Mini 2 Keeps disconnecting
12Next >
13586 46 2021-4-28
Alan M
Flight distance : 1581581 ft
From the last 2 updates my Mini 2 keeps on disconnecting when I'm only 3 foot away or any distance. The screen will blackout then RTH and after 30 seconds the screen comes back. I've only flown the drone around 6 times in different locations 100 miles apart.
I've raised a ticket with DJI support but not heard a thing yet so I'm wondering if there is a fix or anyone else having this problem.
Thanks
2021-4-28
DJI Stephen
Hello there Alan M. I am sorry for the trouble this has caused and thank you for reaching out. May we know what is the model of the mobile device you are using please? Can you please fly your DJI Mini 2  to a different location to see if the issue will still persist? The said DJI drone might have picked up magnetic interference from the area. That might be the reason why you are experiencing these issues. In addition, I will post a diagram on how to get optimal transmission for your DJI Mini 2. Thank you.
2021-4-28
Alan M
DJI Stephen Posted at 4-28 20:54
[view_image]
Hi Stephen thanks for the reply, I did state I’ve flown the drone in one location and it disconnected and in another which was 100 miles apart. The disconnection is an error with either the controller or craft as I’m only sometimes 4 feet away.
Alan
2021-4-28
djiuser_fORDza3Xufck
Flight distance : 172198 ft
I've been having exactly the same troubles now for months, the drone has become so unreliable I'm afraid to use it for anything that involves a moving subject or water as I have no idea when the app is going to decide to crash. This is not in anyway a user error, this is 100% a software issue. The drone will disconnect randomly in any environment and at any distance from the remote, again rendering the drone nearly inoperable.
2021-7-1
Abel nt
Flight distance : 77398 ft
Here app Crash but controller work., I can fly without app and return/reconnect
Its a problem with software...
2021-7-1
jayaston1988
I have also been finding this random low signal and disconnections when the mini 2 has been 80mtrs above with the transmitter at various angles there’s no pattern and nothing obvious around which would cause interference
2021-8-12
empd3083
Flight distance : 85105 ft
I am also having this issue. I've had the DJI Mini 2 for about one week and experienced this problem multiple times. Randomly and from different geographic locations. I'm willing to work with support and supply flight logs, app data, screenshot photos, whatever is needed to help resolve the issue. Thanks!
2021-8-20
Bashy
Flight distance : 2354357 ft
Not one of you mention (at the very least the top one);
  • device make/model?
  • android version?
  • FCC or CE? (including forced FCC, could be important)
  • was the Fly app upgraded prior to this issue?
  • was the Mini 2 firmware upgraded prior to this issue?
2021-8-20
MBSL500
[view_image]
Are you going to respond with the same answer to the others in this thread
with the same issue?
Your credibility would improve considerably if you would just admit the current Fly App is responsible for the issue...and your crack team of enginneers are working on a fix.
2021-8-20
Bashy
MBSL500 Posted at 8-20 16:36
What folks need to realise is that the DJI staff on the forum are only really Media Relations, they relay messages if and when needed and can only relay information that is given to them, if they have not been told about a fix then they are unable to let us know, however, there is another version of the app available, the info is in one of the other app issue threads.
2021-8-20
TwentyThrill
Flight distance : 257133 ft
South Korea
Had the same problem today, fully disconnected twice while in flight at 100% RC signal, no idea if it's the app, the done or the RC.
2021-9-14
hunterws
Flight distance : 382536 ft
TwentyThrill Posted at 9-14 07:43
It's the app.  Simple math.  Mini2 worked great until the update, now problems.
2021-9-14
simone.rva
Flight distance : 303461 ft
Switzerland
Abel nt Posted at 7-1 01:05
I have been experiencing the same problem.
The drone is a few feet away and all of a sudden the app disconnects but the remote controls work.
Normally the problem resolves when I restart the app.
The problem is clearly software because the drone was very close and the signal very good.
2021-9-15
aclock81
Flight distance : 19370 ft
Hi all, I've the same exact problem with my Mini2 (CE version).
-Latest firmware v01.03.0000 (updated drone, RC and batteries)
-Latest app version (1.4.8)
-iphone 12 pro max
It is currently totally unreliable and I'm scaried to use it as it lose control randomly in all environments (urban or in the middle of nowhere, it doesn't change).
This happens even at a distance of less than 10m and the drone no longer responds to commands and sets the automatic return home (after 20-30 seconds signal return).
I'm subject to this problem since the last month. Earlier I have never had any connection problem.
I really don't know what to do and at the moment I'm using my mini 2 as paperweight as I really don't want to fly unsafely.
Any news from DJI?
2021-9-15
fansdcddbfa5
Dear all,
please note I spoke with DJI assistance and they suggested me to recalibrate the IMU. I've followed the procedure (please ensure to do it in a fresh place and on a perfectly flat surface).
Believe it or not, the last 2 flights were perfect: no disconnections at all!
I really hope this annoying problem will never occur again.
2021-9-22
djiuser_nF9jZxKFO3uj
Flight distance : 533241 ft
India
I am getting the same issue with my mavic air 2 since last 2 weeks I haven't did any update or anything not sure why it's happening. Please help me if anyone know how to fix this.
2022-1-3
Joe Cicero
Has anyone had any luck because I am getting this in my firmware is updated, I even have a new phone, and a new cord that is OEM from DJI and it is still happening. It will fly for about a minute and then disconnect. I either have to unplug it from my phone, or it will return to home automatically.
2022-2-12
djiuser_b8Eu3zy45YvM
This thread gives me hope! My son crashed his/our new Mini 2 drone on the first day operating it saying it lost connection and crashed into the side of our house.  The drone has been sent back to DJI who won’t do anything about it.
2022-2-22
ThreeStar
Flight distance : 33176 ft
I had the same roblem and couldnt resolve it. I sent the drone and controller back to DJI and they found the issue was with the controller and replaced it. Now I have no connectivity issues at all.
2022-2-22
ShiuRao
Flight distance : 185673 ft
New Zealand
2022-2-23
fansb514ad5a
Flight distance : 135453 ft
Trinidad and Tobago
My DJI mini 2 disconnected from the controller in flight and went away and crashed.
This is totally annoying.
2022-6-27
fans8489d44d
Flight distance : 1010446 ft
I have found that it disconnect after about 10 second from start the first recording. If, after reconnect,  you cancel RTH, you can start and stop recording without any issue
2022-7-11
djiuser_L5f7rKxVmeRk
Philippines
I have the same issue. I stored my Drone for nearly 2 months. When I decided to use it it asked me to update which I did. Then I have this issue. 2 meters away then I get disconnected. I found out that when I set it in manual and select 2.4 ghz. The signal is stable. But still I'm not confident flying my Drone.
2022-7-12
fans8489d44d
As i wrote in the other thread, the culprit is the sd card. I replaced the card and I have not had any more disconnections
2022-7-13
Alan M
What SD card did you have? And what did you go to?  Thanks
2022-7-13
fans8489d44d
Sorry, no more problems also with the same sd card but after format on mini2.  There was a corupted file that restart trasmission during fly. Now all works again
2022-7-13
Mr.Cinema
Flight distance : 1105036 ft
Philippines
I have the same issue after updating, and I can prove it with my flight logs before and after updates
and I can only hope for a fix for this problem because as of now I can't fly it without anxiety...
2022-7-21
Mambawamba
Flight distance : 28596 ft
Costa Rica
My mini 2 does the sake, disconnects mid air. All of the sudden
2022-7-25
carlospaivaTV
Flight distance : 214177 ft
Portugal
Mambawamba Posted at 7-25 09:54
people must say , firmware, app version and android or iphone
2022-7-25
fateofangel
Flight distance : 1397238 ft
Poland
I have the same, maybe from the last week, i posted the thread here https://forum.dji.com/forum.php? ... D582%26typeid%3D582
I almost lost my drone during this  glitches https://forum.dji.com/forum.php?mod=viewthread&tid=270053
You all guys have an Iphone?
I am not sure if its not bugging after updating IOS from 1.5.5 to 1.5.6
2022-7-25
FabioV
Flight distance : 980066 ft
fateofangel Posted at 7-25 14:10
The phone app has nothing to do do with RC disconnections. You can pilot your Mini 2 also removing the phone cable. But the phone can generate interferences. I usually suggest to turn into airplane mode when flying.
2022-7-26
FabioV
carlospaivaTV Posted at 7-25 10:32
And also the distance ...
2022-7-26
JJB*
Flight distance : 12477300 ft
Hi,
To have a solid connection you need to have a direct line of sight RC > Drone.
If hampered bt trees etc signal is easily lost....
Flying far and low is recipe for loosing signal as well.
If you stayed during the flight at the starting point i am not surprised to see so many disconnects.
cheers
JJB
2022-7-26
fateofangel
Poland
JJB* Posted at 7-26 08:51
Hi,
we were moving, but as you said terrain was still obstructed when the river curves
2022-7-26
fateofangel
Poland
FabioV Posted at 7-26 08:27
There is a disconection in the title but in the description people says about black screens, it is just loosing the ability to steer, ppl dont know exatly what is happening, that may both happen, signal loose and the app crash combo
2022-7-26
fateofangel
Poland
If you start to fly without the phone it is possible only in 30m distance. I am not sure if it is possible to fly  without app when the phone is lost in further distance.. maybe its just starting RTH - i need to test it, maybe you are right and it is possible to fly "blindly" in manual mode after app crash, i dont know beacuse i was restarting / force exiting it few times, but having the black screen - the cable was connected all the time so it may be not the same situation as you describe
2022-7-26
barry6947
Flight distance : 179311 ft
My Mini SE has just started disconnecting.  I'm using a Samsung S9 Edge, software version 10.  Flew for a few minutes then it displayed that it was disconnected.  Pressed RTH - nothing!  I was over water but had line of sight so I flew it back manually using the map in the bottom left corner.  Would not reconnect until I shut down the drone, the app and the controller and started again.  Same thing happened when only 20 metres away.
2022-8-1
djiuser_TPRkgIP02CM3
Philippines
Same thing that happened to my mini 2. It disconnected in less than 10m. It almost landed on the roof of the house near to me because I took off at the side of the house. The rth took of but i cant control it. Good thing i restarted the remote and before it land it connected to the remote and I maneuver and hand catch it but the roof is only few meters high and the signal is red, not even a bar. Its not the app because im using the old firmware before the war. I dont remember the version and this thing happend. I updated the firmware and flyapp. I also formatted the sd card. I also calibrated the IMU and compass Now and still disconnecting. What else can we Do DJI? Take note we know how to fly this drone I even range test it past 4km in single way before. I never crashed it . Always hand catch it(to avoid dust). How to troubleshoot it DJI? Pls don't send picture how to fly this drone because we already know that. The remote is disconnecting to the drone thats the problem.
2022-11-9
Philippines
I almost lost my mini2 again today. The distance increased when I set it to 2.4Ghz but when i thought everything is ok already i tried to set it back to dual mode and the drone disconnects again. You cant set it back to 2.4Ghz once the remote and the drone disconnects. I flew near the coast this time good thing I updated the homepoint away from water because the rth took off again and i got no control over the drone. All RTH this time. What is taking DJI too long to resolve this or even reply to this thread???
2022-11-9
djiuser_rQbu4ehqKHdY
India
Hi, I am using Mini-2 since 3 months but from last 2 days this same issue happened. The drone and RC get disconnected repeatedly even I put them both closely together.
I have checked the transmission section also in setting. Its in dual band but below the lines were always flactuating. It became so irritating and unreliable now.
I am from India. I have tried the same drone in many areas which are almost 50-70 kms distant but the same problem persists.
It feels like I have wasted mh money on DJI.
Please fix this issue or else atleast provide a solution over online.
2022-11-28
12Next >
