Mark The Droner
Flight distance : 2917 ft
Hello - the first vid shows the standard display of remaining power in the batteries. The bottom batteries are very low - 12% or less. The top battery appears to be okay - a little more than 50% charge.
There is a risk when allowing your battery to drop down as low as 12% or less because a battery cell can be damaged running that low. It's something you want to avoid. If it happens, you want to charge it to at least 50% or so as soon as possible.
There's also the possibility that you're getting a false reading. You can turn the batteries on to check the reading.
When you begin charging a very low battery as shown in the second vid, a blinking lamp of LED 1 is what you would expect to see. If everything is charging correctly, the blinking lamp will turn solid after a while and the next lamp will begin blinking. And so on until all four lamps are solid.
If you leave a low battery on the charger all night and it's charge doesn't improve, it's likely the battery is damaged and should be retired. There are some things to try, but they are very rarely successful.
Good luck |
