Ronin 2's New firmware issue ** Remote controller **
9597 15 2018-7-17
onaib_br
Flight distance : 18507 ft
Brazil
Hi
I upgrade my ronin 2 to V01.03.00.60, after that ronin 2 controller (R2-TX1) cannot connect to ronin 2. I can't even bind it to Ronin! I got it working back again after downgrade Ronin 2 to V01.02.00.50.
Should I upgrade remote? How do I do that? There is no instructions on DJI's website!
2018-7-17
Noadventure
Just bought the Force Pro.
VERY light on instructions for setup. I’m updating the firmware to all my tools now (gimbal, joystick, Force). Nothing happening yet.
I could use a tutorial or some less vague instruction.
2018-7-17
onaib_br
Brazil
Noadventure Posted at 2018-7-17 14:17
I did this (twice!!!)
1 - upgrade ronin to 01.03.00.60 version
2 - controller stop working
3 - try to bind - not working
4 - downgrade ronin to 01.02.00.50
5 - controller still not working
6 - bind successfully!!!
2018-7-17
Hi, onaib_br, sorry for the difficulties with Ronin 2, the RC will need to be updated as well, please connect RC to DJI Pro Assistant for Ronin with Type-C and update the RC, then try to link them again. Please let us know if it helps, thank you.
2018-7-18
onaib_br
Brazil
DJI Mindy Posted at 2018-7-18 02:18
Thanks! I was using Assistant 2 (for drones). It does upgrade Ronin 2 but not remote! So I did download the right Assistant version (for Ronin 2) and it worked flawless! Thanks!
2018-7-19
onaib_br Posted at 2018-7-19 04:47
Glad to know the issue was able to be figured out, please let us know if there is any other problem.
2018-7-23
LUMINARIO
Flight distance : 169925 ft
I also had this issue and needed the DJI assistant to upgrade all the firmware. I did have problems with logging into DJI Assist bc of networking problems. Please advise.
2018-9-1
Flo the Pirate
Austria
got the same set up working ... ronin is on the latest update , force doesn´t want to upgrade also the dji assistant shows that there is a new firmware.
i had problems updating the ronin 2/joystick controller on a mac but it worked on windows so I tried the same with the force pro as the update failed ...  but no success.
2018-9-2
Flo the Pirate
Austria
DJI Mindy Posted at 2018-7-23 00:01
as it seems there are two different dji assistants - which one do we need to update force pro to V01.01 ?
2018-9-2
Flo the Pirate Posted at 2018-9-2 04:18
Hi there, the correct software is DJI Pro Assistant For Ronin, please download here: https://www.dji.com/force-pro/info#downloads
2018-9-3
LUMINARIO Posted at 2018-9-1 12:47
Hi LUMINARIO, may I know which device are you referring to?
2018-9-3
LUMINARIO
DJI Mindy Posted at 2018-9-3 01:30
Christian at DJI Burbank was able to update both firmware (Ronin + RC) a week ago. all ok now.
But for some reason, I kept on getting a network error when using DJI Assitant 2 on my Mac OS.  it gives me a network error - with wifi.  I cannot log in for further updates.  is this a networking issue?
2018-9-3
LUMINARIO Posted at 2018-9-3 13:40
Hi LUMINARIO, there was a server glitch on 1st, Sept but it has been addressed, if you still have the same issue, may I have the version of your assistant software? Any chance to upload a screenshot here? Thank you in advance.
2018-9-4
ArturV
Argentina
hey, so the newest version (V01.03.00.60) gives ronin a lot of stiffness issues. What I mean by that, is after an upgrade the Smoothtrack mode starts to be not smooth at all, pan tilt wiggles a lot (and theres always a an electric noise coming from motors). And let me tell you that I played a lot with stiffness/strength/control/filter configuration. The only thing that stops that is to leave the Speed and Acceleration values really low, which limits gimbals functionality by a lot!
So I had to downgrade to V01.02.00.50 where i had some troubles with binding the remote controller and when you use ronin upside down the horizon level drifts a little sometimes and you have to power off and on the gimbal to make it stay horizontal. I can manage working on the V01.02.00.50. version, but it makes me doubt a lot about doing any upgrades at all. Had to reaaaally get in to it to reverse the new update.
hate to be a hater, but you guys doing bad job coding this bi#$&h.
2018-10-14
mattmusz
Hey, my DJI wireless receiver is giving me this error code when I try to refresh/ update the firmware. It is not being recognized by the ronin 2 either. Please advise?
2021-3-17
djiuser_6vV79QSQqQsC
Hi everyone.
I already updated the ronin but the DJI Pro Assistant For Ronin doesn't allow me to update the RC. Here is what I see on my computer.
2022-10-11
