DJI Go 4 crashing on start, Galaxy S21+, Android 12
12
32668 42 2021-12-4
Mrobbo1984
Flight distance : 261027 ft
Try out Steve Mack's solution on YouTube - the solution is to download Go4 app from the DJI website and make sure that location is turned on when using the app.
https://youtu.be/DIK9OGsGBFc
After months of hassle and fatigue from lack of support, the location solution has solved it for me now
Using GalaxyNote10 android 12 - solution apparently works for Android 13 too
2023-3-12
Mrobbo1984
2023-3-12
djiuser_amIqnG1qbctu
Nigeria
djiuser_LH7D0J148GV0 Posted at 2022-3-5 14:04
Yes! Same here.
Message says "allow access to external storage and location services so DJI GO can save photos, videos, and flight records, import files to Editor, and display your location on the map"
[Image]
Good day have you been able to fix this issue beacuse I'm having the same issue now, i would be glad if you can share your soultion if you have one. Thanks
1-21 04:06
12
