Jakab Gipsz
Hungary
SaleKlar Posted at 11-6 03:00
I had this same problem. It would fly some time then start droping suddenly, sometimes if i do not push it up constantly it would drop on ground. I thought its a sensor problem, then battery problem (as i tried changing battery and sometime it would fly with no problem, but then when same battery is placed again problem would persist) i tried reseting, updating firmware for everything, but nothing coul help.
.... then i changed propellers ... at a time i used 3th party fancy transparent propelers, that was working for a while but got worn out or damaged ... placed original propellers again and it works all fine For me, he did the same with the original accessories.
Many people already believed that it was solved one way or another but in many cases the problem returned.
read this: I would recommend my theory to you. Mine did the same, once all the propellers broke because it landed roughly, in just I pushed the stick up. I managed to fix mine: https://forum.dji.com/forum.php? ... &extra=page%3D1
