English Nomad In Oz
Lonesome Crow Posted at 2018-5-15 15:07
Do you by chance have a lens filter installed? If you do, with the MP turned off, remove the filter, then restart the MP. Then let us know the results. Reason I am asking is due to my MP did something very similar to what you are describing . My filter for some reason was causing it. Once removed, restarted, it was fine.
If this does not fix, I would recommend started a case with DJI.
I tried removing the filter, this did not change the problem, same errors and same erratic gimbal.
I need to get this fixed or replaced ASAP.
Mike |
