Drone has error during flight plan
698 5 2022-7-26
AndreUeji
Brazil
Hello, I work with surveying arable areas using P4P. For a few weeks he has been having an error, during the flight plan, where the camera starts to turn sideways, not maintaining the 90° as usual in this operation. I've already performed the updating of all firmware, gimbal calibration, camera calibration, control calibration, in short all possible calibrations and the same continues with the same error. Any suggestions on how to resolve this issue?
Thank you all.
2022-7-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to download the DJI Assistant 2 software and kindly please refresh/update the firmware of the unit and check if the issue persists? You may download the software using the link below. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... t-dji-2-for-phantom
2022-7-26
AndreUeji
Brazil
DJI Paladin Posted at 7-26 21:36
https://www.dji.com/downloads/softwares/assistant-dji-2-for-phantom
Hello, I have already performed the firmware update by DJI Assistant 2, from the rtk base, from the control and from the drone, the problem of the camera turning has been solved, but now during the flight plan the camera stops taking pictures to compose the mosaic. I already checked the memory card and it has free memory, do you have any other suggestions?
Thanks.
2022-7-27
DJI Paladin
AndreUeji Posted at 7-27 05:42
Thanks.
Thank you for keeping us posted. Could you please try to use a different SD card and check if the issue persists? Please kepe us posted. Have a nice day ahead!
2022-8-1
AndreUeji
Brazil
DJI Paladin Posted at 8-1 05:11
Hi, I replaced the SD card and apparently the problem was solved.
Thank you for your help.
2022-8-1
DJI Paladin
AndreUeji Posted at 8-1 09:59
Perfect! We're glad that you managed to isolate the issue. Should you have other inquiries, please don't hesitate to reach us. Have a wonderful day ahead!
2022-8-4
