Firmware upgrade always fails, please help!
1234Next >
8195 123 2017-8-7
LobsterOfTruth
Hello DJI.
I bought a Mavic Pro and wanted to update it to the newest firmware before flying, but no matter if I try updating through DJI Go on my phone or the Assistant (tried both on a Mac and a PC, with different USB cables...), it won't work... It always stops at 76% on DJI Go and at 68% on Assistant. After a while the drone restarts and it says "Upgrade failed". I have been trying it for two days for at least 20 times with the various methods...
The RC is now on .900, but I can't get the AC to update.
On the forum, I read of similar problems and that it worked after you enabled the .350 beta firmware in their account. They were told to downgrade to that first and upgrade to .900 after. Could you enable that beta firmware .350 for me too?
2017-8-7
DJI Diana
Flight distance : 2408 ft
Could you please tell what error message you've got when you failed to upgrade the firmware via DJI Assistant 2? Please post a screenshot.
2017-8-7
LobsterOfTruth
Forgot to mention: My AC is stuck on .400
2017-8-7
LobsterOfTruth
Hello Diana,
I attached a screenshot.
Error is "undefined 0x020106"...
Thank you for your help!
2017-8-8
NE.UK
Flight distance : 25371 ft
DJI either have reset something on your account
Try the following  until they sort it...
Create a new account with DJI and log in with that then upgrade,
I helped DJI solve this issue they never thanked me
2017-8-8
LobsterOfTruth
Thank you NE.UK!
Sadly I have to report that this didn't work either... For some reason, the new account produced the same error... at least through Assistant. Haven't yet tried DJI Go with the new account though.
2017-8-8
LobsterOfTruth
@DJI: Any advice? I'm rather disappointed with my purchase and regret getting Care Refresh for a drone I can't fly...
2017-8-8
LobsterOfTruth
DJI Diana Posted at 2017-8-7 22:18
I posted the info you requested below your reply.
I'm sorry if I seem pushy, but I bought my drone for a trip to iceland in 2 weeks and I'm worried I won't be able to fix this firmware issue until then...
2017-8-9
DJI Diana
LobsterOfTruth Posted at 2017-8-9 00:20
Sorry for the delay, I didn't see your reply until now, please provide me with your DJI account email, I'll reconfigure your email, then tell you how to upgrade it. Besides, do not forget to click on 'Reply' if you have any further question, then I'll get a reminder, will be able to reply you in time.
2017-8-9
LobsterOfTruth
DJI Diana Posted at 2017-8-9 01:39
Yes, guess I'm still figuring out this forum.
My DJI account email is: torsten(at)daeges.de
Thank you!
2017-8-9
LobsterOfTruth
Hello Diana,
my account is: torsten@daeges.de
Is there any more info you need from me?
2017-8-10
DJI Diana
LobsterOfTruth Posted at 2017-8-10 21:06
Hello Diana,
my account is:
Copy that, Please refer to the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2.Upgrade the firmware V1.3.8.10 or V1.3.8.11.
3. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest one, it will be working.
2017-8-11
LobsterOfTruth
DJI Diana Posted at 2017-8-11 02:51
Thank you so much, will try when I get home!
2017-8-11
LobsterOfTruth
Again, thank you Diana! This worked perfectly!
Here's a detailed description of what I did to update:
1. First, I connected with DJI Go to format the Mavic's SD card. This may not be necessary (and make sure you don't delete something you may still need!)
2. Then I deinstalled Assistant 2 on my PC and reinstalled it (This is probably also not necessary, but after a week of trying, you get paranoid). Make sure you get the newest version since at the time of this writing, DJI has 2 versions in the download section.
3. After that, I activated the remote, let it wirelessly connect to the Mavic and then connected the remote to the PC by USB.
4. Login to the account that DJI has enabled for the special beta firmware.
5. Choose the beta firmware you were told to use and start the update. It seems that this special firmware version was .350 in the past, I was told to use .810 or .811. Used the latter.
6. After the beta firmware update finishes, press "Record" on the remote (upper left shoulder button). For me it didn't work the first time I pressed it, since my Mavic was restarting in that moment. I pressed it again and the "REC" symbol in the remote's display started flashing.
7. Start the actual update with the latest firmware and watch the percentage counter go where you never saw it going - done.
Maybe that will help somebody.
2017-8-11
Tombolian
Flight distance : 675958 ft
Yea!  The 'record' fix is still in play!!! (Fixed me back in May).
2017-8-11
black_climber
Russia
Dear DJI, I have the same problem as LobsterOfTruth. Could you please upgrade my account as well to fix it? Sent PM to Diana.
2017-8-12
DJI Diana
LobsterOfTruth Posted at 2017-8-11 07:36
Glad to hear that, hope you can enjoy the drone, and thanks for your sharing!
2017-8-12
DJI Diana
black_climber Posted at 2017-8-12 03:21
What error code you've got when you are failed to upgrade the firmware via DJI Assistant 2, the same as LobsterOftruth?
2017-8-12
black_climber
Russia
DJI Diana Posted at 2017-8-12 23:13
Yes, the same!
2017-8-14
DJI Diana
Ok, done,  please refer to the steps below to upgrade it via the DJI Assistant 2 again.
2017-8-14
black_climber
Russia
DJI Diana Posted at 2017-8-14 23:49
Dear Diana,
I have no neither V01.03.08.10 nor V01.3.8.11 in the list, still V01.03.08.00 and V01.03.09.00
My account is if@adventuretravel.ru
2017-8-17
DJI Diana
black_climber Posted at 2017-8-17 03:48
Dear Diana,
My account is
I've reconfigured your DJI Account already, could you try it again? If it is the same, please provide me a screenshot, I'll double check it on Monday.
2017-8-19
black_climber
Russia
DJI Diana Posted at 2017-8-19 03:13
Dear Diana,
Here is the screenshot:
2017-8-19
fans41ebcafb
Maybe your connection is slow.
2017-8-19
carleido
Hi, my mavic not update from .400, allways error.
Please help me for upgrade .900
thank
2017-8-19
fansf4334088
Dominican Republic
Hello Diana, can't downgrade mavic pro and after the last update camera won't focus so I'm trying to downgrade and It fails at 53%, please help!
2017-8-19
fansf4334088
Dominican Republic
fansf4334088 Posted at 2017-8-19 17:27
Hello Diana, can't downgrade mavic pro and after the last update camera won't focus so I'm trying to downgrade and It fails at 53%, please help! [view_image][view_image]
I'm attaching the image of the error code 0x20104
2017-8-19
fansf4334088
Dominican Republic
fansf4334088 Posted at 2017-8-19 17:29
[view_image]
email: sebaserulle@gmail.com
2017-8-19
DJI Diana
black_climber Posted at 2017-8-19 03:30
Dear Diana,
Here is the screenshot:[view_image]
I've double confirmed, I've reconfigured it, could you please reinstall the DJI Assistant 2, then try it again, if it is the same, could you please use another email to register a new DJI account, then I can try to reconfigure the new account.
2017-8-19
DJI Diana
carleido Posted at 2017-8-19 16:32
What is the error message on the DJI Assistant 2? What is your DJI account email?
2017-8-19
DJI Diana
[view_image]
I am so sorry to say that this method may not be able to solve your issue, As for the focus issue, could you please provide more details? I'd like to see if there is anything we can do to solve this issue.
2017-8-19
carleido
DJI Diana Posted at 2017-8-19 23:46
Hi Diana, thank you for support..
I think my problem is the same as others, everything works but it does not update: 0x020106.
Not updabe becouse reply error and back to default firmware.
My account is: ******
I wait your support for resolve and update from .400 to .900.
Best regards
2017-8-20
fansf4334088
Dominican Republic
DJI Diana Posted at 2017-8-19 23:53
The drone camera was fine before the last update release, and now I can't downgrade nor refresh the version, always gives me the error code.
2017-8-20
fansf4334088
Dominican Republic
fansf4334088 Posted at 2017-8-20 12:10
I'm also getting a gimbal disconnected message.
2017-8-20
fansf4334088
Dominican Republic
can you suggest a place for an inspection? I live in the Dominican Republic, thanks!
2017-8-20
DJI Diana
fansf4334088 Posted at 2017-8-20 14:06
Please refer to the link below to contact the Support, they will help you to deal with it. You may need to send it in for diagnosis.  http://www.dji.com/support
2017-8-20
Dougb 9
This seeks to be a wide spread problem.
2017-8-20
Dougb 9
This seems to be a wide spread problem.
2017-8-20
DJI Diana
carleido Posted at 2017-8-20 05:00
2017-8-20
djiuser_fghHyzC
Russia
DJI Diana Posted at 2017-8-19 23:45
Dear Diana,
Reinstall DJI Assistance didn't help, so my new account is newar@mail.ru.
2017-8-21
1234Next >
