Aardvark
Flight distance : 384432 ft
Imovetheearth Posted at 2017-8-4 04:20
Took flight yesterday morning for at least 1/2 hour. I had no issues with the video link. There wasn't one glitch. Anyway, yes, I did update RC and did that first. If I have any more issues, I will do a factory reset, but does that require me to go through the process of updating both the RC and the P4 again. I guess that only makes sense.
Thanks!!
"but does that require me to go through the process of updating both the RC and the P4 again."
The factory reset wouldn't I don't think, that resets aircraft though Assistant 2, and doesn't take long if I remember.
The RC can be reset and relinked as follows:-
* Turn on the controller, the aircraft should be off.
* Press C1, C2, and shutter (top right button nearest antenna) on the controller and hold for about 2 seconds or so until it beeps (D-DDD), then turn the controller off.
* Turn on both the aircraft and the controller and link the remote if needed.
This can be done manually (without using DJI Go):-
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button (top left button) on the controller, then the controller will beep 'D-DD'.
*Let go all fingers, then press the wheel on the right side of the controller (It's a 'click wheel', similar to a mouse wheel) and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will link soon.
