snatch
djiuser_c2IR4N2vfEQg Posted at 1-8 13:12
You can enable high Tempurature mode by using an app called "Fake GPS Location" which is a free app in the Google Play Store. I've not found a similar app in the Apple App Store so this only works on Android phones. All you need to do is start the Fake GPS app, set a locaton outside of the UK/EU, I set a location in New York. Start the DJI Mimo app and connect to your Action 2 Camera. This will fool your camera that it's outside the UK/EU and you should then be able to enable the High Temp setting, then disconnect from the DJI Mimi app. This setting will remain in the camera and can switch modes back and forth as long as you don't go into the DJI Mimo App using a UK/EU location. If you do, you can use the Fake GPS app again to re-enable it again. I also tried this trick but high temperature remains disabled.. |
