Bashy
Flight distance : 2354357 ft
TheBoy Posted at 6-7 12:34
If you're thinking about the controller pointing the right way, I've been doing this a long time.
As it happens, the compass on the DJI RC is pretty unreliable, so never expect the controller orientation on the radar map to be pointing the right way.
Even though the RC indicator does not always point where it should on that controller, the arrow on that indicator will still turn green when there's good alignment, just an FYI
Also, I'm not just on about on the horizontal plain, even more so vertically because there is no helpful indicator for that. From what i can gather, the Mini 3 Pro is very sensitive to alignment, so even though the screen is probably at a nice viewing angle of what 45º 'ish, that means the antennas are pointing into space, if the drone is say 1km at say 400ft (120m) high, the angle of the RC needs to be lower than that comfortable viewing angle, and if the sun is out, your instincts will be to raise that angle more.
Just remember, from your position on the ground, the horizon is less that 5km away, that would mean that if the drone was 4km away, you would be pointing that RC so that the screen is pretty much flat, if there are structures, trees, hills etc along your flightpath then at that will scupper the signals LOS. This is how sensitive that this mini 3 is.
Just food for thought is all, I'm not trying to teach you how to suck eggs, just that this time it seems to be more precise between RC and drone. |
