hallmark007
Flight distance : 10017858 ft
120ccpm Posted at 4-25 16:38
Yes, sorry I misunderstood your post. You probably misunderstood mine too, as I'm fully aware that this Motor Error warning was introduced with the latest firmware.
Anyways, back to the issue at hand: your theory about mismatched props is very plausible, and would explain a lot of things. The stripes have nothing to do with it, though, as they simply identify which corner the props go on (CW or CCW). Matched pairs have the same raised markings (letter/number, like C3, F2, E3) on the leading edge, and those are very easy to miss. It would be interesting to ask those people who got the error and replaced the props, to check whether they were mismatched or not.
Well I read that storing in the combo bag was the cause, yet I still have my props on since I got the drone and they’re fine, there is a photo of a flat prop doing the rounds here so I decided to put a half prop under a 5kg steel block for two days and when I removed it the prop was almost the same as when I put it under the block and I did it because I couldn’t believe that this flat prop could end up exactly level I mean it just looked so staged , there is a Chinese video on YT I’ve looked but I can’t find it but the video is basically about seeing how much abuse mini will take, but at one stage they cut the ends of two of the props and the mini flew fine.
I know the props are fine but looked after I don’t think they will wear out every couple of months, I have a set of props on an orignal Mavic pro 4 years they’re fine.
I’ve been flying dji drones a long time now, I have never seen or come across a bad batch of props, I may have come across a new prop with a scratch or chip out it but that’s about it.
Also since using dji drones, Mavic mini was the only drone I’ve bought that came with props fixed on . |
