Air 2S New Firmware Release Notes (07/27/2021)
12
14096 68 2021-7-27
Frontliner 2020
Philippines
DJI Stephen Posted at 8-18 21:18
Hi there Frontliner 2020. Thank you for the reply and you are very much welcome. Have a safe and a happy flying always.  .
you are welcome...
2021-8-19
Miguel Leitao
Flight distance : 1977067 ft
Portugal
djiuser_j0fPT46NRS1l Posted at 8-19 00:52
Why do i get laging and the occasional crash with my air 2 s. Ever since the last update. Will this problem be fixed on the next update?
Are you using fly app 1.4.8?
If you are try going back to 1.4.4 abd see if it makes any difference.
2021-8-20
djiuser_mdi0tQfQ3Yew
Russia
Avatargood Posted at 8-18 11:18
Hello.
After the update, error 30064 appeared, the drone does not take off.
What should I do in this case?
I have the same error
2021-8-21
Russia
I have an error 30068  after update firmware. Drone doesn’t take off. Also indicated 30016 error and 180037 error
2021-8-21
Lomaka
Flight distance : 149738 ft
My drone hit the wall himself.... its Really amazing. After the last Update, i start to fly- turning back ( just pushed left joystick on the right , he started to turning on 180 grad, then he just starting fly on the left side , and hit the wall.  After  i get vision sensor error :Code: 180043. I already taked in contact with  support. I will send it for verification , and analysis. will see what happened....
2021-8-25
Flight distance : 1548599 ft
Miguel Leitao Posted at 8-20 06:57
I am using 1.4.8 (1185) i was using (1120) seems to have improved a fair bit. no more app crashes at least. Just a bit of lag.
2021-8-30
bjr981s
Flight distance : 139698 ft
DJI Stephen Posted at 7-27 21:10
Hello there Frontliner 2020. You are very much welcome and if you have any inquiries with regards to this new update. Please feel free to post it here at DJI Forum. We are all here to help and assist you. thank you.
Stephen,
Can you advise how I can configure my Air 2S to less than 9 days. 9 days is dangerous and damaging to the batteries. 5 days was already too long 12hours would be appropriate at a max delay.
Can you also advise why this change was made to what end. Damaging everyones batteries is only driving battery sales.
2021-9-5
rollzroyce
Flight distance : 196995 ft
Help! I just activated my new Air2S and I cannot take off, or do much of anything. The drone is stuck and will not let me update anything, when I am connected with the remote the software gives a timeout message when trying to manually update my firmware. I also connected with USB on DJI Assistant and it gives me a similar server error. It's like it's rejecting server access internally. Is there a way to manually hard reset the drone via button press/hold or hidden reset that doesn't require DJI Assistant?
2021-9-5
dr6583
Flight distance : 490627 ft
Possibly it could be telling the truth.......there may be a network error at the router (or beyond) at your end.  The first one relates to WiFi the second to the network, i.e. the router itself.  Any trouble by chance with other devices and your network/WiFi?   Or is it just this WiFi device and app (DJI Assistant)?  And do you have it connected by cable to the computer?  Edit---I see now you did say USB.....
2021-9-5
djiuser_oSuehWLxblvz
My name is Nathan I am from Herndon Virginia, Can you guys please make it possible that while flying we can stream live via Facebook and YouTube just like Mavic pro 2 . Please make it possible so we can enjoy more the DJI Air2s .
2021-9-5
DASPhotos
Flight distance : 5589232 ft
Turkey
Hi, I am using air 2s. I take off after RTH is determined, it does not allow me to go above 30 meters. After down it again and turning off the device and the remote, I can fly normally when I turn it on and take off again. I experience this at every departure point. I've looked through all the settings and can't find a setting that solves this. I did not have such a problem with Mavic 2 pro. Is there anyone who can help? Thanks.
2021-9-10
Graphite
Flight distance : 629642 ft
Portugal
Please make tripod available, or at least control spedd on cinemode, its very fast to do slow  movements...
2021-9-17
dr6583
DASPhotos Posted at 9-10 03:27
This may sound obvious, but have you checked the max altitude in the Fly app during each pre-flight.....sometimes I've seen mine seem to change on its own.
2021-9-18
fans1a94fbbc
Flight distance : 1414 ft
Portugal
Having problems to connect to my pc after a firmware update… help me please
2021-9-24
doglaboi
Flight distance : 766234 ft
Suriname
djiuser_j0fPT46NRS1l Posted at 8-30 02:33
Where did you get 1185 from? When I download the file name still says 1120. Didn't they update the file name to correspond to the version?
2021-9-25
Mobilehomer
Flight distance : 18150351 ft
doglaboi Posted at 9-25 14:10
Here - https://drive.google.com/drive/u ... pW_LB7UDL6GevH4WVg5
Use the last one.
2021-9-25
doglaboi
Suriname
Thanks for the download, are these official DJI downloads? 4 different 1.4.8 versions and still not working correctly???
2021-9-26
Mobilehomer
doglaboi Posted at 9-26 02:50
I haven't tried the others, but the 1185 version has official after the numbers once installed. It is a beta version. It does work better than the others.
2021-9-26
fans1d784eec
Can we get active track with dlog please.  The performances of active track is so amazing it’s a shame we can’t use it professionally because it can’t shot dlog.
2021-9-29
djiuser_CByg6tD7YbYo
Will DJI Fly do all the updates including firmware we need? Some of the material makes it seem we need DJI assistant 2?
2021-10-5
AkDroneFlyer
Flight distance : 1295082 ft
I know this has already been asked but there has been no response so I’m going to ask again.
Why change auto discharge of the battery to start after 9 days?!! Everyone who knows anything about LiPos knows that 5 days is too long!!! It should be up to the user and be adjustable as is in Go4. This is a good way to loose customers.
2021-10-7
fansa1f7ca43
Flight distance : 509639 ft
Anyone have any advice on how to enable Touch Screen gimbal controls one Air 2s? I have a Samsung S21 Ultra but no ability to control gimbal with screen. Only with the wheel. If I touch the screen it tries to go into tracking mode. Thank you in advance
2021-10-8
Washblue
I downloaded firmware on the morning of 10/8/2021 and haven't been able to view videos or pictures since...
I spent all day trying different things...
2021-10-8
Washblue
I downloaded new firmware the morning of 10/8/2021 and haven't been able to view a video since...
Codec problems, several different computers say...
2021-10-8
Raw_B
Flight distance : 1494190 ft
thanks for the info!
2021-10-10
fans1adbdd02
Why would I want to take a chance of updating , when my done is fine? Seems kind of silly to take a chance of screwing it up with a update that I'm not getting much out of.
2021-10-12
fans1adbdd02
I've not updated since I bought my air2s the day it came out and I've had no problems.  Why would I want to update, I don't like to fixing things that aren't broke
2021-10-14
john.motchbtconnect.com
New air 2s firmware v02.04.2080 just released.   Fixes flight safety issues
2021-10-15
djiuser_M1x4tKqkBIyV
Romania
hello. i have the exact same  error.   brand new 2S ,made he firmware update, and I have te same error... no mor than 30 m.    what can I do?   Did you fix it yours? thank you
2021-12-27
12
