Gerry1124
Parrish
Do all your calibrations the first time with your Phantom connected, including the X1 calibration. Make sure you select (upgraded version) then click on the start button for your sticks, then finish when you are done. Then click on the start button at the right for (sticks monitor) and move the thumb wheel to the extreme positions. Then click finish when you are done. Disconnect everything from the computer and have everything powered on with the props off and check everything. Check the gimbal wheel and check the movement of the camera. If it is jumpy, do the ( stand alone ) calibration again. |
