New Mini 3 Pro Firmware Released (09/26/2023)
jedp
Flight distance : 991991 ft
Mobilehomer Posted at 10-26 13:33
DJI cannot know if the drone will be used by someone who requires registration or rid. To code two different firmwares is not feasible. By U.S. law, the rid cannot be bypassed or disabled.
However, they can enable FCC or CE mode depending on the geography where it is used.... so they must be able to enable RID in countries where it is legally required only.
2022-11-7
FL_Flyer
Flight distance : 810594 ft
When I connected to DJI assistant to check for more updates, and it kept  prompting me to upgrade to a later version, but it fails after downloading. I phoned support and they said that file was “Flysafe”. Is anyone else seeing this anomaly?
2022-11-7
AVsupport
Flight distance : 618734 ft
"Lens Profile for FC3582 cannot be detected"
Mini3 Pro has vignetting issues and colour shift when using DNGs natively, and manufacturers lens correction profile is not embedded in the DNGs.
This makes stitching 360 spheres from DNGs nearly impossible.
Please fix this
2022-11-9
Gabco
Oracle Miata Posted at 8-17 07:37
Make sure and update all your batteries as well.
I also updated all three of my batteries and now the drone LED's blink red indicating low battery.
They are at 60% minimum, and the controller confirms this.  Any suggestions?
2022-11-11
Marco899
Today the first flight after the update and am not really happy. Upside down drone doesn't stop the motors anymore, the drone drifts a bit and panos get worse stiched. And that with windless weather.
2022-11-12
AK_90
Flight distance : 3152241 ft
My mini 3 arrives tomorrow I can’t wait to get it up to date and in the air!!
2022-11-14
DJI Natalia
Marco899 Posted at 11-12 11:10
Hi, there.
We are sorry for the inconvenience caused.
May we know if your problem is resolved now?
If not, could you please check the following details and keep us updated?
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. Check whether the device drift or unsteady hovering is within the hovering accuracy range.
3. Please move to another flight environment to test.
4. Check the propellers and the state of the motors. Check whether any motor rotates abnormally when the propellers are not mounted.
5. Confirm that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
6. Check whether the control stick is being pushed. If the stick movement is offset, the remote controller should be calibrated.
Should you have any further questions, please feel free to let us know.
2022-11-15
Marco899
I really don't understand where this standard talk could serve any solution to my complaint. except that this might fix the drifting. Unfortunately, things just got worse with panos stitching and the drone no longer stops when you flip it over. So I want you to give me the option to downgrade.
2022-12-3
JLB768
Flight distance : 1259715 ft
Haven't flown my Mini 3 Pro since it updated to run Remote ID, I have zero interest in it anymore. Probably sell it and buy a new F1 Wheel for my racing sim.
2022-12-20
Ranjan
India
AVsupport Posted at 2022-11-9 16:38
This should have been fixed by now, can anyone confirm that last few firmware solved this or not?
2023-3-29
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Ranjan Posted at 3-29 04:07
There are no problems in Adobe Lightroom, the profile is embedded in the file.
2023-3-29
Nexus Redux
Flight distance : 7878520 ft
Austria
WTF. Cant use the new update after installing it, Gain and Edpo still the old Menu. Fly App on RC Controller still is on 1.9.4 and im not able to update the App on the Controller to 1.9.8
2023-3-29
onymar
Flight distance : 564400 ft
Nexus Redux Posted at 3-29 08:30
Same here.
Strange that some people appear to have received the new RC update.
Updated DJI Assistant and that also shows no newer version.
Pointless M3P update for anyone using the RC controller.
2023-3-29
nixuspix
Flight distance : 2864974 ft
Latvia
I am really disappointed as well. After system upgrade with DJI Assistant from MAC, i have firmware 0500 version, RC firmware 0400 version, but DJI Fly 1.9.4 version and NO one extra byte of info in Gain&Expo section WTF
2023-3-29
nixuspix
Latvia
2023-3-29
djiuser_HkPYPooXu2oQ
Flight distance : 928 ft
Norway
Same issue here also, no firmware update available for the RC. Got the M3P updated but not able to use the change due to stuck on 1.9.4 of the fly app. Tried Assistant 2 also to no result
2023-3-29
RUD_fr
no dji rc remote controler firmware v01.02.0500 only v01.02.0400
2023-3-29
Robert Łabuz
Flight distance : 467037 ft
Poland
dji released a dud again, which can't be uploaded
2023-3-29
RUD_fr
perhaps we have to wait a bit
2023-3-29
CptKangaroo
Looking for some help here. I was able to update my mini-3-pro to the latest 01.00.0500 firmware that just came out without issue. However my RC-Pro is only showing firmware version 01.02.0400 and I know there is a 01.02.500 version. Also my DJI fly app says version 1.9.4 and there is a 1.9.8 version out.
So how can I update these - I’ve clicked check for updates and the RC says “Your firmware is up to date”. In addition the recent firmware upgrade for the mini-3-pro was supposed to add the ability to factory reset the RC-Pro or Erase all Data on the RC. Those options are not available to me after the upgrade - so something isn’t upgrading fully.
2023-3-29
4wd
Flight distance : 545817 ft
What's going on has the app update been paused as I got drone update but app on RC says 1.9.4 is latest available?
2023-3-29
fans3eceac83
Same here aircraft updates firmware but rc stoll on 1.94. Also the green led on the controller doesn't light up when connected to the drone.
2023-3-29
michaelchia
Why is DJI RC Remote Controller Firmware: v01.02.0500 not available as an update? Still says 1.02.04 is the latest. I have upgraded the firmware for the drone but cannot use the new features as my RC app is not the latest. I am in Australia.
2023-3-29
djiuser_i30O4usIoYfr
Iceland
The new features are not installed on the RC controller with firmware 1.00.0500 update download via wifi. Should I try again using DJI Assistant 2.
2023-3-29
djiuser_uGpZisZQ1ULW
I have updated firmware to latest yet in the correct area of RC  it does not show vertical and horizontal speed  to allow me to reduce speed in cine mode
2023-3-29
Andre vd Weide
Flight distance : 1503937 ft
now version v01.02.0600 online with flyapp 1.9.9
2023-3-29
KlimaPic
Flight distance : 360115 ft
Hi, is it correct that I see following:
Aircraft Firmware: v01.00.0500
DJI RC Remote Controller Firmware: v01.02.0600
DJI Fly App: v1.9.9
2023-3-30
RUD_fr
thank you dji for this update now v01.02.600 is on my rc and that run very well!
2023-3-30
djiuser_iiKucE29TbH5
Flight distance : 143835 ft
Poland
Updated the mini 3 pro FW yesterday and now my drone can't focus when in flight mode.  On the previous FW, everything was fine. Here is two videos with broken and normal focus
BTW manual focus works fine and I can focus with the peaking, but not in AF.
Maybe anybody else faced such an issue?
2023-3-30
Blériot53
Flight distance : 6260935 ft
Got it!
2023-3-30
dronethemoment
Flight distance : 9021293 ft
Updated my mini 3 pro and after my first hyperlapse flight I was in a circle and noticed that my signal wasn’t dropping.  It’s like it was before the last updates in November.  Solid 30 satellites and full bars at 2,000 ft.  Usually I’d have to turn back but this kept going so long and solid I almost ran outta battery getting home. I’m happy with this!!
2023-3-30
SkipMc
Flight distance : 233166 ft
Thailand
Hello, I cannot update to the latest version as all updates are blocked on my RC with the error: "Server error: Wait a moment and try again(Code:0x1151009fffff)" - I have logged out and back into my DJI profile, have rebooted the RC remote and Mini 3 Pro drone, and also waited 45 minutes, and the error happens every time I try to update via the Profile section or the Settings-About section of the RC UI. Please advise. Thank you.
2023-3-30
AlbertoBkk
Flight distance : 47434 ft
Thailand
I updated yesterday in Banbgkok. No problems. RC has now more editable parameters. Thank you
2023-3-30
dronethemoment
The EV settings don’t have any effect on the controller’s video but after a hyperlapse the preview video shows the proper EV.   I thought the filter I had was too dark and turned up EV to 1.7 and started a lapse then stopped and looked at the short video. Clearly not what I’m seeing on my screen. The screen is really dark like stuck on EV 0. I couldn’t see this on the daytime but night time is obvious.
2023-3-30
StrangerFings
Flight distance : 76010 ft
Sure would be nice if DJI would give the Mini 3 Pro a flight planner like.... idk..... WAYPOINTS?
2023-3-30
chrisvomradio
Flight distance : 3241519 ft
CloudVisual Posted at 2022-8-18 04:47
If I refer to it as ISO priority, I'm due a headache of replies and misunderstanding, but I'm glad we've agreed that this is a necessity.
Another confusing comment but you can set the iso to 100 and the shutter to "automatic" and you are fine. Or did I also misunderstand?
2023-3-31
chrisvomradio
After the update I suddenly lost connection. And the drone went into ATTI mode. At night. Above the sea.
It didn't respond and drifted with the wind..
I switched off the DJI RC to initiate the RTH. Luckily that worked and it was only 80 meters away.
Anyone able to assist me with this one?
2023-4-1
djiuser_qZ4ozz9riuet
Flight distance : 2146132 ft
After this update I noticed that there was no prompt to update the batteries.  Anyone else?
2023-4-1
Burt37
Flight distance : 4009 ft
chrisvomradio Posted at 4-1 04:39
I'm not sure that there is a relation between the latest update and your loss of signal...
Manual page 43 and 51, may help you...
2023-4-1
Willi33
Flight distance : 266913 ft
djiuser_qZ4ozz9riuet Posted at 4-1 17:06
Same. I tried all 3 batteries. No update
2023-4-2
