osmo 5 flickering
987 2 2022-2-20
Ginopino
Flight distance : 873100 ft
Hi everybody
is it normale that the osmo 5, when rotating, with fps lower than 60 creates some flicker?
2022-2-20
DJI Stephen
Hello there Ginopino. I am sorry for the trouble this has caused and thank you for reaching out. may we please know what is the model of the mobile device that you are using please on your DJI OM 5 for us to be able to isolate the said issue? Thank you.
2022-2-20
Montfrooij
Flight distance : 2560453 ft
I think it is normal.
My initial thought is that this has to do with the way camera's capture video.
It is just a stream of photo's and if the movement is too fast between the shots, it gets stuttery.
Try moving left to right (panning) very quickly and you will probably see the same effect.
The faster the shutterspeed, the less likely this will happen.
2022-2-21
