LobsterOfTruth
DJI Diana Posted at 2017-8-11 02:51
Copy that, Please refer to the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2.Upgrade the firmware V1.3.8.10 or V1.3.8.11.
Again, thank you Diana! This worked perfectly!
Here's a detailed description of what I did to update:
1. First, I connected with DJI Go to format the Mavic's SD card. This may not be necessary (and make sure you don't delete something you may still need!)
2. Then I deinstalled Assistant 2 on my PC and reinstalled it (This is probably also not necessary, but after a week of trying, you get paranoid). Make sure you get the newest version since at the time of this writing, DJI has 2 versions in the download section.
3. After that, I activated the remote, let it wirelessly connect to the Mavic and then connected the remote to the PC by USB.
4. Login to the account that DJI has enabled for the special beta firmware.
5. Choose the beta firmware you were told to use and start the update. It seems that this special firmware version was .350 in the past, I was told to use .810 or .811. Used the latter.
6. After the beta firmware update finishes, press "Record" on the remote (upper left shoulder button). For me it didn't work the first time I pressed it, since my Mavic was restarting in that moment. I pressed it again and the "REC" symbol in the remote's display started flashing.
7. Start the actual update with the latest firmware and watch the percentage counter go where you never saw it going - done.
Maybe that will help somebody. |
