Over Temp Compass and GPS lost 2nd Flight @ 6min
12
3613 52 2017-7-25
Arcicorsa
Flight distance : 235892 ft
Czechia
Lian82 Posted at 2017-7-31 15:23
mmmh my temp is HOT
https://healthydrones.com/main?f ... d=POWERBattery_Info
You have mistake in link... You link is to my flight..
2017-7-31
Arcicorsa
Czechia
SparkySurvey Posted at 2017-7-31 15:29
I have the RC antennas at 45deg up and I am facing the drone at all times. The greatest distance I have ever gotten away from myself horizontally has been 80m, greatest height 100m. In Australia we have a 120m ceiling for drone operation and have to remain at least 30m away from anyone who is not operating the drone. This gives me a flight height range of 35m-120m vertical and given the small size of spark probably
45 deg is wrong !! You must have antenna on 90 deg and target flat antenna side on drone (not top of the antenna on drone) !! You understand?
2017-7-31
Arcicorsa
Czechia
An example of the right direction .. I apologize for the quality :-).
2017-7-31
SparkySurvey
Flight distance : 1770289 ft
Arcicorsa Posted at 2017-7-31 15:53
Ok will see if that improves things today. What is the recommendation if the drone is basically over head? And if the drone is at a point on your image above the left hand star so at 45deg out in front of you? Should I tilt the controller?
Thanks for the assistance.
2017-7-31
SparkySurvey
Oh and thank you for the tip on HealthyDrones. That is brilliant! I like to keep records.
2017-7-31
Arcicorsa
Czechia
SparkySurvey Posted at 2017-7-31 16:05
Yes, you aim flat part of antenna all time to drone.
2017-7-31
DJI Diana
Flight distance : 2408 ft
SparkySurvey Posted at 2017-7-31 14:46
Do you need the vision logs? These are very large files and I don't have an unlimited dropbox account.
No need to upload the vision logs now. Our engineers are looking into the data now. If we need more info, I'll get back to you.
2017-8-1
SparkySurvey
Arcicorsa Posted at 2017-7-31 16:12
Ok Tested this today with an OTG cable and the connection was solid for both flights. I flew both with about 10min break between down to 30% battery, out to 80m horizontal and vertical. No drop outs or errors. It is a different system with antennas oriented and iPhone wifi turned off. Thanks for your time and help, this is what a forum should be.
2017-8-2
Indi91
Flight distance : 103973 ft
SparkySurvey Posted at 2017-8-2 16:43
Thats a beautiful shot!
2017-8-2
Arcicorsa
Czechia
I'm glad to I helped You. I wish You lots of good shots!
2017-8-2
SparkySurvey
Indi91 Posted at 2017-8-2 18:07
Thanks, the weather has been spectacular for the last month.
2017-8-3
SparkySurvey
Arcicorsa Posted at 2017-8-2 22:33
I got lots of good shots yesterday.. Processed this product in Pix4D for a little bushland site. Plenty of detail and texture. It's a shame that DJI downgraded the capability of the geotagging and SRT files on Spark. The sensor is actually quiet nice.
2017-8-3
wisnia.sebastia
Sorry for your experience,  I  have look into the log , the temperature seems to be ok. There was obvious magnetic-field interference from the ground when compared with the condition in air.  So this happened when it land near ground. This is ok, if you change for another clear place.  For the temperature warnning,  I would like to get a app shot then I can go on with it.
2017-8-8
12
