Battery logging
3100 4 2017-12-8
Q-Man
South Africa
HI Guys
Hope someone can help me! Or let me ask first.
i operate a Matrice 100 and 600
is there a way that one can check how to log battery voltages before and after flights. i want to be able to get a full report of how many times the battery has been used and for how long the battery was used for per flight(Flight times) etc.
Is there a way that i can check it?
If there is can someone please explain to me how i can get this info
2017-12-8
broadlandboy
Flight distance : 1654222 ft
If flying under dji App sync flights & use https://airdata.com/
2017-12-8
ROBERM19
Flight distance : 839160 ft
a failsafe option is to pull the log files off the aircraft and write a script to give you that information, but the dji go app will give you battery health information just by checking that tab. its failsafe because if you're using a different app, say UgCS on the UAV, it wont save anything to the tablet. just the aircraft.
for more in depth information the logs are what you want.
2017-12-8
DJI Elektra
Hi, sir. I would recommend you export the data through DJI Assistant 2 and use DataViewer to view the record.
2017-12-10
PilotCOE1
broadlandboy Posted at 2017-12-8 03:53
thank you for the information
2023-7-5
