I also have this "jello" problem. I have tested now to do every tips and trix but still the videos look like some one very drunk have filmed ;-)
So is it worth to wait on a FW update or is the only way to get it repaired ??
My first P3 Professional were the charger corrupt so I did have to wait and ended up with that I returned that.
And now my second P3 Professional have the "jello" and strange gimbal sound...
Im expecting a little more quality for the price!!
Do you mean the vibrating landing gear or the camera gently move to one side then back to center?The camera movement is normal I think, you can change a place and try again.
And did you push the aircraft down when power it on?
Do you mean the vibrating landing gear or the camera gently move to one side then ba ...
Hi Autumn
Yes i mean the gimbal moving to one side and then at the end of the starting progress suddenly going in the position where is supposed to be going
And yes i did push it a little downwards
Whereever i do this it starts up like this.
My brother in law got a phantom3 pro like me and when he starts up the phantom everything is normal without the gimbal / camera moving to one side.
Everything looks ok - it fly's like a beauty - filming is just perfect - im a happy customer (finally)
But when, in the future, the gimbal stays in de "moving position" and not going back to the place where it supposed to be going, you do understand that "i will be back "
Regards
Richard
I am also trying to figure it out because I find sometimes my P3 also act the same behavior, but sometimes not. I start to think about maybe it caused by I changed its direction before start it up.
Hello, mabye someone can help me here? EU support does not respond me for ona week, I don't know what to do. I bought Phantom3 Pro on the 13th of April, it was delivered on the 4th of May. Since that time I had an opportunity to use it only for two weeks because camera turned to the left and stayed in this position. I connected with EU support team, they advice me to wait for firmware update. I was waiting for 3 weeks, when updated nothing changed, but became worse. Drone started flying very loud, started loosing high, sometimes does circle, at first not big but then bigger and bigger. Because of all these reasons I couldn't take it on vocation. I payed 1499 EUR, but I can't use it normally, only make filters and control tests. I would like to replace it on the new one Drone or get the money back. Hope to hear from you as soon as possible. THNX
Ciao hai risolto il problema??? dji continua ad affermare che i casi di guasto gimball sono veramente pochi, ho i miei dubbi, seguendo i vari forum e youtube vedo che i casi aumentano ogni giorno.
