Filipe Coutinho
Portugal
alexmbraMav Posted at 2020-6-12 05:41
I just notice this problem with the Osmo Pocket. But for me it does not start right away.
I was recording a video for more or less one hour. It was created 9 files of 3,80 GB.
But the out of sync problem only shows up on the last two files.
Same here. I just filmed a one hour DJ Set. I used 4 cameras. 2 DJI Pocket, filming at 2.7K / 30fps, a DJI Osmo Action filming at 1080p / 30fps and a SJCAM also at 1080p / 30fps.
I tried it all... I synce all four cameras by a initial clap. It works... but after 20 minutes I start to see that my multicam is not accurate (DJ is touching the mixer in 2 cameras, but on both Pocket, his hands position are quite different - between pockets and the other 2 cameras).
I also tried to use the Premiere Sync... same result. It starts perfect. All 4 cameras all synced... but then, I have 2 still in sync and quite different frames in each Pocket.
Another weird thing is that both Pockets filmed the same amout of time (around 70 minutes non stop). Both did several files... but one of the Pockets footage was divided in 10 mp4 files + 10 LRF files, while the other Pocket only made 9 mp4 files and none LRF Files. Both were using 128GB SD Card, same brand, same speed.
Now I really don't know how to solve this issue.... anyone knows how should I fix it in Premiere? |
