find any difference in video quality, using OTG or wifi connection. Throughout the test, 5.8G signal was strong and reliable. Video was continuous and response  instantly when the gimbal moved up/down and was flying sideways.
From now on, fly with wifi connection between RC and phone can be trusted. :-) I give five stars rating to this version.
2018-4-22
djiuser_Kf4iPA3DtL3S
Flight distance : 510968 ft
Israel
Ricky Aerial Photography Posted at 2018-4-22 03:30
Do you use the version that's on APK? the tablet version?
I don't see a phone version. Was there ever one available?
2018-4-22
DMX_MLT
Malta
Hi Rick ! Thank you for the update, I will test them both to test as well.
Are you flying in FCC Mode ? BTW do I leave the Video Cache on so the phone will cache the Streaming footage too please, just in case it crashes and need to see where the last connection was ?
Thanks Rick, Darryl
2018-4-22
DJI apk mirror, installed on Huawei P9 Plus, android 7.0 phone. There is only one version in the APK mirror, I am unsure whether it was a tablet or phone version. It can be successfully installed on Huawei anyway. I use Fake GPS to force DJI GO 4 to run in FCC mode.
Before the flight, I do the following on Huawei:
1) Turn on areoplane mode with wifi on.
2) Do a complete phone cleanup using Huawei phone cleaning utility.
3) Do not allow any background apk running.
4) Enable GPU hardware decoding.
5) Enable maximum brightness.
I do the following on DJI GO 4:
1) cleanup the video cache.
2) rotate the Spark 360 degree with hand to ensure no IMU/Compass errors.
2018-4-22
DMX_MLT
Malta
Ricky Aerial Photography Posted at 2018-4-22 04:12
Thanks Rick,
When they upload on APK Mirror usually in the Description there is Written - For Phone or For Tablet. Right ? Any other way someone know how to know which is which ?
Cheers Rick and Thanks Again !
2018-4-22
Israel
If I recall correctrly - then generally speaking, variants beginning with 1 are for phones, those that begin with 2 are for tablet.
2018-4-22
DMX_MLT
Malta
djiuser_Kf4iPA3DtL3S Posted at 2018-4-22 04:18
Shalom brother, yes I read this once, just wanted to make sure. You are 100% Correct.
2018-4-22
DMX_MLT
Malta
DJI GO 4--For drones since P4 4.2.12
April 18, 2018
DJI GO 4--For drones since P4 4.2.8
March 25, 2018
DJI GO 4--For drones since P4 4.2.6
February 8, 2018
Seems these latest 3 Versions of the DJI GO4 only have 1 Variant available.
2018-4-22
DMX_MLT
Malta
Rick if you use airplane with Wifi on only, you switch off the GPS on the Phone ?
Does the Spark need GPS on the Phone ?
2018-4-22
DMX_MLT
Malta
Can you explain how I can do these Rick -
Thank you !
For example my Samsung has the GOPro app always running in background. It takes part of the RAM Memory searching for the Wifi of the GOPro Camera to SYNC with Phone.
2018-4-22
