JJB*
Flight distance : 12566335 ft
Burt37 Posted at 4-11 03:17
Yes, that was the one...
If I got to be honest, My Mini3P has never been very accurate in returning to the exact same spot after a fly. There is always a bit of difference maybe 20-50cm, but I never got an audio message...
Hi Burt,
There is a misunderstanding about GPS accurancy, if your GPS is off few meters from the actual takeoff spot and during flight GPS quality remains the same, than it will land on the same spot, often with some cm away from the spot.
But if you look on GE and spot the LatLon....than you see the real offset.
So find a nice spot for launch wich is a good landmark on GE map, and check after flight the LatLon landings data from the log on the map, you will be surprised sometimes. ;-)
Ofcourse no audio message, as HP data stored in the drone is not changed.
cheers
JJB |
