Recommendations for a Tablet For Use with Inspire 1 PLEASE
123Next >
35955 99 2014-11-24
AVNes
Perfect! Thanks for passing on the information.
2014-12-20
AcesAreWld
The Inspire1 uses built-in GPS (to the QuadCopter, not the remote) to set it's initial home point. If you want dynamic home point, see page 23 of the draft manual that clearly states:
2.7 Dynamic Home Point
Dynamic home point is useful in situations when you are in motion and require a Home point that is different from the
takeoff point. Dynamic home point is only available to the GPS-enabled mobile device. Turn on GPS and data service
to obtain higher accuracy of the mobile device position. The Home point will be reset to position of the mobile device at specific time intervals. Select Dynamic Home Point from the “Camera” page in DJI Pilot App.
So you only need GPS in you iPad if you want dynamic home point.  I'm not sure how it shows your spot on the map while flying though (does it used cached maps and the Inspire1 sending back its GPS position?)
2014-12-20
rbendjebar
Flight distance : 3170190 ft
AcesAreWld Posted at 2014-12-21 10:50
The Inspire1 uses built-in GPS (to the QuadCopter, not the remote) to set it's initial home point. I ...
You're wrong. Tahoe Ed has answered this on another forum (RCGroups), stating that there is GPS capability in the controller, meaning that a WiFi iPad is all that is necessary. If there is GPS in the Tx, then dynamic home point is available, as well. Lots of errors in that draft manual.
2014-12-20
AcesAreWld
rbendjebar Posted at 2014-12-21 14:16
You're wrong. Tahoe Ed has answered this on another forum (RCGroups), stating that there is GPS cap ...
I hope so... that would be neat, but I just can't believe they would have GPS in the remote. It just seems unnecessarily redundant and more expensive, but we'll see.
2014-12-20
redleader
This is extra cool and should really be touted more as a feature of the system, having GPS built into the controller is a pretty big deal!
2014-12-20
AVNes
How about for the Slave unit... Will the original iPad Mini work? That what I'm currently using with my Lightbridge and no problems at all.
Would be looking at running an iPad Mini 3 with the Master and iPad Mini as the Slave unit.
Anyone?
2014-12-20
hmerkel
Flight distance : 2307995 ft
I dont think the ipad mini will work, I believe that there is a minimum requirement for an A7 processor to run the app, the mini has an A5 processor so it will not run the app.
2014-12-21
Tahoe_Ed
Flight distance : 2605 ft
The iPad mini with Retina display works and has the A7 processor.  That is why you don't believe everything that is in a draft manual, that is why they call them "draft".  This error has been corrected in the newest draft manual.  The Tx has a GPS module that allows for Dynamic Home Point.
2014-12-21
Plouf1er
Hello Tahoe_Ed !
Thank you for your posts.
At some point,  Will an iPhone 6 or 6 plus Work ?
I tend to do all outside work on my 6 plus despite of my iPad mini.
So using the 6 plus would simplifiy even more the charging management by removing an external (and costative for some) élément.
Thank you for your help here !
2014-12-21
AVNes
Tablet Options?
I'm sure it's probably on this forum somewhere, but couldn't find it.
Can some please list the tablet options outside of iPads that...
A. Works with the Inspire 1 app.
B. Fits in the tablet holder on controller.
Currently own an iPad mini and looking to get two new platforms. Just not sure which route to go with right now, looking for options and choices.
Thanks in advance.
2014-12-22
Tahoe_Ed
The maximum size is the iPad Air.  The minimum processor is the A7.
2014-12-23
skyml
Flight distance : 4741906 ft
Tahoe_Ed Posted at 2014-12-23 21:38
So the iPad mini with the A5 won't work?
2014-12-23
jazzinman
the specs page lists the ipad 4 as compatible which runs on a a6x. Has that changed?
2014-12-23
AVNes
Hey Ed -
Thank you for the response. I am aware of the iPad mini and Air specs needed for the Inspire 1 App, but seeking your advice on what Android tablets you have seen or know that will work with the Inspire 1 app as well.
Example: Samsung - Galaxy Tab 4 8.0 or Samsung - Galaxy Tab 4 7.0
Thanks in advance.
2014-12-23
Tahoe_Ed
AVNes Posted at 2014-12-24 02:34
Hey Ed -
Thank you for the response. I am aware of the iPad mini and Air specs needed for the Insp ...
I know some are using the Tab 5.  I use the S4 as well as my iPad mini.
2014-12-23
Tahoe_Ed
jazzinman Posted at 2014-12-24 01:05
It will probably work but my experience is that you need the most processing power that you can get.
2014-12-23
svencool
Flight distance : 6690 ft
Tahoe_Ed Posted at 2014-12-24 07:03
It will probably work but my experience is that you need the most processing power that you can ge ...
Ed will the Ipad Mini 3's cable plug into the transmitter? It's not USB
2014-12-23
Tahoe_Ed
svencool Posted at 2014-12-24 09:24
The Lightening cable has a USB end as well as the lightening end.  It works.  I just purchased a 3 pack of 8" cables for less than $9.  They seem to be the perfect length.
2014-12-23
svencool
Tahoe_Ed Posted at 2014-12-24 10:12
The Lightening cable has a USB end as well as the lightening end.  It works.  I just purchased a 3 ...
Thanks Ed...
2014-12-23
CHASE
shouldn't the listed compatible tablets for lightbridge be compatible with the INSPIRE ?
2014-12-24
AVNes
Tahoe_Ed Posted at 2014-12-24 07:02
Thanks Ed.
2014-12-24
AVNes
CHASE Posted at 2014-12-25 06:58
CHASE -
Thats what I was hoping for. If that was the case, I would only have to purchase 1 additional mini. But by the sounds of it, my current iPad Mini that I use with Lightbridge will not work with the Inspire 1 App.
2014-12-24
pimezon1
is Inspire compatable wth Ipad AIR 2 ?
2014-12-26
cmontisano
pimezon1@hotmai Posted at 2014-12-27 04:40
Yes believe me that cost me allot of money, I purchase two, don't ask me how I know I just know that you cant go wrong with the iPad air 2..
2014-12-26
misticsea
Flight distance : 87228484 ft
I found this on ebay Aputure vs-1hdmi 7 does any fourm members know if this will work will with our new inspire 1 thanks
2014-12-27
lucasfernandezm
Chile
when we release the application clear what the most appropriate tablet
2014-12-27
pauldean85
I wonder if my Xperia Z2 tablet will be compatible, the Z3 is, so here's hoping...
2014-12-27
travissrt
Flight distance : 68555177 ft
Has anyone tried an LG G Pad?  I have the 7" version
2014-12-27
rodger
Flight distance : 20145135 ft
The holder for your tablet will fit anything from an iPhone to an iPad. It is adjustable. I received this info from DJI.
2014-12-27
travissrt
My concern is not the size but will the app run on my LG pad
2014-12-27
AVNes
travissrt@gmail Posted at 2014-12-28 00:41
That's exactly my thought... Not worried about the bracket. I want to make sure that it can run the app.
2014-12-27
travissrt
Wish someone from dji could advise.  I have until Monday to return this tablet then i'm stuck with it...
Thankfully I got to test it yesterday on a live Inspire and it works great!
2014-12-27
dale.kaechler
Hello Tahoe_Ed
Should I have WiFi and cellular turned on in my iPad 4 ?
2014-12-31
CHASE
Tahoe_Ed Posted at 2014-12-21 19:21
The iPad mini with Retina display works and has the A7 processor.  That is why you don't believe eve ...
Hello Sir...I would like to know if it is possible to fit the SAMSUNG TAB S in holder, it is 6.96 inches wide compared to iPad air 2 - 6.6 inches .  Thank You
2015-1-1
Tahoe_Ed
CHASE Posted at 2015-1-1 22:52
Hello Sir...I would like to know if it is possible to fit the SAMSUNG TAB S in holder, it is 6.96  ...
170mm max is all I see on mine.
2015-1-1
bernsch
Flight distance : 211657 ft
Does anybody know if the Samsung Galaxy S 10.5 works with the Inspire 1 and how you can make the tablet holder to fit the Galaxy S 10.5 tablet.
I know maximum is 170 mm and the Galaxy S 10.5 is 177 mm. Thanks!
2015-1-2
CHASE
Thank You Sir..!!!..Will be purchasing an iPad air 2 64 gb..Do you know of anyone offering training in northern N.J. ?...Thank You
2015-1-2
rutchmann
I've installed pilot on my Samsung tab 3 android 4.4.2 and so far so good (even though it is no in the compatible devices list in the play store...i.e. downloaded and installed directly from DJI).  Dont have my copter yet but will find out if fully functional next week hopefully.
2015-1-2
Blade_Strike
Flight distance : 872694 ft
Guys -
Think of it as base to recommended requirements. Yes it will run on a iPad4 but to get decent latency and performance you will need a higher end device.
iOS app seems to be more CPU dependent(A7 or higher), where the android is more RAM dependent(2gig)
2015-1-2
carlosmh305
Nvidia Shield (Android 4.4.2) Quad core is another option for powerful graphics and  memory.(gaming tablet)
2015-1-2
123Next >
