hallmark007
Flight distance : 10186312 ft
IMU will notify if it needs updating and you can see in your app the health of your IMU. But there have been many myths over the years about calibration of the IMU after FW or SW updates but these are only myths.
My understanding was and in most cases still is, although with new tech and better hardware for the most it’s probably not a good idea to continually mess about with it.
IMU "Inertial measurement unit" .
As far as I see it, IMU calibration on a level surf as a reference for a level stationary hover. From there the craft responds predictably to flight commands. It also likely measures any sensor noise and thermal drift so that these technical imperfections are accounted for when using IMU sensor data in flight. - this is likely why there must be no vibrations during the calibration process.
Bad IMU calibration could cause drift and attitude issues as the flight controller fights to hold the craft in what it thinks is the correct attitude as opposed to the correct physical attitude.
The IMU usually has 2 types of sensors – angle and acceleration and in turn 3 sensors of each type measuring in the X,Y and Z axis. These sensors can, through vibration, aging, impact etc, drift in their response over time and thus an IMU calibration will establish a new reference for the IMU’s level/stationary state that the flight controller can work with to restore stable flight.
Think of calibration as the bringing back into line the measured craft attitude with the true physical craft attitude.
As to how often an IMU calibration is needed, Refer to your manual ; |
