Uncontrollable spinning at roll axis Z15-GH3
1234
14797 127 2014-11-13
DennisMurry08
Flight distance : 5948264 ft
ArasT Posted at 2017-3-26 05:27
I have the GH3 assistant. Do I need to use the GH4 assistant?
If your running gh3 then remove the GH4 assistant...the GH4 gimbal is different and sometimes when you have both installed the assistant gets confused.
2017-4-1
DennisMurry08
Uninstall the GH4 assistant..if you have a gh3 gimbal...I've had my gh3 try to upgrade when I had both installed..after I removed the GH4 then it worked fine..don't forget to restart you computer after removing...in fact if I was doing it I'd remove both, restart, and reinstall the gh3 just to be a clean install. Hope it helps
2017-4-1
fans7c6ec794
Hi Dennis I to have the spinning problem could you send me instructions to pg_desbo@hotmail.com
Thanks
2017-5-12
DennisMurry08
fans7c6ec794 Posted at 2017-5-12 05:40
Thanks
do you have a GH3 or 4 gimbal/camera?
2017-5-16
Brunetti
Flight distance : 108251 ft
Have exact the same problem since 2 days, but with the Z15-A7. In flight, the drone became nearly uncontrollable because of its vibrations.
Would please someone mail me the mysterious instructions? Maybe it's the same issue... THANKS!!
2017-5-30
DennisMurry08
Brunetti Posted at 2017-5-30 11:38
I've never downgraded an A7 gimbal...that said I don't know f the instructions would be the same...Do you know the previous version number that you'd want to downgrade to?
2017-5-30
Brunetti
Hi,
don't know the previous version, I've never upgraded (the Z15 is from feb 17). But I contacted DJI support now, they presume it's a hardware issue and gave me 4 (!) RMAs (LB2, Z15, s900 and A3, the whole thing :-()
Damn, i lost 2 clients since the error.
2017-5-31
Thisdemalo
Hi,
Come back to 2017, does anyone still have the GCU 1.4 downgrade procedure?
In case : thisdemalo@gmail.com
Thanks !
2023-5-30
1234
