DJI Assistant 2 Incompatible with Mac OS Catalina a Disgrace
1234Next >
49070 134 2020-1-12
Farva
Cannot get DJI Assistant 2 to install on Catalina 10.15.5. I manually installed the horndis driver and the DJI install seems to complete, but it is not installed. Please help!
2020-8-14
djiuser_iOV1WE04gX8P
DJI Mindy Posted at 1-12 19:59
We apologize for the difficulties on installing DJI Assistant 2, I have sent you PM, please check, thank you.
Please send me one. I need to active for my DJI unit air
2020-8-19
Mikael Sweden
Flight distance : 350627 ft
Sweden
Farva Posted at 8-14 07:49
Go into system settings on you Mac, then under security and integrity. Under common you should se that you need to allow in bottom for the driver..
2020-8-24
djiuser_tapXmsK5afOG
South Africa
DJI Mindy Posted at 4-23 04:31
Good to know it works in the end, nice try, hope you enjoy flying.
no, it is not working, Keep having problem with the driver. Still telling me that is incompatible with catalina
2020-8-27
PeterSweden
Sweden
I used DJI Assistant 2 For Phantom to connect my Phantom 4 Pro+ and did all calibrationstuff in Catalina. After updating firmware via the controller app DJi Go the  DJI Assistant 2 wont find my drone anymore.
I can live with the fact that i do the controller and drone upgrades in DJI Go but i must upgrade my DJI Goggles in DJI Assistant 2 or?
I have also tryed DJI Assistant 2 For Phantom on a MacBook Pro with Sierra but same problem.
Please tell me what to do.
2020-8-30
WebParrot
Flight distance : 23625 ft
Jeff402 Posted at 2-5 16:05
I really can't believe DJI expects people to ignore every Catalina security warning!  HEY - large companies will not allow people to do this!!  To say this is unacceptable is rather an understatement, and unless it's resolved in the immediate future we'll be removing all our DJI drones.
Here's my very sad chat with DJI Support:
[ I realize this is an old reply, but just getting around to reading stuff that used to be important }
WHY are you using a company computer to play with your toy?  Seems like just using any non-business related software or connectivity (downloading information from a drone would violate EVERY company system security policy in existence).
While I agree, requiring a customer to circumvent security to operate their software is egregious, your practices and behaviors are no less contributory.  Me thinks you're B-S-ing the whole work computer thing. :-)
2020-8-31
PeterSweden
Sweden
I like the DJI products very much and i don't want to be one who just whines. The firmware update/calibration stuff is nothing i will have to do every other day so i will simply borrow a PC with Windows 10, install Assistant on it and do what i need to do.
I will let you know how i went
2020-9-3
fansedd6a8df
DJI Mindy Posted at 2-24 20:08
Since so may customers have the same problem with the Mac OS Catalina, I will post the workaround in public.
Please click Quit when the Mac pops up HoRNDIS is not compatible, exit the installation of the driver, then download the driver installation package below separately, and then double-click the PKG file to install it after decompression. After the installation is successful, it should be used normally.
https://github.com/jwise/HoRNDIS/files/3719733/HoRNDIS-9.2-catalina_install.pkg.zip
I tried this and it still does not work. Everything installs and then there is no DJI Assistant 2 App present on the computer. Rebooted, reinstalled, everything I could do I tried.
I even loaded up the DJI Assist 2 app in a Windows VM. When I try it there I get another error about not being able to detect the screen size. I give it the screen size and then the app doesnt show what is is supposed to show to calibrate.
Your software is buggy on 2 different OS's.
My Mavik Air is now a brick
Is using this buggy software the only way to calibrate the Vision on my drone?
2020-9-3
MicroDOC
Flight distance : 79 ft
I have the same problem. With two drones I cannot fly because they won't update. I have tried Mindy's solution #2 and it doesn't work. What we need is a serious update to the application. It's been about two years and that's unacceptable. Please provide a solution. With all the drones and other robotic equipment DJI has you'd think they could provide maintenance software that actually works for their products...
2020-9-6
fanscaee3aed
Thailand
https://www.loom.com/share/37d788b845974b62890401c05f838cf7
2020-9-25
fanscaee3aed
Thailand
Covert23 Posted at 4-10 17:38
so, i did this .. istalled the HoRNDIS 9.2, restarted, then tried to re-run the dji assistant .pkg file . . and at the end it says i need to install the HoRNDIS file . . . which I had already done! So I'm not sure how to proceed. Does ANYONE have a good, CLEAR step--by-step guide to do this? I have both .pkg files -- DJI Assistant and HoRNDIS 9.2 -- sitting in my downloads folder.
This is an annoying run around I too installed the hoRNDIS file why can they just make it all a DMG file for macs and so here is a  link to a screen grab . What a mash up .
2020-9-25
fanscaee3aed
Thailand
Executing: /usr/bin/kmutil install --volume-root /Library/Extensions/HoRNDIS.kext --check-rebuild
/Library/Extensions/HoRNDIS.kext is not a volume root, skipping rebuild
kmutil done
Does not install
2020-9-27
fanscaee3aed
Thailand
DJI Mindy Posted at 2-24 20:16
Hi Jeff402, we are terribly sorry for the unpleasant experience, I have posted the workaround in 2# and we will also make sure this resolution has been spreaded to our support team.
Please keep us updated if you have any other concerns.
kmutil done
This is after downloading the link you posted Mindy ?
kmutil done
loom video showing the failure process ?
2020-9-27
fanscaee3aed
Thailand
does not work for me see below
2020-9-28
fanscaee3aed
Thailand
same for me
2020-9-28
fanscaee3aed
Thailand
djiuser_M3diKNv6RUAI Posted at 4-20 15:27
Oh and also....Tried the Horndis workaround that the DJI person posted and although it loaded it still doesn't work
This worked for me
Please follow the steps in order.
1. Uninstall the DJI Assistant 2.
2. Restart your computer.
3. Download the DJI Assistant 2 on the matrice section thru this link: https://www.dji.com/downloads/so ... t-dji-2-for-matrice and
install it. then uninstall it ..
4. Restart your computer.
5. Download and install the DJI Assistant 2 on the mavic section thru this link: https://www.dji.com/downloads/softwares/assistant-dji-2-for-mavic
6. Restart the computer and the issue should be rectified.
2020-9-29
fanscaee3aed
Thailand
2020-9-29
RHodsonPhotogra
Flight distance : 11404 ft
I purchased the DJI Smart Controller as soon as I found out that it would now work with my Mavic Air 2. I was so excited to use it that I immediately went to download DJI Assistant 2 to my iMac running Catalina 10.15.7. When I tried to open it Safari fait it couldn't open it. So I did the next logical thing and went to the Forum and saw your post. However, when I tried to open the link / download from here I received the following “HoRNDIS-9.2 2.pkg” cannot be opened because it is from an unidentified developer". Did I just spend over $800 (with tax) on something I cannot use??
2020-9-29
GarWood58
Finally a logical response to “JUST OVERRIDE YOUR COMPUTER SECURITY”! I decided whatever this download provides in never going to be worth compromising my Mac system. 2 questions beg to be answered. Why does DJI not follow Apple developer protocol?  What prevented Apple from endorsing this
software if it was in fact submitted? I will wait for answers before installing anything not recommended.
I love the DJI Product and will only buy this brand, but only at acceptable security measures.
2020-10-12
alloffroad
Flight distance : 6339409 ft
need to reset my Mavic Air Firmware for control as i have constant beeping, cant get controller to connect with remote, installed latest version of Assistant 2.0.14 and it comes up with this.
It amazes me that a multi million $ company is unable to provide a working app for their products!!
2020-10-17
WKHTTH
Flight distance : 163438 ft
I'm on a Mac as well and the easiest way for me to get around this is -- If you have already used bootcamp to make a windows partition - instal Assistant 2 on the windows partition and your all set ready to go -- If you dont have a partition made using bootcamp - make one, you will find having a windows partition on your Mac can solve a lot of headaches when it comes to programs of all kinds. .. If it dont work on Mac, use windows partition - much faster than all these work arounds.
2020-11-3
poembrunch
Thailand
thank you for your information  I really appreciate this! ร้านค้าบิทคอยน์www.classemap.com
2020-11-4
poozaa
Thailand
ขอขอบคุณข้อมูลของคุณหัวข้อนี้ช่วยฉันได้มากเกินไปสำหรับการแก้ปัญหายินดีต้อนรับสู่ Batman999
2020-11-6
poozaa
Thailand
นื่องจากลูกค้าอาจมีปัญหาเดียวกันกับ Mac OS Catalina ฉันจะโพสต์วิธีแก้ปัญหานี้ในที่สาธารณะ โปรดคลิกออกเมื่อ Mac ปรากฏขึ้น HoRNDIS ไม่เข้ากันให้ออกจากการติดตั้งไดรเวอร์จากนั้นดาวน์โหลดแพ็คเกจการติดตั้งไดรเวอร์ด้านล่างแยกต่างหากจากนั้นดับเบิลคลิกที่ไฟล์ PKG เพื่อติดตั้งหลังจากคลายการบีบอัด หลังจากติดตั้งสำเร็จควรใช้งานได้ตามปกติ Batman999<br /><a >สล็อตออนไลน์บนมือถือ</a><br /><br />
2020-11-6
BarkBoy
Flight distance : 40978 ft
I can't open the download as my MAC computer said it does not have an application to run the programme!!!!?
2020-11-14
Robbie777
Slovenia
fuck off DJI  team !!!!  I spent $ 2,000 to buy a new drone, and you can't provide mac catalina software, I'm angry, fack you !!!
2020-12-9
Robbie777
Slovenia
2020-12-9
Robbie777
Slovenia
2020-12-9
Robbie777
Slovenia
2020-12-9
WKHTTH
I dont understand why this is an issue. - I run Catalina as well and I am having no problems at all. . People using a MAC, go into your utilities and run BOOTCAMP. Instal a version of windows on a partition and when its done, boot into your windows partition, download the assistant program from DJI and use the program. Simple.Using BOOTCAMP is not hard at all.
If you dont have a copy of windows, torrent one with a activation key and instal it.
Problem solved.
Sure it would be easier if we didnt have to do this but there is a work around without all the coding that some are doing.
BOOTCAMP - the best workaround for lots of programs you want but cant use on a MAC , now you can.
Try it.
2020-12-11
Adrian G
New Zealand
SOLUTION
I have DJI Assistant for Mavic working fine with my DJI Mavic Mini Air 2 on my MacOSX Catalina. I struggled for hours, but finally this worked for me:
1. Download and install DJI Assistant for Mavic for Mac.
2. Make sure you install the driver from post #2 (https://github.com/jwise/HoRNDIS/files/3719733/HoRNDIS-9.2-catalina_install.pkg.zip). Don't forget to reboot.
3. After reboot, go to your System Preferences > Security and privacy > General tab > Click the lock to make changes (and type your password if needed), and if this page says that the system blocked the driver, make sure to authorize it, and just to be safe, reboot again.
4. Important: make extra sure you are using the USB cable provided with your drone. I was using a USB C cable (on both ends of the cable), and this failed. Using the cable provided with your drone (i.e., USB C on one end and USB-A on the other end), everything worked fine. Note that you may need to use a USB-A to USB-C adapter to connect to your MacBook (google "usb a to usb c adaptor").
5. After reboot, start DJI Assistant for Mavic, turn your drone on and pray!
6. If this doesn't suffice, follow the other instructions people posted, like popping out the SD card and plugging it back in just when the drone boots up. I didn't have to do this though, the previous steps were enough.
Hope this helps!
2020-12-20
Bob_Dempsey
Flight distance : 1140364 ft
This has been a problem for over a year! DJI please fix this - a year??? totally not fair to the Macintosh community
2021-1-4
djiuser_R6nhlxPAJHrt
I need the answer. Again it’s 2021. Don’t know why/how this isn’t corrected by now. These things aren’t cheap.
2021-1-7
Chispita
DJI Mindy Posted at 2020-2-24 20:08
I just tried the workouround provided then got this message: A program tried to load new system extension(s) signed by “Joshua Wise” that need to be updated by the developer.
I am still unable to update my Spark on my updated Mac.
2021-1-20
djiuser_M9XSCDv2U1l1
I have the same issue please DM with how this can be resolved. Thank you
2021-1-25
djiuser_VhZh2N7fmpg7
Flight distance : 35738704 ft
Dji sucks. Either your computer or phone is to new and not compatible or,,, well it's usually just the person's fault and dji will never take responsibility for the failure of their technology, staff or design. Buyer's be warned, but if your in a forum it's usually too late.
2021-1-26
RGMGFitness
Flight distance : 233757 ft
Opened an ONLINE CHAT with DJI Tech Support.  I was informed by DJI, that for MAC OS users (specifically macOS Catalina Version) users would need to go to;   SYSTEM PREFERENCES , then Security & Privacy , Click OPEN ANYWAY (or ALLOW) and "Continue" to start the installation.
I've tested and this fix does work!   Seems to be an ONGOING issue with anyone running MAC OS "Catalina Version" (which is an older version of MAC OS).
2021-1-30
djiuser_HbUm2h6cAQl6
Can you please send me the workaround to install the DJI assistant 2 on my MacOS Big Sur- it’s also telling me it “cannot be opened because it is from an unidentified developer”
I also tried downloading HoRNDIS from your previous link but was unsuccessful
Please help!
2021-2-3
djiuser_HbUm2h6cAQl6 Posted at 2-3 10:43
Please help!
Also after updating everything I now cannot use DJI GO 4 app on my smart controller- it’s telling me the current device cannot use the app and to download the correct one?
2021-2-3
Bill Foster
The instructions say you need an android phone for this to work.  I have an iphone, not android. Any more ideas?
2021-2-6
1234Next >
