hallmark007
Flight distance : 10017858 ft
timothy_tw Posted at 2017-7-25 07:43
Exact same thing just happened to me about 15 mins ago, I was flying in Gesture Mode but it didn't quite work due to low light, so I took over control manually and flew it forward to increase altitude to about 40m. All of the sudden my Spark started flying backward on its own and despite my enter to correct its course nothing seems to able to stop it from going backward. It finally flew into 2/F parking of my apartment, bump into the wall and crashed upside down, thank god it crashed in the 2/F floor car park, if it were to fall down from that height, I'll be out in the market looking for a new drone by now.
When I picked up my crashed drone, the first thing I notice was the Compass Calibration indicator is in FULL BAR (900+) and it saids it needed calibration (which I did the same morning in the same spot). Given that I was in a car park, I just took my drone and went home. Once I got home I took my Spark out for calibration, and the indicator dropped to 9 (Excellent) without me doing anything, I took the drone downstairs back to that same spot in the car park, Compass Calibration is perfectly normal.
First you said you did compass calibration before you flew why?
Second you took off with minimum amount of satellites, and during your flight it didn't get any better, I presume you were using you phone or tablet as your log shows no stick movements,
This is one of the first cases I've seen where gps was lost were you flying at night or in an area of high buildings .
Your Aircraft went into Atti mode once for a short time you received a warning, it regained gps you probably should have tried to land, but continued, you lost gps a second time and AC went into Atti mode it's impossible to know if it had any reaction to your control movements as they are not recorded in your log, your aircraft was not moving that fast but was drifting all the time until it crashed.
You really need a minimum of 10 satellites to operate comfortably, you should never fly far on 5,6,7 satellites. I don't use the phone much but I do know if you had RC you could have easily managed to land safely.
Regarding compass asking to be calibrated this is most likely due to your crash, compass was fine until you crashed.
Hope your craft is ok and still flying I will leave a link below that might help with future flights. Good luck.
https://forum.dji.com/forum.php? ... &fromuid=260008 |
